200mm flywheel specs
Shlomi32
Shlomi32 is offline
PostPosted: Wed Nov 19, 2014 1:10 am    Post subject: 200mm flywheel specs Reply with quote
Hi, im looking for 200mm flywheel specification and dimension.
specially, the 'a' from the image...
b.d.w, the image i found is for porch flywheel..
modok
modok is offline
PostPosted: Wed Nov 19, 2014 1:19 am    Post subject: Reply with quote
for the "12volt 200mm clutch" type flywheel, Dimension A should be 21.0mm-21.2mm
Future search tags: Flywheel depth step specification.
Shlomi32
Shlomi32 is offline
PostPosted: Wed Nov 19, 2014 1:21 am    Post subject: how do you know that? Reply with quote
Is there any place to see that information?
modok
modok is offline
PostPosted: Wed Nov 19, 2014 2:10 am    Post subject: Reply with quote
It is in Sachs catalog, napa clutch catalog, and AERA database.
Shlomi32
Shlomi32 is offline
PostPosted: Wed Nov 19, 2014 4:03 am    Post subject: link Reply with quote
can you send me a link of it??
is there a original data from VW?
ashman40
ashman40 is offline
PostPosted: Wed Nov 19, 2014 5:45 am    Post subject: Reply with quote
That is less than 0.008" difference!
This explains why people have such a problem when the machine shop re-surfaces the clutch face but forgets to cut the "shelf" by the same amount to restore the distance into spec.
AshMan40
Shlomi32
Shlomi32 is offline
PostPosted: Wed Nov 19, 2014 8:25 am    Post subject: Reply with quote
this is exactly why i asked this question...
i think that my flywheel is not at the right tolerance....
modok
modok is offline
PostPosted: Wed Nov 19, 2014 5:31 pm    Post subject: Re: link Reply with quote
no, sorry.
Old catalogs are not available for download, and AERA PROSIS is a paid subscription.
Bruce
Bruce is offline
PostPosted: Wed Nov 19, 2014 7:39 pm    Post subject: Reply with quote
No, the reason most used flywheels are out of this spec is because the machine shops are doing exactly what you described. They don't know the spec is 21.0mm, so they just take equal amounts off both surfaces, preserving the previous wear amount in the flywheel.
The correct way to machine the flywheel is to grind the disc surface, then take the ledge down to 21.0mm
