chabanais Samba Member
Posted: Wed Nov 23, 2016 3:11 pm Post subject: Re: 1970 bus trailer hitch install |
I have the same Vintage Speed exhaust and would be curious whether this application fits. _________________ "I spud therefore I yam." |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5009 Location: Richmond, Verjinya
Posted: Tue Dec 06, 2016 3:59 pm Post subject: Re: 1970 bus trailer hitch install |
My new one bar design will work with the stock style Vintage speed exhaust. I Thought I have a photo of the setup but I can't find it. It will not work with the lowered bus style. _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
earlybayjim Samba Member
Joined: July 12, 2013 Posts: 250 Location: East Dubuque, IL
Posted: Sat Oct 27, 2018 6:00 pm Post subject: Re: 1970 bus trailer hitch install |
| jeremyrockjock wrote: |
| My new one bar design will work with the stock style Vintage speed exhaust. I Thought I have a photo of the setup but I can't find it. It will not work with the lowered bus style. |
Has anyone confirmed the vintage speed exhaust fitment? I have this exhaust sitting here ready to go and wondering... _________________ 1971 Chianti Red Westfalia x2
1985 Westfalia
1984 tintop |
Posted: Mon Mar 18, 2019 3:14 pm Post subject: Re: 1970 bus trailer hitch install |
I finally got around to fitting your trailer hitch with the VS exhaust! It fits great! Great job.
1985 Westfalia
1984 tintop |
MonkeySee Samba Member
Posted: Tue Mar 19, 2019 8:20 am Post subject: Re: 1970 bus trailer hitch install |
| Anyone know the turnaround time on an order? |
Posted: Wed May 08, 2019 5:09 am Post subject: Re: 1970 bus trailer hitch install |
Here is one of Jeremy's early bay hitches doing some work!
1985 Westfalia
1984 tintop |
Posted: Sat May 11, 2019 1:00 pm Post subject: Re: 1970 bus trailer hitch install |
| thefalconer_88 wrote: |
| Here is one of Jeremy's early bay hitches doing some work! |
What motor are you running to pull that trailer? |
Posted: Tue May 21, 2019 6:12 am Post subject: Re: 1970 bus trailer hitch install |
| MonkeySee wrote: |
1776 with dual 40hpmx carbs. _________________ 1971 Chianti Red Westfalia x2
1985 Westfalia
1984 tintop |
Lionhart94010 Samba Member
Joined: January 04, 2005 Posts: 1418 Location: SF Bay Area / Silicon Valley / So Cal
Posted: Fri Jul 19, 2024 12:30 am Post subject: Re: 1970 bus trailer hitch install |
Would you happen to have a through the bumper 68 to 71 Bay model picture?
And do you know if that puts the hitch too high?
I have an extra bumper that is a bit reinforced as well that I could use and Keep the original should ever need to change back to stock🙂 _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm |
CaptainHaddock Samba Member
Joined: April 20, 2005 Posts: 42 Location: Victoria,British Columbia,Canada
Posted: Fri May 16, 2025 9:52 pm Post subject: Re: 1970 bus trailer hitch install |
I Received the Hitch from Jeremy a few weeks ago, finally had a chance to install it on my ‘71 with VS exhaust. It was a 2 beer difficulty level-The hardest part was scraping off the 50 year old factory rustproofing (I put some POR15 on too) then cleaning it out of the bolt holes and tapping them. The hitch fits perfectly and is very sturdy and well finished. I have an 8’ utility trailer I occasionally pull, and was hoping to carry a small dirt bike on the back.
Thanks Jeremy for a great product and follow up. _________________ Billions of Bilious Blue Blistering Barnacles!
Last edited by CaptainHaddock on Mon May 19, 2025 8:58 am; edited 2 times in total |
richparker Samba Member
Joined: November 24, 2011 Posts: 7799 Location: Durango, CO
Posted: Sun May 18, 2025 6:45 am Post subject: Re: 1970 bus trailer hitch install |
^You might want to think about re-indexing your rear spring plates to carry that bike.
I’m 6 years in with my hitch from Jermery. It’s been great, I use it all the time. My Thule bike rack pretty much lives on it and when it’s not I’m towing my 1973 Allstate trailer. It was an excellent purchase! _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab |
Posted: Sun May 18, 2025 1:03 pm Post subject: Re: 1970 bus trailer hitch install |
I checked out a photo of your trailer Rich, pretty cool. It would only be very occasionally putting the bike on the back, so if I re-indexed the spring plates how would that affect the ride without the bike the rest of the time? _________________ Billions of Bilious Blue Blistering Barnacles!
Last edited by CaptainHaddock on Mon May 19, 2025 8:56 am; edited 1 time in total |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42975 Location: at the beach in Northern Wokistan
Posted: Sun May 18, 2025 1:13 pm Post subject: Re: 1970 bus trailer hitch install |
adding to what Rich already said, the rear shocks are held on by captive nuts that are welded into weak steel. They are near impossible to repair if they rip out. You do not want the rear shocks either bottoming or topping out in any situation, and you do not want any form of shocks or helper springs in the rear that increase the load on that captive nut. Most likely you will need to play with the rear torsion bar tension to find a happy medium.
I pulled a 2000 lb boat with my 1971. Not much power on grades etc., but it was possible. Even so that was only about 120 lbs tongue weight. I also pulled a small camping trailer than only put about 50 lbs tongue weight on the hitch. That motorcycle and carrier is a lot of weight hanging back there - the proverbial tail that wags the dog. You would be better off with a lite trailer for it where only the tongue weight was on the hitch. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Posted: Mon May 19, 2025 8:48 am Post subject: Re: 1970 bus trailer hitch install |
Thanks for the input guys, I just installed new rear sachs/boge shocks a few months ago. I’ll try it around town and see how it feels. If not I have a good utility trailer and the bus has a 1776 set up.
I just removed the dirt bike carrier pic as it leading to mission creep on the thread. There are a few threads on the carrier already, I just wanted to show the hitch mounting. Cheers _________________ Billions of Bilious Blue Blistering Barnacles! |
