rmr2122 Samba Member
Joined: August 18, 2013 Posts: 96 Location: San Francisco, CA
Posted: Sun May 15, 2016 10:20 am Post subject: Broken pencil in cylinder while finding TDC |
1971 Super, stock engine. I was doing a simple distributor swap and did the pencil test to confirm TDC. The pencil broke and the eraser end is now lost in my #1 cylinder. What's the fastest and easiest way to get it out? I can't feel it down the hole so tweezers are not going to work.
Thanks in advance. |
Agent47 Samba Member
Joined: April 22, 2016 Posts: 271 Location: Scott AFB
Posted: Sun May 15, 2016 10:46 am Post subject: Re: Broken pencil in cylinder while finding TDC |
You could try a shop vac with the smallest attachment you have, it may be able to pull the piece out.
Personally, I would take the head off and ensure all the foreign materiel is removed; it would be work the extra work not to damage my engine. |
Posted: Sun May 15, 2016 10:55 am Post subject: Re: Broken pencil in cylinder while finding TDC |
| Thanks! Do I need to remove the engine to take the head apart? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33587 Location: Hot Arizona
Posted: Sun May 15, 2016 10:56 am Post subject: Re: Broken pencil in cylinder while finding TDC |
| rmr2122 wrote: |
| 1971 Super, stock engine. I was doing a simple distributor swap and did the pencil test to confirm TDC. The pencil broke and the eraser end is now lost in my #1 cylinder. |
1. I can't believe that you did this - you had received poor information, maybe from the Compleat Idiot book. A plastic drinking straw is a tons better choice !!!
2. Others have done this too, and posted their sob stories and fixes here.
http://www.thesamba.com/vw/forum/viewtopic.php?t=626188&highlight=pencil+broke
http://www.thesamba.com/vw/forum/viewtopic.php?t=415893&highlight=pencil+broke
http://www.thesamba.com/vw/forum/viewtopic.php?t=225356&highlight=pencil+broke
| rmr2122 wrote: |
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sun May 15, 2016 11:04 am Post subject: Re: Broken pencil in cylinder while finding TDC |
whobba Samba Member
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8881 Location: Sunset, Louisiana
Posted: Sun May 15, 2016 11:08 am Post subject: Re: Broken pencil in cylinder while finding TDC |
| rmr2122 wrote: |
The job would be much faster if you remove the engine. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Sun May 15, 2016 12:15 pm Post subject: Re: Broken pencil in cylinder while finding TDC |
Thanks for the troubleshooting. I live in Brooklyn and my car is parked on the street, so dropping the engine is a bigger deal than if it were in a driveway or garage.
I'm going to try the shopvac and grabber methods. If they don't work, I'm going to fire it up and let the damn thing burn. I'm sure there will be some disagreement with this method, but I seriously double the damage capabilities of a thin piece of metal wrapped around the end of the pencil on this tank of an engine. |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1790 Location: Niagara Region, CANADA
Posted: Sun May 15, 2016 12:17 pm Post subject: Re: Broken pencil in cylinder while finding TDC |
| Wont a magnet work on the eraser end of the pencil? |
slalombuggy Samba Member
Posted: Sun May 15, 2016 12:30 pm Post subject: Re: Broken pencil in cylinder while finding TDC |
| rmr2122 wrote: |
Have you ever seen what a wafer thin lock washer will do to a head and piston? Don't think that it will pop right out, you will do damage to your motor no ifs ands or buts. If it doesn't come out with a vacuum pull the head or fk up your engine, your choice.
brad |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11812 Location: Redding, CA
Posted: Sun May 15, 2016 12:32 pm Post subject: Re: Broken pencil in cylinder while finding TDC |
Use the shop vac, or any vacuum cleaner. Tape up a clear hose to the vacuum suction--a hose that will fit into the spark plug hole. Stick the hose in and turn on the vacuum. Watch the clear hose for the eraser head.
However, if no eraser shows up in the hose, the eraser may simply be stuck to the hose end, so gently pull out the hose with the vacuum still operating.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Sun May 15, 2016 12:44 pm Post subject: Re: Broken pencil in cylinder while finding TDC |
| Tim Donahoe wrote: |
Tim |
Uhh,if the rings are good you wont draw the eraser out....correcting stupidity should cause pain,it keeps the process from repeating..yard out the engine,take off the head. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80684 Location: Sneaking up behind you
Posted: Sun May 15, 2016 1:06 pm Post subject: Re: Broken pencil in cylinder while finding TDC |
| Cusser wrote: |
| rmr2122 wrote: |
[/quote]
Take the pulley bolt off and turn the engine so the key way is at 9:00. Now it is at TDC on either #1 or #3. Reinstall the nut, remove the valve covers and rock the engine back and forth observing the rockers on #1 and #3. If the #3 rockers are moving, it's at TDC on #1. If the #1 rockers are moving, it's at TDC on #3.
No need to stick anything inside the cylinder. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2931 Location: Germany
Posted: Sun May 15, 2016 2:12 pm Post subject: Re: Broken pencil in cylinder while finding TDC |
| Dougy Dee wrote: |
Yes, a rubber magnet. _________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
Glenn  Mr. 010
Posted: Sun May 15, 2016 2:22 pm Post subject: Re: Broken pencil in cylinder while finding TDC |
| Volks Wagen wrote: |
| Dougy Dee wrote: |
Yes, a rubber magnet. |
Maybe a wood magnet would be better.
The metal around the eraser is most likely aluminum. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sun May 15, 2016 2:46 pm Post subject: Re: Broken pencil in cylinder while finding TDC |
| ALUMINUM! Then that wont work. I should have checked more pencils than the old one I found in the back shop... It was steel/magnetic. |
Danpa Samba Member
Joined: August 21, 2007 Posts: 1334 Location: Valparaiso, in
Posted: Sun May 15, 2016 3:00 pm Post subject: Re: Broken pencil in cylinder while finding TDC |
Could he/she remove the bolts in the rear of the frame fork and lower the engine/trans enough to get the head off? Might not have to completely remove the engine that way.
Just a thought,
Dan |
Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Sun May 15, 2016 3:11 pm Post subject: Re: Broken pencil in cylinder while finding TDC |
| rmr2122 wrote: |
Take it from me, I've worked on enough old junk on Queens N.Y. streets. If you can't possibly pull the engine and you have 115 volt out there on the curb, do the shop vac with the tiny hose, etc. but don't fire it up, just turn it over by hand and hopefully crunch it up enough separating the aluminum band from most of the wood. Then do the shop vac again until you at least get the metal piece. Any wood left shouldn't be too bad if it's in small enough pieces. It's not the right way but sometimes you gotta do what you gotta do. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
Posted: Sun May 15, 2016 3:26 pm Post subject: Re: Broken pencil in cylinder while finding TDC |
I wonder would pouring oil in the plug hole fast cause it to float up and out? _________________ 1973 1303 with AB-motor - sporadic
Glenn  Mr. 010
Posted: Sun May 15, 2016 3:48 pm Post subject: Re: Broken pencil in cylinder while finding TDC |
| Dougy Dee wrote: |
So is the cast iron cylinder.
I'd get a borescope and one of those 3 finger grabbing things on a flexible shaft. _________________ Glenn
Member #1009
#BlueSquare
