Third brake light
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
c21darrel
c21darrel is offline
PostPosted: Fri Jun 05, 2015 11:57 am    Post subject: Reply with quote
I have the metal tray...it is actually open at the front (front of car). Its pretty easy. Get your fingers up there and feel around. Clean everything really well if you want the tape to stick. I have a couple years and 3000 or so trouble free miles.
GhiaBuild
1967 DC build
asbug
asbug is offline
PostPosted: Fri Jun 05, 2015 12:39 pm    Post subject: Reply with quote
San Dimas?
Bill and Ted's excellent adventure...
1969 Ghia Vert - Jenny.
2004 B5.5 Passat Wagon - no name yet.
2012 Routan - Urban Assault Vehicle.
c21darrel
PostPosted: Fri Jun 05, 2015 3:31 pm    Post subject: Reply with quote
Very Happy Very Happy Very Happy
Exactly Dude Cool
GhiaBuild
1967 DC build
akear
akear is offline
PostPosted: Fri Jun 05, 2015 3:44 pm    Post subject: Reply with quote
Northof49 wrote:
I tried the double sided tape that came with a led strip in my engine compartment. It got too hot, the tap fell off, and the led strip got slightly abraded by my fan.
The tape that came with the strip failed on me too. I reattached with 3m double sided tape for auto trim (bought at Autozone). That stuff is strong!
DanUK
DanUK is offline
PostPosted: Tue Jun 09, 2015 4:51 am    Post subject: Reply with quote
asbug wrote:
How are all you early Ghia owners getting these into the solid steel rain trays?
I cannot figure out how to get them into my '69 Vert.
I have a couple openings (small) on the inside of the lid. Mine is a 1959, but I think the deck lid is slightly later. It was pretty awkward. I used sand paper and a vaccuum to make sure the surface was ready/clean.. placed the strip & used clothes pins to position it in a few small vent holes inside (being careful to make sure I had the wires routed properly to the brake lamps to get the signal!).. then removed the first inch or so of the tape backing and carefully peeled & stuck it down as I moved along the strip. I gave it a good rub into position to make sure it was properly stuck down, covering my hands and fingers in little cuts and indentations in the process
Back to the original question- I propped the deck lid open just enough to get a hand under so I could watch from the top, and had to work through a few vent slots on the inside right where the deck lid shuts near the convertible top
Angus Dowrie
Angus Dowrie is offline
PostPosted: Thu Mar 09, 2017 3:21 am    Post subject: Re: Third brake light Reply with quote
Old post, but I have just mounted this at the bottom of my rear window. Wiring through the rear demister vent and double sided tape of the light to the glass means no extra holes.
It is slightly longer than the rear vent by about 20mm. The LED bulb can be rotated to suit the angle of the screen. I've got it mounted but forgot to take a photo of it. Will take one next time I'm there with it wired up. The 'box' minimises any reflection off the glass.
1963 Australian Delivery RHD Coupe
Build thread;
http://www.thesamba.com/vw/forum/viewtopic.php?t=610414
Angus Dowrie
PostPosted: Fri Mar 10, 2017 1:54 pm    Post subject: Re: Third brake light Reply with quote
Here is it installed, Narva part No 84650BL.
Build thread;
h~moto
h~moto is offline
PostPosted: Fri Mar 10, 2017 4:04 pm    Post subject: Re: Third brake light Reply with quote
I put a third brake light at the bottom of the back window inside my `66 Beetle. I used a Hella bumper mounted reverse light. I replaced the clear lens with a reproduction 1957 and older type II brake light lens. I think this setup would work well for a Karmann Ghia.
slalombuggy
slalombuggy is offline
PostPosted: Sun Mar 12, 2017 4:55 pm    Post subject: Re: Third brake light Reply with quote
Does the lens require modification or did it drop right in?
brad
h~moto
h~moto is offline
PostPosted: Sun Mar 12, 2017 8:26 pm    Post subject: Re: Third brake light Reply with quote
Fits right in.
carguy4
carguy4 is offline
PostPosted: Mon May 08, 2017 11:35 am    Post subject: Reply with quote
Do you have to remove the rain tray for this type of install?
Thanks in advance.
Doing the spring clean-up, thought illustrating the method would be useful to others - this basically makes the 3rd brake light a "separable" task without too many contingencies on clean surfaces, etc. We attached the lights to some vinyl weatherstripping, and then attached that to the upper screw positions in the rain tray. Basic idea:
Looks like this from back (lights off):
(Please excuse poor phone pic colors)
And then, what it looks like in real life:
(Again, excuse phone pic... We also later found out that tail-lights & brake-lights were reversed in harness wires, but you get the idea...)[/quote]
Looks good! That stretch of roadway looks like Baron Cameron Parkway near Lake Anne Center in Reston, VA.[/quote]
e&m_ghia
e&m_ghia is offline
PostPosted: Mon May 08, 2017 5:52 pm    Post subject: Re: Third brake light Reply with quote
Thanks in advance.
We didn't remove the rain tray, we used the existing screws to find the screw-holes in the shadows. We did it as a 2 person job - one with clever, nimble fingers (E).
The rain trays in the late Ghia's are only held in by a few screws, so it's not a big deal to remove. (Our Ghia didn't come with it, but it was an easy purchase & install.)
Figment
Figment is offline
PostPosted: Sun Oct 15, 2017 4:57 pm    Post subject: Re: Third brake light Reply with quote
I plan to spend a fair amount of time with a loaded decklid rack, so I put mine up high.
L-61 unit from Watson's. I discarded their pedestal mount and made that little bracket to get it up tighter to the top of the window. Yeah, I know that bracket is going to put a little mooseknuckle in the headliner, but I can live with that.
Turn signals too! Smile
'71 Ghia coupe
c.j.
c.j. is offline
PostPosted: Thu Nov 02, 2017 3:48 pm    Post subject: Re: Third brake light Reply with quote
Instead of splicing into the the wires I hooked up my brake light by using a double spade on the brake light bulb and ran the ground wire to the negative side of the coil. It works.
SBD
SBD is offline
PostPosted: Thu Nov 02, 2017 7:20 pm    Post subject: Re: Third brake light Reply with quote
Think But wouldn't that only work when the points were closed,,, er open,,, uh, how would that work? Confused
"Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote:
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it.
sputnick60
sputnick60 is offline
PostPosted: Fri Nov 03, 2017 3:07 pm    Post subject: Re: Third brake light Reply with quote
I too was wondering about that. The brakes are usually operating with a running engine and wired as described he has a switched earth via the points. The earth is subject to engine speed and dwell angle. Hardly ideal.
There are plenty of earth points nearby, for example on the generator where you can find a nice 4mm threaded hole just askiing for a spade lug.
LEDs are more responsive than filament lights so that might be why SBD has enough light to make him happy with his work methods.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
c.j.
c.j. is offline
PostPosted: Fri Nov 03, 2017 4:59 pm    Post subject: Re: Third brake light Reply with quote
Ran the ground to the body.
Steelz21
Steelz21 is offline
PostPosted: Mon Oct 19, 2020 4:20 pm    Post subject: Re: Third brake light Reply with quote
Great idea, safety first.
rbsurfguy
Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
rbsurfguy is offline
PostPosted: Mon Oct 19, 2020 4:27 pm    Post subject: Re: Third brake light Reply with quote
Looks Great, what brand and size did you use?
Jeff
1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
udo dreisoerner
udo dreisoerner is offline
PostPosted: Tue Oct 20, 2020 12:24 am    Post subject: Re: Third brake light Reply with quote
here my tird brake light. it is an aftermarket brake light from the 80's
Searching for a 1956 lowlight karmann ghia with a VIN number between1273054 and 1273440, and the matching engine with an Engine Number between
1525510 and 1525519 PLEASE OFFER ME ONLY THE CARS THAT I'M LOOKING FOR, THANKS!!
Page 6 of 7
