I removed lights now wont start
clubtreb
clubtreb is offline
PostPosted: Mon Feb 10, 2014 5:55 pm    Post subject: I removed lights now wont start Reply with quote
Ok i took lights to paint, replaced them with all connections are good. Went to start it and i had no battery charge. I jumped it and drove home thinking maybe the batterywould gain power. But no its been days driving it and jumping it each time.what should i look for ?
EDragnDean
EDragnDean is offline
PostPosted: Mon Feb 10, 2014 6:13 pm    Post subject: Reply with quote
Does it charge while running? Generator light on? Loose belt? Bad regulator?
Running generator? Alternator?
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image
tubdub
tubdub is offline
are the battery cables hooked up to the battery ?
clubtreb
clubtreb is offline
PostPosted: Mon Feb 10, 2014 6:19 pm    Post subject: Reply with quote
Yeah the battery cables are on tight. No it does not charge after drinking sorry driving!!! Damn computer likes to spell for me
clubtreb
clubtreb is offline
PostPosted: Mon Feb 10, 2014 6:22 pm    Post subject: Reply with quote
Belt is good and my gen light is broken. Just strange that i driven this bus for years then when i screwed with the lights something malfunction.
EDragnDean
PostPosted: Mon Feb 10, 2014 6:23 pm    Post subject: Reply with quote
Check voltage output while running. Assuming a generator, my first suspicion would be loose belt, worn brushes, bad regulator. Do you hear noise coming from the generator while running? What is your belt tension? Inspect the brushes, and shine on the contact points.
EDragnDean
PostPosted: Mon Feb 10, 2014 6:24 pm    Post subject: Reply with quote
Is your generator light on while running? If you turn the key without starting, both warning lights come on?
EDragnDean
PostPosted: Mon Feb 10, 2014 6:32 pm    Post subject: Reply with quote
Start with the generator light. Same bulb as your illumination lights. Pull and switch if its just a burned bulb, the report back.
clubtreb
clubtreb is offline
PostPosted: Mon Feb 10, 2014 6:34 pm    Post subject: Reply with quote
My warning lites don'twork. I know..... belt is good and tight. Now i have drove this bus for 8 years so brushes should be changed. I will check the yes gen output. Which should be good that the lights are bright. Is it possible that i shorted out something when i removed the lights? Oh and fuses are good.
clubtreb
clubtreb is offline
PostPosted: Mon Feb 10, 2014 6:38 pm    Post subject: Reply with quote
I have the new bulbs for the warning lites. I will install them tomorrow.and will keep you updated. Thanks for everyones help.
EDragnDean
PostPosted: Mon Feb 10, 2014 7:06 pm    Post subject: Reply with quote
How the generator light behaves tells you if the regulator is suspect, or car is charging while driving. (In addition to broken fan belt while driving). I also seem to recall the electrical system doesn't charge right without the light, but will defer to the other Samba experts.
don.ville Premium Member
Samba YardMan
don.ville is offline
PostPosted: Mon Feb 10, 2014 8:53 pm    Post subject: Reply with quote
You have ID the problem.
No GEN Light, alternator wont work.
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
Clara Premium Member
Clara is offline
PostPosted: Tue Feb 11, 2014 8:55 am    Post subject: Reply with quote
x3
zozo
zozo is offline
PostPosted: Tue Feb 11, 2014 9:28 am    Post subject: Reply with quote
I don't see where he says he has an alternator. Question
otis_bartleh
otis_bartleh is offline
PostPosted: Tue Feb 11, 2014 10:45 am    Post subject: Reply with quote
Thought I remembered hearing that before... Does the generator, not just alternator, need the gen light functioning to work properly?
-Adam
'59 Mango Bus
'69 Bug - Cobalt Blue
telford dorr
telford dorr is offline
PostPosted: Tue Feb 11, 2014 3:54 pm    Post subject: Reply with quote
If you have a generator, no indicator light is needed for proper operation. An alternator is different - without the indicator light, the alternator won't work. Power backfed from the light "kick-starts" alternator operation.
'71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
clubtreb
clubtreb is offline
PostPosted: Tue Feb 11, 2014 5:17 pm    Post subject: Reply with quote
Ok i but in new bulbs and holders. Turned key and it started.. But my warning lights still did not work. Where should i go next? Also new belt is on. I do have a gen not a alt.. very weird.. do the holders of the bulbs need to be in there mounting holes to complete a path??
clubtreb
clubtreb is offline
PostPosted: Tue Feb 11, 2014 5:21 pm    Post subject: Reply with quote
And yes it ran fine with no warning lights for a year. I want them fixed aswell. My bulb holders are new with a good spring in them and new bulbs.
otis_bartleh
PostPosted: Tue Feb 11, 2014 5:26 pm    Post subject: Reply with quote
clubtreb wrote:
I want them fixed as well.
I hear ya. I count on those to tell me if somethings wrong, would be kinda paranoid driving without them... Laughing
-Adam
'59 Mango Bus
clubtreb
clubtreb is offline
PostPosted: Tue Feb 11, 2014 5:34 pm    Post subject: Reply with quote
I am.. been driving by smell....
