Multi69s Samba Member
Joined: January 24, 2006 Posts: 5576 Location: Lefty, CA
Posted: Thu Feb 16, 2017 1:05 pm Post subject: alternator not charging, no idiot light |
I have a 1977 based type 4 engine in my square back. A couple of days ago, the alternator quit charging, and the idiot light does not come on with the key. Also, the alternator has an external regulator. I have the bus Bentley coming in the mail, but until it gets here, does anyone have any pointers that I can use to begin my trouble shooting? _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53181 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Feb 16, 2017 1:14 pm Post subject: Re: alternator not charging, no idiot light |
Ground the blue wire from the regulator to the front, if the light doesn't come on with the key on the problem is a bad bulb or the wiring in the dash. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 6041 Location: Brooklyn
Posted: Thu Feb 16, 2017 1:24 pm Post subject: Re: alternator not charging, no idiot light |
| Multi69s wrote: |
| I have a 1977 based type 4 engine in my square back. A couple of days ago, the alternator quit charging, and the idiot light does not come on with the key. Also, the alternator has an external regulator. I have the bus Bentley coming in the mail, but until it gets here, does anyone have any pointers that I can use to begin my trouble shooting? |
Idiot light needs to work for alternator to charge.
If idiot light burns out, alternator no chargey.
So do what busdaddy said and replace bulb if it's burned out. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2270 Location: Detroit, Michigan
Posted: Thu Feb 16, 2017 2:15 pm Post subject: Re: alternator not charging, no idiot light |
| sjbartnik wrote: |
| Multi69s wrote: |
So do what busdaddy said and replace bulb if it's burned out. |
This must have changed from 1970 then. My bus just got its generator light working (previously not even wired) and ive driven a few hundred miles without it. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Thu Feb 16, 2017 2:31 pm Post subject: Re: alternator not charging, no idiot light |
| Spike0180 wrote: |
This must have changed from 1970 then. My bus just got its generator light working (previously not even wired) and ive driven a few hundred miles without it. |
Ah grasshopper, but generators are not alternators!  _________________ 1965 Volkswagen 1500 Variant S
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4548 Location: viroqua wi.
Posted: Thu Feb 16, 2017 5:22 pm Post subject: Re: alternator not charging, no idiot light |
| You can drive a long time on battery only. But as far as the gen/alt light all is same. |
Posted: Thu Feb 16, 2017 6:51 pm Post subject: Re: alternator not charging, no idiot light |
Have a look through these: http://www.thesamba.com/vw/forum/search.php?search..._chars=200
I always start with a good close look at the connectors and wires, it's not uncommon for a wire to break inside the insulation yet still look fine outside, sometimes they also push back out of the plug when connecting. After the visual use an OHM meter to confirm each wire is doing it's thing, even while pulling and wiggling the plug at each end. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13621 Location: West Coast, USA
Posted: Fri Feb 17, 2017 5:29 pm Post subject: Re: alternator not charging, no idiot light |
| sjbartnik wrote: |
| Spike0180 wrote: |
Ah grasshopper, but generators are not alternators!  |
Check his signature: 1700 T4 in a '70 body. So it would be a gen light with an alternator.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
Posted: Fri Feb 17, 2017 8:46 pm Post subject: Re: alternator not charging, no idiot light |
It's kind of ironic, but there doesn't seem to be a good procedure anywhere for trouble shooting the regulator / Alternator. I've searched here, and my bus Bentley came in. The Bentley goes in depth on a generator, but it seems like the alternator was an after thought. I remembered that I had a Clymer 411/412 book. It does a great job on showing how to disassemble and test individual parts on the alternator, but nothing on determining whether the problem is the reg or alt in the first place. I refuse to spend $$$ chasing a problem. I am looking for any kind of procedure that will tell me which part of the charging system is causing the problem. _________________ 69 road Bug 2110
My builds
Posted: Fri Feb 17, 2017 9:19 pm Post subject: Re: alternator not charging, no idiot light |
Sadly there's not many tests you can do on a regulator without a full bench simulator, some old school electric shops may still have such a rig gathering dust back in the corner. There are tests for the alternator so you can rule it out and blame something else, aside from the wiring and the regulator there's not much else to blame once that's done. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
dawie Samba Member
Joined: July 27, 2008 Posts: 222 Location: Cape Town, South Africa
Posted: Fri Feb 17, 2017 11:41 pm Post subject: Re: alternator not charging, no idiot light |
| Check the slipring brushes as well. Test by measuring resistance between DF wire from alternator and earth. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3630 Location: San Diego (Encinitas)
Posted: Sat Feb 18, 2017 9:22 am Post subject: Re: alternator not charging, no idiot light |
You can quick-check the alternator for functionality with a quick rewire using some jumper wires. This is NOT a definitive test of the alternator, but will tell you if the regulator is the cause of the problem. Basically, we're going to remove the regulator from the circuit and run the alternator "wide open", varying the alternator output by varying engine speed. If your battery is good, this is safe for a short period of time. Note: I generally don't recommend doing this if you have FI, as FI can't take a joke.
Here's the stock alternator wiring:
What we're going to do is unplug the regulator and, using some jumper wires with blade terminals on their ends, connect the regulator wires as follows:
- D- wire to ground
- Df wire to D+
This will apply maximum rotor current to the alternator.
Connect a good voltmeter across the battery and start the engine. Watch the voltmeter carefully. Increase engine speed slowly. The battery voltage should increase. DO NOT allow it to rise to more than 14.4 volts, or 2500 rev/min max. If you can get the 14.4 volts, then the regulator is probably toast.
Note: for this test to work, the dash idiot light must illuminate when you first turn on the key, as it supplies the initial alternator activation current.
If you have access to a variable voltage power supply (or a "stupid' battery charger and a Variac), the regulator may be easily checked. Here's the test setup:
As you increase the power supply voltage, the test light will illuminate. As the voltage gets past somewhere around 13.8 to 14.4 volts, the light will suddenly go out. Decreasing the voltage will cause it to suddenly come back on. If it does this, the regulator is working. Note: if the regulator is a mechanical unit, don't let it run very long at the 'test light out" point, as it doesn't like it (the resistor on the bottom of the regulator will get quite hot). Ironically, the solid state regulators don't care. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1782 Location: New Brunswick,Canada
Posted: Fri Feb 24, 2017 11:44 am Post subject: Re: alternator not charging, no idiot light |
In this case, no.
- it would have to be one hell of a big rheostat. [You can do it easily with a small pot and a couple of transistors.]
- in this case, you need greater than battery voltage for the test.
Sorry. Good idea, but this time, no cigar... _________________ '71 panel, now with FI
Abscate Samba Member
Joined: October 05, 2014 Posts: 24365 Location: NYC/Upstate/ROW
Posted: Fri Feb 24, 2017 2:00 pm Post subject: Re: alternator not charging, no idiot light |
| telford dorr wrote: |
In this case, no.
Sorry. Good idea, but this time, no cigar... |
You just need the ubiquitous step-up rheostat.
You can also take the extra voltage and charge your battery with it.
 _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Posted: Wed Mar 01, 2017 12:21 pm Post subject: Re: alternator not charging, no idiot light |
- D- wire to ground
- Df wire to D+
As you increase the power supply voltage, the test light will illuminate. As the voltage gets past somewhere around 13.8 to 14.4 volts, the light will suddenly go out. Decreasing the voltage will cause it to suddenly come back on. If it does this, the regulator is working. Note: if the regulator is a mechanical unit, don't let it run very long at the 'test light out" point, as it doesn't like it (the resistor on the bottom of the regulator will get quite hot). Ironically, the solid state regulators don't care. |
Telford, a couple of questions.
When testing the regulator you show D- going through the regulator and back to common on the power supply. Is it supposed to ground through the body of the regulator? My regulator has no continuity between D- and the shell.
As for the alternator, the only way that I can get the dash light to illuminate is when I ground the blue wire. I checked the wiring and the signal from the blue wire is going to the D+ of the alternator.
This would lead me to believe that something in the alternator is not allowing the activation current to energies the alternator. Or am I way off base? _________________ 69 road Bug 2110
My builds
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3563 Location: Wyoming,USA
Posted: Wed Mar 01, 2017 12:34 pm Post subject: Re: alternator not charging, no idiot light |
| Abscate wrote: |
Commonly referred to as the Transfrheostormer. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
kooper271 Samba Member
Posted: Wed Mar 01, 2017 12:36 pm Post subject: Re: alternator not charging, no idiot light |
| Multi69s wrote: |
Yes, the regulator body should be grounded. Telford mentions that in page 1 of this thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=673255 |
