Retrosound Hermosa radio question
cn63bug
cn63bug is offline
PostPosted: Sat Sep 05, 2015 8:52 pm    Post subject: Retrosound Hermosa radio question Reply with quote
So I just installed the Hermosa in my 66 along with Retrosounds DVC speaker and it sounds really great. Everything is hooked up correctly. Now when the engine is off, it sounds awesome. However, when the engine is running, the sound cuts in and out. It doesn't matter if it's on radio, AUX or BT. It's the same. When I shut the car off and turn it back on without starting the car, everything works great. I'm leaning towards a weak ground perhaps, but wanted to see if anyone has some other suggestions.
Thanks
caleb0101
caleb0101 is offline
PostPosted: Sun Sep 06, 2015 12:17 am    Post subject: Reply with quote
Is your charging system working correctly?
Ruby red 1967 beetle sedan with a 2021cc
1967 beetle sedan baja project
April 60 euro spec ragtop beetle with a 1641cc
cn63bug
cn63bug is offline
PostPosted: Sun Sep 06, 2015 7:04 am    Post subject: Reply with quote
Yep. Went through and verified that it was.
grandpa pete
grandpa pete is offline
PostPosted: Sun Sep 06, 2015 12:52 pm    Post subject: Reply with quote
That's right . It IS WORKING CORRECTLY . Maby You have a generator and your fancy electronics doesn't like that.....they work with alternators......generators have fields......generators create static fields..........
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
Wayne S. Johnson
Wayne S. Johnson is offline
PostPosted: Sun Sep 06, 2015 2:58 pm    Post subject: Reply with quote
You can isolate the 12V power input using a small 12V battery. This will determine if the problem is input power related or ignition/generator noise related.
HYBRID STARTER 6/12 https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231
cn63bug
cn63bug is offline
PostPosted: Sun Sep 06, 2015 11:42 pm    Post subject: Reply with quote
I'm starting to think it's ignition related. The car has an alternator on it. I did install a pertronix igniter and flame thrower coil on it before I installed the radio. I re-routed the power directly to the battery and it improved but the sound still cuts in and out just not as bad.
drmyers
drmyers is offline
PostPosted: Mon Sep 07, 2015 2:10 am    Post subject: Reply with quote
I have a Retrosound in my 64 with a generator and don't have this issue. Just tossing it out there.
Life in the fast lane... Your mileage may vary..
cn63bug
cn63bug is offline
PostPosted: Mon Sep 07, 2015 11:11 am    Post subject: Reply with quote
Yeah, it isn't an alternator or generator issue. I've had those before and this isn't the same. I have a feeling that the power leads for the radio are picking up "interference" from the main harness while the car is running due to the ignition system. Going to try running the leads back to the battery on the other side of the car which will be a little tricky for me as I don't want to drill any other holes to run wire through Smile
I'll post back up what I find later.
Thanks
Wayne S. Johnson
PostPosted: Mon Sep 07, 2015 1:27 pm    Post subject: Reply with quote
Noise entering your radio can be reduced using a PI FILTER.
A PI FILTER is a low pass filter consisting of two capacitors connected in parallel with a series inductor between the capacitors.
Free online low pass filter calculator, with Bode plot.
http://sim.okawa-denshi.jp/en/RLClowkeisan.htm
bluebus86
Banned
bluebus86 is offline
PostPosted: Mon Sep 07, 2015 3:08 pm    Post subject: Reply with quote
What's a static field in so far as a generator is concerned verse an alternator?
Aynthm
Aynthm is offline
PostPosted: Mon Sep 07, 2015 5:31 pm    Post subject: Reply with quote
Check the condenser wire under the distributor, could be frayed and grounding out on the case.
cn63bug
cn63bug is offline
PostPosted: Mon Sep 07, 2015 6:10 pm    Post subject: Reply with quote
No condenser installed anymore. Has electronic ignition. I replaced the plug wires today as I was wanting to put new ones on and hadn't did it yet. Once installed, the stereo hardly cut in and out at all. Didn't do it all for nearly 20 minutes and then started to sporadically do it. Going to look into the low pass filter suggested by Wayne next.
cn63bug
cn63bug is offline
PostPosted: Mon Sep 14, 2015 6:13 pm    Post subject: Reply with quote
So I wanted to post an update to my issue with audio cutting out.
I tried several different routes to get rid of the problem. I replaced plug wires (my old ones were looking a little worse for wear anyway) and it seemed to help some. Routed the power wires to the battery directly. Didn't work. Re-routed the ground to the battery and didn't really help much either. Ended up routing the power wires on the other side of the car away from the harness and it seems to have solved the issue. Ran it all day today without issue. One other thing that I did since I wasn't using the hazard switch (there wasn't one when I bought the car), was put a push pull switch in it's location and use a factory knob on it to create a switched power so it's not on my ignition. Don't have to have the key on to use it and potentially miss up my ignition.
Thanks for everyones input.
