ignition coil exploded!
Page: 1, 2, 3, 4  Next
inorganic
inorganic is offline
PostPosted: Mon Oct 09, 2017 11:20 am    Post subject: ignition coil exploded! Reply with quote
hey there,
i was idling my engine to burn off that new rear-heater core smell and noticed a pile of hard plastic on the ground (queue van anxiety). i opened up the engine bay to find my ignition coil (~12months old) exploded out black goo.
has anyone else seen this? curious if it could be a sign of something else....not looking forward to cleaning this up. Evil or Very Mad
'86 SYNCRO Weekender
djkeev
djkeev is offline
PostPosted: Mon Oct 09, 2017 11:52 am    Post subject: Re: ignition coil exploded! Reply with quote
Oh Geez!!!
Now you're going to make me carry a coil aren't you?? Rolling Eyes
I think there's room for one more item.....
Dave
Ghia
Vanagon
Beetle
?Waldo?
?Waldo? is offline
PostPosted: Mon Oct 09, 2017 12:04 pm    Post subject: Re: ignition coil exploded! Reply with quote
inorganic wrote:
hey there,
You're not the first: https://www.thesamba.com/vw/forum/viewtopic.php?t=581079
I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site.
inorganic
PostPosted: Mon Oct 09, 2017 12:22 pm    Post subject: Re: ignition coil exploded! Reply with quote
thank you both for your replies!
?Waldo? - great article you posted here, my coil failed under similar conditions (extended idle).
Dave - I can identify most of those parts you carry, but not all. which ones do you have onboard?
DanHoug
DanHoug is offline
PostPosted: Mon Oct 09, 2017 4:47 pm    Post subject: Re: ignition coil exploded! Reply with quote
i've had non-VW coils fail also and they seemed to contain that same black death.
at an idle, the dwell time, meaing the time the coil has 12v applied to charge it, is at it's maximum. not in terms of degrees rotation as that doesn't change but in terms of time. obviously exceeded the duty cycle of the coil, which is a bit scary that the margin of safety is that close.
old points systems had a ballast resistor that was bypassed during cranking (direct feed off the crank pole on the ignition switch)for hottest spark and put in the coil circuit during running. modern ECUs control that 'on time' but it looks like the early electronic systems we have don't. very good to know!
my old airhead BMW can do the same thing to coils with extended idling or key on time. they modified the ignition control module (not quite a computer) in later years to have a timer circuit to turn off voltage to the coil.
i've idled my van for really long periods of time dorking with the cooling or ignition systems. i'm going to reach over and touch the coil periodically now, or maybe it is an excuse for another gauge!
-dan
djkeev
djkeev is offline
PostPosted: Mon Oct 09, 2017 5:10 pm    Post subject: Re: ignition coil exploded! Reply with quote
Maybe it's a German form of the proverbial "Lucas electric smoke" escaping?
Lucas, the British prince of darkness........
Dave
Ghia
Vanagon
Beetle
Gruppe B
Gruppe B is offline
PostPosted: Mon Oct 09, 2017 5:15 pm    Post subject: Re: ignition coil exploded! Reply with quote
djkeev wrote:
Oh Geez!!!
Dave
Where is your alternator voltage regulator? Very Happy
fraggle00
fraggle00 is offline
PostPosted: Mon Oct 09, 2017 6:31 pm    Post subject: Re: ignition coil exploded! Reply with quote
Yikes! I wouldn't touch test it I found this is the result of a failure. Temp gun! I keep a little one for RC nitro cars in my van to check temps on things, especially helpful when my motor was acting up before I rebuilt it.
'91 Vanagon Carat
'87 Porsche 928S4 DOWN
'12 Fiat 500 Abarth
tencentlife
tencentlife is offline
PostPosted: Mon Oct 09, 2017 7:28 pm    Post subject: Re: ignition coil exploded! Reply with quote
It's not that close, the Digifant ECU lowers dwell time at lower rpms, or maybe more correctly, the term dwell as a function of crankshaft degrees is obsolete, the ECU now just uses a time function, whatever time it takes to saturate the primary and no more. This allows use of higher-current coils without overheating them. This can of course be measured with a dwellmeter and it will look like a varying dwell angle.
Dwell was fixed mechanical relationship which required coil power to always be a compromise, as soon as engineers had electronic control of saturation time, of course they would use that advantage to use a higher-current coil. It's the natural progression of design.
If all you do with your axe is grind it, you'll just end up with a piece of hickory. Better throw it on the fire, cuz no wood's gettin' chopped!
Experience is death to doctrine.
Gauche1968
Gauche1968 is offline
PostPosted: Mon Oct 09, 2017 7:51 pm    Post subject: Re: ignition coil exploded! Reply with quote
Yeah, that happened to me (but worse) at 65 MPH in the left lane of the interstate. I had to coast across three lanes to stop. I don't know if these Bosch Made in Brazil coils are top notch quality.
1984 Vanagon GL
1984 Vanagon Westy
dobryan Premium Member
dobryan is offline
PostPosted: Mon Oct 09, 2017 9:43 pm    Post subject: Re: ignition coil exploded! Reply with quote
Bosch has had QC issues a lot lately....
Dave O
The Western Syncro build
pinetreeporsche
pinetreeporsche is offline
PostPosted: Tue Oct 10, 2017 8:21 am    Post subject: Re: ignition coil exploded! Reply with quote
fraggle00 wrote:
Yikes! I wouldn't touch test it I found this is the result of a failure. Temp gun! I keep a little one for RC nitro cars in my van to check temps on things....
Great strategy; I looked on the web and must have entered the wrong phrases, didn't find one. Can you give the mfgr and model no. for one (or more) of these.
teej
teej is offline
PostPosted: Mon Oct 17, 2022 1:02 pm    Post subject: Re: ignition coil exploded! Reply with quote
I looked in the engine bay today and discovered this. Last drove it Saturday morning, ambient temps in the 50s, a couple easy 45minute runs on rolling secondary highways speeds 35-55 and no extended idling. No running issues. Did not try to start after seeing this. Coil is Bosch, installed in 2015, 21k miles on it. I saved the old one will put it back in. Is there anything else I should check that might have caused this without giving any running symptoms?
*Edit: I just remembered a couple weeks ago, Sept. 29, I was in a 1.5 hour stop and go traffic jam east of Snoqualmie pass, so yes extended idling, in and out of first gear, crawling along with no airflow, rad fan cycled alot. But no running issues then or several runs since, but maybe this melt happened at that time as I don't think I've been in the engine bay since. If that is the case, surprised that it continued to start and run well.
1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Mon Oct 17, 2022 2:04 pm    Post subject: Re: ignition coil exploded! Reply with quote
Just questioned how my coil failed recently in another thread, so there is a way to lower the voltage, and possibly the temps of the coil, here is the quoted text of that thread.
bobbyblack wrote:
I recently had a coil go bad, and decided I wanted to know a little more about how these things work.
Here is a youtube of a crafty tech. that helps me understand what might be happening. I am not saying this is what happened to my coil, but if it is happening, I sure would want to know about it sooner rather than later.
I don't have access to the kind of equipment that this guy does, so I'd rather like to know how a general knowledge guy like myself could determine if I am getting multi-strike, having too much voltage running into the coil, all that sort of stuff without taking it in for an analysis by a scanner like that.
Is this a 'touch it after its been running a while' kind of thing? If its frickin hot, then put more ballast in the positive side (after letting it get full voltage on the start circuit like in the below explanation of what a ballast resistor is)?
VeeDubDaySpa
VeeDubDaySpa is offline
PostPosted: Mon Oct 17, 2022 3:05 pm    Post subject: Re: ignition coil exploded! Reply with quote
I have dealt with this on a van that blew numerous coils and found the ECU to be faulty. Also, was told that that black stuff is extremely poisonous and carcinogenic so be safe.
North American Hightop Installer/Distributor
Current stock (3)
Hot Water Systems
90 Syncro NAHT Vanagon RHINO
86 "Syncro" Van DIAMOND
87 Syncro Hightop WestyCamper ROCKY (for sale soon)
79 bay window OLIVER
teej
teej is offline
PostPosted: Mon Oct 17, 2022 3:11 pm    Post subject: Re: ignition coil exploded! Reply with quote
thanks bobbyblack for the links, I have seen the first one before but my understanding of all that is incomplete. Thx for the safety tip VeeDub.
I just put the old coil (removed in 2015) back in and it runs fine. I will continue to run and monitor for heat.
My theory at this point is that the coil got hot in that extended stop and go a couple weeks back, melted some and leaked, but did not fail completely. And has been running ok since. If so, I am feeling grateful that the traffic jam cleared when it did before the coil blew up and left me stranded in the middle of a big traffic mess on I90, making it that much worse, plus I had a dog with me in the van. In hindsight, when I got to camp afterwards that evening, when I sniffed the back louvers there was an additional scent note to the normal nice hot engine smell, but it was faint, I couldn't place it, and I ignored it. Should have trusted my nose and investigated further!
GoEverywhere
GoEverywhere is offline
PostPosted: Mon Oct 17, 2022 3:57 pm    Post subject: Re: ignition coil exploded! Reply with quote
A lot of coils are oil filled, thats what you see leaking out... I've had coils rupture on other non VW stuff and get that junk all over the place. Time for a new coil.
khughes
khughes is offline
PostPosted: Mon Oct 17, 2022 4:19 pm    Post subject: Re: ignition coil exploded! Reply with quote
The coils (inside *the* coil) and the oil expand when heated, and that's when they normally will short, or go open circuit. And most all transformer oil I've used over the years has been pretty carcinogenic/mutagenic stuff. Used to have to replace the oil in the custom built transformers for a high voltage leak detection piece of equipment (25-30KV). I know NOW how toxic it was...this was 35+ years ago.
'86 Westy FAS GenV Turbo (Marvin)
teej
teej is offline
PostPosted: Mon Oct 17, 2022 4:46 pm    Post subject: Re: ignition coil exploded! Reply with quote
The usual vendors I go to (VC, GW) are sold out at the moment, glad I saved the old but still working one to use for now. Bus depot has in stock but do not state the manufacturer, so I will hold off buying from them until I learn what it is they are selling.
DanHoug
DanHoug is offline
PostPosted: Mon Oct 17, 2022 5:37 pm    Post subject: Re: ignition coil exploded! Reply with quote
right. true nasty gene-mutating dioxins. same as in old capacitors. but it is my belief that the Bosch coils are just filled with a bituminus resin, no worse than creosote <grin>.
-dan
www.thefixitworkshop.com
Page 1 of 4
