Tins under cylinders are they essential?
SweetCars
SweetCars is offline
PostPosted: Fri May 30, 2014 7:49 pm    Post subject: Tins under cylinders are they essential? Reply with quote
I just bought a complet header for my car. Stock 1600. I have to take off the tins under the cylinders, is this going to cause my engine overheating??
Danwvw
Danwvw is offline
PostPosted: Fri May 30, 2014 7:54 pm    Post subject: Reply with quote
As they spread the air and force it over the fins on the back side of the cylinders and block some of the air they increase the air flow over the heads too. I would think the cylinders need them to keep from running hotter on the bottom side than the top! Probably not too big a deal for a drag race engine.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
mark tucker
mark tucker is offline
PostPosted: Fri May 30, 2014 7:59 pm    Post subject: Reply with quote
first off ...what exzactly tins are you refeering too??? there lottsa tin in these cars/busses..... some ok, some not ok to loose
udidwht
udidwht is offline
PostPosted: Fri May 30, 2014 9:14 pm    Post subject: Reply with quote
Deflector tins (below cylinders).
Don't run without them.
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
rs58rag
rs58rag is offline
PostPosted: Fri May 30, 2014 10:16 pm    Post subject: Reply with quote
are you referring to heater box sled shaped tins? Those protect pushrod tubes and deflect hot air away from engine. The cylinder air deflector plates or cool tins that attach to cylinder studs under cylinders is an absolute must to direct air around cylinders.
stan_tichomirov
stan_tichomirov is offline
PostPosted: Sat May 31, 2014 9:58 am    Post subject: Reply with quote
He means the sled tins. They do get in the way of my Bugpack merged header, mine are still on but I had to bend them. The little deflector fins won't be in the way and would be difficult to remove anyway.
Stan
Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build
mark tucker
PostPosted: Sat May 31, 2014 10:51 am    Post subject: Reply with quote
I think he needs to reply as to just what tins, but there is no need to remove the cylinder tins for a header,just the "sled" tins on some apps.or trim&modify to fit if you want to keep them.I personaly dont run any of that stuff but I think there good for road cars as well as offroad cars in directing&helping the used heated air out the rear easyer.my butt has been chewed so much on my spellen& grammer(still in cali)I no longer have a rear.... Rolling Eyes
57 Rag
57 Rag is offline
PostPosted: Sat May 31, 2014 12:34 pm    Post subject: Reply with quote
I personally run as much of the tins possible on all the engines Ive had. Like said before, its essential in cooling and them germans put them there for a reason. I just like to "massage" them into place if necessary. Smile
Ohhhhh and Mark. Its "easier" with an i. lol Laughing jus kidding bro. you ragged yourself so id figure id laugh with you. Wink
57 Ragtop
84x94 86C
IDAs
SweetCars
PostPosted: Sat May 31, 2014 1:09 pm    Post subject: Reply with quote
yes i mean the sled thins, which protect the push rods.
People told me that they are there only for protecting push rods. I guess helps for cooling.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat May 31, 2014 1:11 pm    Post subject: Reply with quote
They are wrong.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
tattooed_pariah
tattooed_pariah is offline
PostPosted: Sat May 31, 2014 1:21 pm    Post subject: Reply with quote
covered, again, and again, and again...
I searched for "industrial sled" because I remembered someone once showing how they made modified sleds to fit with headers..
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...mp;start=0
http://www.thesamba.com/vw/forum/viewtopic.php?t=522162&highlight=industrial+sled
http://www.thesamba.com/vw/forum/viewtopic.php?t=509872&highlight=industrial+sled
http://www.thesamba.com/vw/forum/viewtopic.php?t=401642&highlight=industrial+sled
http://www.thesamba.com/vw/forum/viewtopic.php?t=428462&highlight=industrial+sled
http://www.thesamba.com/vw/forum/viewtopic.php?t=416096&highlight=industrial+sled
http://www.thesamba.com/vw/forum/viewtopic.php?t=367242&highlight=industrial+sled
http://www.thesamba.com/vw/forum/viewtopic.php?t=337263&highlight=industrial+sled
-pariah
'72 Volksrod
Mr. 010
Glenn is offline
PostPosted: Sat May 31, 2014 2:06 pm    Post subject: Reply with quote
Unless you're smarter than the VW engineers, i'd suggest using every piece of tin the engine originally came with. Because if it wasn't needed, they wouldn't of put it on at the factory.
By every piece i don't mean just the large pieces, I mean the hoover bit, the lower tins that close off by #2 and #4 and the little square tins that fit in the heads (which no replacement head includes).
My 2180 with 9.5cr in a full body sedan has the stock oil cooler with the only additions of 1.5qt sump and remote filter and runs cool as a stock 1600.
That's because I use all the factory tin.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
SweetCars
PostPosted: Sat May 31, 2014 4:25 pm    Post subject: Reply with quote
Well I going to put the original exhaust system. Thanks for your advices and knowledge.
Dwayne_71SB
Dwayne_71SB is offline
PostPosted: Mon Jun 02, 2014 6:34 am    Post subject: Reply with quote
It's not hard to make your own tin so you can use the header and not sacrifice cooling.
'71 Super Beetle
Mr. 010
Glenn is offline
PostPosted: Mon Jun 02, 2014 7:45 am    Post subject: Reply with quote
Just get a header that clears the tins and thermostat and a set of Type 126 tins.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
