peecee69 Samba Member
Joined: January 27, 2005 Posts: 1592 Location: Annapolis, MD/Bloomfield Hills, MI
Posted: Sat Dec 03, 2016 9:44 am Post subject: Slow moving resto of 66 DC |
I picked up a 66 DC a while ago (about 4 years now), but due to other obligations, I haven't been able to work on it at all. Some of my time is starting to free up, I'm going to get going on putting this old girl back on the road. Here's a picture of the day I got it:
It looks almost exactly the same today. Since I know it will need some major metal work that I can't handle right now (no welder, yet), I am starting with some of the more manageable bits. The first on my list is the front window frames. Problem already.
It looks like the hole was drilled in the screws and probably messed up the thread. Either way, neither screw will budge, even after two weeks of soaking with pb blaster and some heat occasionally. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3338 Location: N.E. Oklahoma
Posted: Sat Dec 03, 2016 11:04 am Post subject: Re: Slow moving resto of 66 DC |
... just think, it's appreciating, in value, just leaving it alone, till you get to it... you could let it sit another 10 years and sell... better than money in the bank... no rush _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Sat Dec 03, 2016 11:08 am Post subject: Re: Slow moving resto of 66 DC |
ZENVWDRIVER wrote: |
you could let it sit another 10 years and sell... better than money in the bank... no rush |
That would suck. I want to drive it! |
Posted: Mon Feb 06, 2017 7:20 pm Post subject: Re: Slow moving resto of 66 DC |
I'm trying to figure out how to straighten the rear area where it meets up with the engine breast tin. I was thinking about making a template out of wood and use that to bend the metal back into place, using that the the tin as a guide. Any suggestions how to bend down the bump on the right side?
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2529 Location: UK (South)
Posted: Tue Feb 07, 2017 6:26 am Post subject: Re: Slow moving resto of 66 DC |
peecee69 wrote: |
I'm trying to figure out how to straighten the rear area where it meets up with the engine breast tin. I was thinking about making a template out of wood and use that to bend the metal back into place, using that the the tin as a guide. Any suggestions how to bend down the bump on the right side? |
If you've got the woodworking skills a pair of templates forming half the curve over the bell housing should do it. Use the good side to get the shape and make an outer and innner template to sandwich the 'good' curve between. Flip them round for the bent side and use a series of clamps to squeeze the templates together. Work back and forth between the clamps to squeeze it evenly.
I did that on a smaller scale on a compound curve that formed the of the lip of the tailgate on a daily driver car a while back. Someone reversed in to it while the tailgate was closed and bent the lip in and under, but didn't break the paint. I was able to get it back perfectly using the above method.
I did something similar last year on the engine lid of my truck using a pair of 2 x 4 timbers, although the damage was more severe than the tailgate example, but it still got it straight enough to fit a new valance panel. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Thu Feb 16, 2017 10:56 am Post subject: Re: Slow moving resto of 66 DC |
During disassembly, I found that this "button" doesn't do anything. It doesn't move, and I'm having a heck of a time removing it. There are three wires connected to it, but the wiring in this truck is a mess. It doesn't seem like there is a switch or button like it in the wiring diagram, unless I'm missing it, which is entirely possible. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71513 Location: Phoenix 602
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25918 Location: Olympia Wash Rinse & Repeat
Posted: Thu Feb 16, 2017 11:41 am Post subject: Re: Slow moving resto of 66 DC |
Pop out frame will need nuts welded onto what is left of the screw heads.
Work on the stuff you can get to now like the engine body to engine tin, de-rust and epoxy cold galv primer, cut out rust areas that are totally toast, EG front floor. _________________ In Stereo, Where Available! |
Posted: Thu Aug 15, 2019 5:53 am Post subject: Re: Slow moving resto of 66 DC |
If it wasn't for the earth rotating, this DC wouldn't have moved for the last 4-5 years. Life got in the way (and continues to do so), but I've recently acquired a welder, a blaster, a blast cabinet, a trailer, and a few other tools. I've also married into a family with some experienced metal workers. My daughter took a picture of the DC loaded on the trailer last night, and it looks kind of surreal. Hopefully once I get it to Detroit, I'll be able to finally start working on it.
_________________ 1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
1966 Doublecab - Starting resto - https://www.thesamba.com/vw/forum/viewtopic.php?t=668518&highlight= |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1290 Location: Surprise, AZ
Posted: Thu Aug 15, 2019 6:50 am Post subject: Re: Slow moving resto of 66 DC |
peecee69 wrote: |
Although it gets in the way, Dr. Ian Malcolm said it best "Life, uh, finds a way." Any progress is still progress, and it sounds like you're picking up steam. Keep at it! _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
silkvw Samba Member
Posted: Thu Aug 15, 2019 6:59 pm Post subject: Re: Slow moving resto of 66 DC |
Even little by little adds up.
Perhaps your daughter will be your helper? _________________ '64 single cab Big Bend Bus Bash 2015 '16
'59 camper BBBB 2017 '18 '19 '20 '22 New Mexico
'70 Ghia........Bonneville,........TX Mile,........142 mph......(sold)
https://www.thesamba.com/vw/forum/viewtopic.php?t=641871&highlight= |
Posted: Thu May 28, 2020 6:17 pm Post subject: Re: Slow moving resto of 66 DC |
About 3 months ago, I pulled the original swing axle transmission. I had a local transmission shop look at rebuilding it. They told me it was not worth it, as the actual shell was cracked. Since I had an IRS already being built for my bug, I decided to reroute that to the DC.
Then I bought Wagenswest IRS setup, along with some type 1 trailing arms.
Got some 930 CVs, axles, 100mm forged stub axles, type 3 backing plates and drums for the rear.
Now I'm looking for the other "non-consumable" items in the mix.
Should I be looking for type 3 "spacers" or "oil slingers"? I think that's what the part is called that holds the backing plate to the trailing arm. I need the bolts and spreader bar (hoping to retain e-brake) also.
I think I can use the 45mm type 3 brake shoes and spring kit for the rest of the consumable items. _________________ 1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
Posted: Wed Feb 03, 2021 7:20 am Post subject: Re: Slow moving resto of 66 DC |
Quite possibly the slowest progressing resto on the samba. But, trying to move forward with whatever little progress I can document. Trying to save money for the downpayment on a house, while resisting the urge to sell the DC to finance it is tough.
I forgot to include the frames in the pictures, and noticed I haven't primed the vent window frames yet. I have some NOS vent wing latches, and trying to come up with the best way to install the rivets for them. I also removed the bent latch plates, so I need to figure out how to reinstall those things. I have the rivets for those as well, but there is little to no information on how the latch plate rivets are installed.
1970PAKombi Samba Member
Joined: July 10, 2019 Posts: 290 Location: Denver, PA
Posted: Tue Apr 06, 2021 11:27 am Post subject: Re: Slow moving resto of 66 DC |
I don't think it's the slowest progressing. Come check me out sometime haha. Keep us posted |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Tue Apr 06, 2021 12:54 pm Post subject: Re: Slow moving resto of 66 DC |
You messed up buddy, wrong logo
or maybe you haven't told us the whole story on your car fleet (don't get me wrong, I like that brand as well)  _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much!
Two Glove Boxes Samba Member
