Fuzzy manual transmission plug after rebuild
Page: Previous  1, 2, 3  Next
Jon_slider
Jon_slider is offline
PostPosted: Tue Jun 03, 2014 10:36 am    Post subject: Reply with quote
snowsyncro wrote:
Jon_slider wrote:
Could you please also mention what
1. motor and
2. tires you use,
3. as well as any non stock gearing changes? What is your RPM@70mph?
RonC
Thanks Ron!
I hope others will also include those details so we can learn more about which motor, tire, and gearing configurations are associated with the most fuzz on the magnet.
My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
rmcd
rmcd is offline
PostPosted: Tue Jun 03, 2014 1:41 pm    Post subject: Reply with quote
insyncro wrote:
Plumbing an in line filter is not difficult at all and will add even more protection.
Pardon the dumb question. Does the filter become a constraint in the system as it gets plugged up with metal shavings? Is there a means to maintain the filter screen and if so how often should it be addressed?
Thanks
VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight=
Jon_slider
PostPosted: Tue Jun 03, 2014 3:08 pm    Post subject: Reply with quote
very easily. I would suggest each 10k miles. It catches stuff that does not get caught by an overly fuzzy magnet
http://weddleindustries.com/products/new-products/new-billet-inline-oil-filter-long-life-strainer
This is my tranny cooler filter at 5k miles
insyncro
Banned
insyncro is offline
PostPosted: Tue Jun 03, 2014 3:58 pm    Post subject: Reply with quote
Thanks
I check all filters at the engine oil change intervals.
Since -AN lines are used, quick disconnects can be used at the filter so it can be removed and only the fluid in the filter is lost.
The filters I use are 50 micron and some systems have a scavenger filter as well for big chunks Shocked .
It is truly amazing to see what comes out of the filters.
I smile every time I clean them Very Happy because those particles are not creating havoc in my box Wink
Wildthings
Wildthings is offline
PostPosted: Tue Jun 03, 2014 9:25 pm    Post subject: Reply with quote
This is the drain plug on my 1.8L Bay with an 091 tranny which has 50K miles on the last change of Pennzoil GL-4 oil.
boof1306
boof1306 is offline
PostPosted: Tue Jun 03, 2014 9:53 pm    Post subject: Reply with quote
A freshly rebuilt trans will "wear in" or "bed in" causing more metal fragments to be caught by the magnet. This is normal and unless large particles are on the magnet the "fuzz" is not an indication of anything. I always rub the matter on the magnet through my fingers to feel for anything significant. After a bedding in and a couple of oil changes I would expect a reduction in the quantity of material though.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Tue Jul 01, 2014 12:31 am    Post subject: Reply with quote
It was suggested I post a pic of my rebuilt transaxle drain plug after first oil change. Apologies for the crappy image. Used my phone camera.
Nothing unusual (only small bits of metal) but then I've only ever looked at two other transaxle drain plugs.
Oil changed at just over 1000 miles.
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
AndyBees
AndyBees is offline
PostPosted: Thu Jul 03, 2014 7:43 pm    Post subject: Reply with quote
Below is what my tranny oil drain plug looked like after 20k miles using regular spec dino oil. I re-filled it with regular dino oil again. After the 10k mile trip to Alaska this month, I will change again using synthetic.
DK tranny with the 4.57 R&P.
The tranny had all bearings replaced, except the pinion bearing.
I also installed a new 3rd and 4th gear (taller), new reverse gear, all new brass syncro rings, a new 3rd/4th shifting fork, and a new 3rd/4th hub.
'84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful.
Syncro Jael
Syncro Jael is offline
PostPosted: Mon Mar 16, 2015 11:25 am    Post subject: UPDATE with almost 20k miles on the rebuild. Reply with quote
Here are some photos of my transaxle magnet with about 20k miles on the rebuild. The last oil fluid change was at 6000 miles, so this magnet has a little over 13k miles.
This is my yearly or 10k mile gear oil change that I plan to keep records of.
I am a little over my mileage and under my yearly by a couple months.
I rotated the drain plug to get pics of each side. The one side is fairly clean. Possibly when pulling the plug with oil running on it?
I am again running Mobil Delvac 75/90.
1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat)
Merian
Merian is offline
PostPosted: Mon Mar 16, 2015 11:55 am    Post subject: Reply with quote
remove them to filter paper, flush with a solvent and you will find that the particles are actually quite small in size - they look larger due to magnetism holding them together
the only time to worry is when you find a huge accumulation or some large chunks of metal
Jon_slider
PostPosted: Thu Mar 19, 2015 5:22 pm    Post subject: Re: UPDATE with almost 20k miles on the rebuild. Reply with quote
Fantastic documentation Syncro Jael!
Syncro Jael
PostPosted: Sat Oct 03, 2015 9:34 am    Post subject: Re: UPDATE with almost 20k miles on the rebuild. Reply with quote
Just to keep up with documentation.
I just dumped the transaxle gear oil today. 12,500 miles since the last dump in Mar 15. AA rebuild now has 32,192 miles on it.
My only concern are the larger flakes from the past (2)two oil changes. If anyone cares to comment their thoughts? Most of the metal can not be felt between the fingers when rubbing them together. But there was one that could be felt.
Still shifts perfect, no noises, and it is still running cool. Very Happy
Sodo
Sodo is offline
PostPosted: Sun Oct 04, 2015 9:33 am    Post subject: Reply with quote
This is good stuff.
Here's my magnet after 9,000 miles since rebuild. I found that the last rebuilder put in a USED pinion bearing, which nobody would expect to last very long especially with a 173 HP engine. It was worn to have 1/4 INCH of endplay. The amount of steel that rolled off this bearing is probably a strip 6 inches long, 1/2" wide and 1/16" thick. The magnet is MAXED, and displays only a TINY fraction of the metal volume known to be in my oil. It makes me cringe. I had to replace lots of stuff, both shafts, R&P. Here's a link to pics of the USED bearing.
This is a shorter magnetic plug from a Smallcar bellhousing. Also, oil was drained "cold".
I wonder ---- if ALL the drainplugs shown are approaching MAX capacity.
What if you cleaned it, and re-insert it in the old oil and look again in a week? You can do this (in the interest of science). You can put the old oil back in. I've heard of attaching a shop-vac to the oil filler bunghole and R&R the magnet. I wouldn't leave the vac running too long,,,, have a helper run the switch & get 'er done. Can plug the hole with the filler bung, shut off the vac & take your time. (I have NOT done this process, but I would ! )
With the (obviously) rebuild, I'm adding a transaxle cooler system, with the weddle filter ---- but currently have no drainplug thus NO magnet. Kinda wish I had a magnet so I can compare to other members' fuzzy pics.
....KTMs, GasGas, SPOT mtb
Sodo
Sodo is offline
PostPosted: Wed Oct 14, 2015 12:57 pm    Post subject: Reply with quote
On my Smallcar bellhousing, the drain hole was 12mm above the trans floor, no way to drain out the bad stuff on the bottom. It wasn't difficult to modify it to drain to the bottom.
Here it is after widening the hole and covering the top of the hole. Now that I have an inspectable filter (Weddle) I'm inclined to vacuum the trans floor into my filter so I can look at whats there.n I covered the top of the hole because I have a cooler/pump system and I did not want it to suck air.
Looks like RJES lets you drain to the bottom (or lower) so you can get the funk out between oil changes.
Anyway I wonder how well a drain plug magnet can really work from an intermediate position that's uphill.
SSWesty
SSWesty is offline
PostPosted: Fri Jul 21, 2017 11:24 pm    Post subject: Re: Fuzzy manual transmission plug after rebuild Reply with quote
This is the second oil change on my AA rebuild with a peloquin and stock gearing which pushes around a 2wd Westy. The first oil change I ran Valvoline 75w-90 dino oil and replaced it with Valvoline 75w-90 SYN Power full synthetic. During this interval I've tweaked the engine a little bit with a 2200 piston kit from Rocky and a few other minor adjustments which probably net an additional whopping 5hp. I am looking at about 18,000 miles on this change which probably included about 3,000 miles of towing trailers with weights between 500-2,000 pounds. Most of the miles have been with 27x8.5 Grabber AT tires. When travelling on trips which is where all my miles come from we tip the scales between 4,750-5,000 pounds.
In a few of the pictures posted it appears that metal seems to collect on one side of the magnet and in this change mine shows that too.
It looks like minimal wear so I'll probably stretch the next change out a little to a 20k interval. Note to self that will be at 133k Smile
Sodo
Sodo is offline
PostPosted: Sat Jul 22, 2017 8:35 pm    Post subject: Re: Fuzzy manual transmission plug after rebuild Reply with quote
Hate to tellya but that's not really "minimal wear". I can say that any MORE than that would be alarming. It ain't good to be on the cusp of alarming. At your stage of rebuild (a couple changes in) you should be running very very little swarf in 15,000 miles. And very little swarf for the next 60k miles, the trans should be running clean, in it's heyday. Smooth running. If you want to run that oil another 20k miles (for whatever reason) you should at least LOOK at the plug at 5k. If it's clean, then maybe look again at 15k before going onward to 20.
I don't know what the goal is, in saving oil, but it's a false economy. You're far better off dumping the metal out of your trans as often as you can tolerate it. I do understand changing transaxle oil is no fun but its much easier (and cheaper) than yanking out your trans.
These vans are no longer the expendable grocery getter they were the 1st 100k miles. A good used trans no longer "exists" out there, like they did back in the '90s. They are now valuable antiques, and transmission parts are either NLA, perhaps substandard, and skyrocketing in cost.
You're trans is somewhat 'lucky' you gave it a sensible motor.
One thing to keep in mind. TheSamba's general concensus that a fuzzy magnet is "OK" ..... is because everybody's tranny is old, full of 200, 300k mile parts and they are shedding a lot of metal (grenading). Your magnet looking like theirs is not genuine comfort. They need to get that metal out of their trans more often, as it "compounds", makes more metal.
Your 18,000 mile magnet should be clean(er). At least there are no big parts. Maybe thats some of the break-in swarf. If the next check is cleaner, then that's good news.
SSWesty
SSWesty is offline
PostPosted: Sun Jul 23, 2017 12:17 am    Post subject: Re: Fuzzy manual transmission plug after rebuild Reply with quote
This is precisely why I started this thread was to figure out what normal should look like. Most of the folks posting seem to be pushing more HP so I can understand having a cleaner magnet would be good. Seems like my best comparison would be with what AndyBees and Wildthings posted. I do wonder how much the peloquin contributes to the build up on the magnet and I did a lot more towing in this last interval. We've been working on a house addition so Westy was been towing a lot of building materials in the last 9 months.
I wasn't clear on the oil change, I dumped the oil that was in there for 18k. For the next interval I was thinking about letting that run for 20k. However maybe sticking with a 10-15k service interval may be a better plan.
Sodo
Sodo is offline
PostPosted: Sun Jul 23, 2017 8:18 am    Post subject: Re: Fuzzy manual transmission plug after rebuild Reply with quote
On the Peloquin, Tom Lengyel, (Syncroshop) who is a white-glove kinda guy, feels that the Peloquin contributes very little swarf, and is not a significant contributor. Ask him what your oil change interval is, he will say "I don't know - what does your magnet look like?". It's a chicken/egg scenario. Basically you have to look at your magnet. But can YOU look at your magnet? Not many can.
I understood what you meant. Your recent rebuild has some new parts, and mostly old parts. Some parts will hold steady, and run clean. But some of those old parts may be INCREASING their swarf production soon. I don't think there is any possible way to predict lifetime of a box full of old parts simply running on new bearings. I hate to rain on parades but..... somebody has to increase the attention on transaxle oil condition or there's just going to be a LOT of pain in Vanagonland (spread out over 10, 20, 30,000 of miles though).
SS you are doing a good thing by forcing dialogue on this subject. Everyone agreeing that that horrible stuff is "just fine" does no justice to a forum. Members come to theSamba for information, not always a pat on the back. There are hundreds of:
    1) over engined vans
    2) under-maintained vans
    3) decent rebuild of "used parts"
    4) crap rebuilds
out there, and the chickens are coming home to roost. Transmission noise creeps up on you. Every year it's a little louder, but you can you POSSIBLY monitor sound level? An old farts' hearing may be degenerating at the same yearly rate that his trans is getting louder.
I think if you are capable of getting under the van (and curious) gear oil inspection is useful. Because then you KNOW what's going on in your trans. Furthermore, if your trans is generating swarf you need to get it out of the lubricating oil ASAP or rebuild time will come sooner, significantly sooner.
As far as what's acceptable metal to have running around in your precision, high-dollar antique machinery.... well would you accept that in your engine oil? NO because that would have already caused catastrophic damage. Your engine is already destroyed, don't start it again with that in it. So why is it "OK in the trans"? It probably won't crap out tomorrow,,,, but it's NOT OK.
In a trans, the damage just creeps up on you and fooks up $$$$ thousands in parts, over 30, 40,000 miles. Noise increases incrementally, you don't notice it. You have to look at the oil, but nobody else is looking, and furthermore they advise YOU against looking because then they have to look too. Wink
There should be no doubt that Sodo thinks, in his hyper-verbious manner, that "metal contamination" needs to be removed from any antique trans. It's a grinding paste. You have LOADS of useful parts in there you DON'T WANT to replace. You don't just open up a gearbox, dump it out and put all NEW stuff in. You run lots of old stuff. And old stuff can run clean - or - make more swarf. Or run clean for 60k, 30k, 15k miles then start producing swarf. And there's LOTS of old parts, all with varying remaining lifetimes. Your only hope - is - irrespective to which part is contributing, just get that swarf OUT. It's really NOT that difficult for a handy guy/gal. Or buy all NEW stuff at next rebuild. Shocked Next SOONER rebuild.
It adds another line-item to your maintenance list, which is already kinda long with Vanagons. A large number of owners cannot add this line-item (or any). Owners who have re-engined, increasing HP by 30, 50, 100% should add this line item (gear oil inspection). Most people don't think about their trans ever, because most people don't re-engine their cars, but Vanagon people often re-engine. Adding a big engine, and NOT adding extra caution WRT the trans is kinda foolish actually. I found this out the hard way. I knew it too, of course, but I suppressed it and I think everyone else does too. Maybe it could be done back in the '90s when there were used trans to be had.
Ignoring the transaxle flies in the face of sensibility. The Vanagon has a small trans. Increase the HP, and you'sd better pay closeer attention to the trans. and the ONLY way to monitor it is by gear oil inspection, and comes down to what collects on the magnet. "NAWWW yours looks fine, mine was even worse!" is not helpful information to have on TheSamba. Comforting, for the two members in the exchange but not helpful to the 98 others who need INFO.
The other challenge is, you can't tell other people what you're doing. They will tell you; "pfffft I've never changed the trans oil in any vehicle I've ever owned". Others will tell you "just use a higher quality gear oil" (which turns into "more expensive grinding paste"). There is no REAL discussion and knowledge WRT this subject, even though everyone understands the basics, they are unwilling to apply known logic to gear oil. That's what you're up against. Probably because gear oil stinks.
SSWesty
SSWesty is offline
PostPosted: Sun Jul 23, 2017 10:31 am    Post subject: Re: Fuzzy manual transmission plug after rebuild Reply with quote
Good to know we have input from one source that says the Peloquin shouldn't contribute much. What I am learning from this discussion is I need to figure out a way to pull the magnet and check it out more frequently like every 5k. Now I am thinking about a little experiment. In the next week I am making about a 500 mile run so it would be interesting to see what the magnet picks up right after a clean refill. That sucker better be clean. I do consider oil to be much cheaper than tranny parts so I don't have an issue with more frequent changes.
Question, what tricks do you guys have for pulling the magnet and not making a huge mess? Do you have a second plug that you screw in or do you use some other type of plug?
Sodo
Sodo is offline
PostPosted: Sun Jul 23, 2017 10:42 am    Post subject: Re: Fuzzy manual transmission plug after rebuild Reply with quote
Buy two new magnetic plugs (then you have three). Use one the filler hole, so you double your magnetic surface capacity. The other is for the "quick switch" at the drain bung.
Another thing you can do if your van sits for weeks at a time,,,,, (but so far I'm one-hand-clapping here Embarassed Wink haven't heard or read of a single person doing this....) is park your van nose-up (a foot? ++ ?) so more of your heavy stuff is likely to settle near the drain hole.
When you do this plug swap to observe your magnet, you will drain off the bottom 8-16 oz? of oil. I did some observations last year WRT metal settling in (clear water-jugs of) gear oil and found that in 3 weeks, a lot of the metal settles to the bottom. Consequently, if your van has been parked for awhile (nose up) and you drain off the bottom ??8-16?? oz, you have reduced your metals. So in addition to looking at the magnet, you can reduce, AND observe the dregs of your oil too. Sort of a stool sample. Wink Then replace it with 16 oz (or whatever volume came out) of fresh oil thru the oil filler.
Page 2 of 3
