pilottangocharlie Samba Member
Joined: February 24, 2017 Posts: 86 Location: Newcastle, OK
Posted: Wed Nov 01, 2017 10:36 am Post subject: My First Beetle Project- 1964 |
Hi guys/gals. I've been lurking here for a short time and picked up my first project. It's a 1964 Beetle that is in pretty good shape and will be the recipient of some TLC. My efforts will be focused on getting the car back to how it was when it left the factory.
The car was built in August of 1963 as serial 5748732.
Last edited by pilottangocharlie on Wed Nov 01, 2017 5:05 pm; edited 1 time in total |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35900 Location: Conejo Valley, CA
Posted: Wed Nov 01, 2017 11:39 am Post subject: Re: My First Beetle Project- 1964 |
Welcome! Post more pics, please!
Looks like it's sitting very high. Does it have a motor in it? Does it have an adjustable front end? |
Posted: Wed Nov 01, 2017 11:56 am Post subject: Re: My First Beetle Project- 1964 |
It does have a motor in it. I did notice it has had coil over shocks installed. I'm guessing that may be why it is sitting tall. I will also be looking for a buyer for this engine as I will be putting a 1200 back in.
I'll post more pics to keep the thread lively.
I'm looking forward to becoming part of the community here.
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2338 Location: Cleveland, OH
Posted: Wed Nov 01, 2017 12:01 pm Post subject: Re: My First Beetle Project- 1964 |
Nice car. Keep the pics coming.
Don't drive the car much with the engine in it's current condition. You're missing the engine seal and added to the chrome tin, you're cooking that engine with all the heat. _________________ 1971 Super - Sold
1984 Puma GTC - Sold
1971 Campmobile |
KTPhil  Samba Member
Posted: Wed Nov 01, 2017 12:02 pm Post subject: Re: My First Beetle Project- 1964 |
Engine and bay needs a bit of work!
Those chrome tins mean you have no heater, and generally rust and fit poorly. Looks like you have a header system, probably no heater boxes. Stock tins and heat exchangers will work out well if you can find them cheap in the classifieds.
That power pulley will make it run hot (slower fan), and the lack of engine bay seals will make that worse.
I'd look for a stock air cleaner as well, for many reasons.
But first, do a compression test and check oil pressure and screen to size up the motor condition, before worrying about all the accessories. If your engine is toast, a complete used running motor may be a better bargain.
Coil overs are unnecessary in a Bug and can break shock mounts. I wonder why the PO installed them? |
raycer60 Samba Member
Joined: January 15, 2013 Posts: 167 Location: H Town Texas
Posted: Wed Nov 01, 2017 12:29 pm Post subject: Re: My First Beetle Project- 1964 |
Car looks nice! Maybe the PO was going for the "rally" look?
Looking at the positive: no fuel filter in the engine compartment...or at least I can't see one.
Enjoy your build! _________________ 59 De Luxe Sedan with grafted ragtop |
Posted: Wed Nov 01, 2017 4:55 pm Post subject: Re: My First Beetle Project- 1964 |
Thanks for the welcome!
The car will be in tear down stage shortly and that engine will not be driving in this car. I'll pull the engine off the chassis once the body is lifted off.
If anyone has a lead on a 1200 case/engine around number 79XXXXXX I am looking for one to use to build the next engine for this car.
I'm trying to verify the current body to make sure it is in the right configuration. I believe the patches (pictured) that are above the front bumper mount holes were used to block off the bumper support (overrides bar?) holes. Besides that and some evidence of minor rear apron damage repair the body is in great shape. The pillars, pans, and heater channel are solid.
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1479 Location: Richmond, VA
Posted: Thu Nov 02, 2017 8:00 am Post subject: Re: My First Beetle Project- 1964 |
I think you're right about that weird patch. Looks like they covered the overrider support hole from the backside and smeared some Bondo over the front. Too bad it looks like they pop riveted the patch piece in, so now you'll have extra holes to fill. _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
1966 Beetle: My new project. (SOLD) Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040 |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2135 Location: Perry, GA
Mr. Mike Samba Member
Joined: January 30, 2015 Posts: 520 Location: Shoreline, WA
Posted: Thu Nov 02, 2017 6:33 pm Post subject: Re: My First Beetle Project- 1964 |
Dang! The seller of the 40hp case is super close to me too.
I made a little progress this evening pulling some of the interior out to get a good look at what lies beneath. The luggage tray looks pretty good.
Posted: Fri Nov 03, 2017 6:41 am Post subject: Re: My First Beetle Project- 1964 |
pilottangocharlie wrote: |
If anyone has a lead on a 1200 case/engine around number 79XXXXXX I am looking for one to use to build the next engine for this car. |
I have an 81XXXXXX number on the 40hp engine I will use on my build while rebuilding the original 36hp that came in my car. _________________ 59 De Luxe Sedan with grafted ragtop |
Posted: Fri Nov 03, 2017 10:45 am Post subject: Re: My First Beetle Project- 1964 |
Interior removal continues today with a day off from simulator training at the real job.
Channels and the rest of the body appears to be all original metal. I did find one small hole where the passenger side "Y" joins the heater channel under the rear seat.
I'm sure someone knows, but is the angle that is on the forward passenger floor board supposed to lie there freely or were they originally attached somehow?
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8850 Location: Sunset, Louisiana
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Sat Nov 04, 2017 10:48 am Post subject: Re: My First Beetle Project- 1964 |
Looks like the previous owner may have been a roofer ...evidence left behind is that galvanized flattened roofing metal patch on the rear fender. If nothing else, we VW folks are resourceful ... LOL Nice looking bug!! _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Posted: Sat Nov 04, 2017 2:36 pm Post subject: Re: My First Beetle Project- 1964 |
Digger89L wrote: |
Looks like the previous owner may have been a roofer ...evidence left behind is that galvanized flattened roofing metal patch on the rear fender. If nothing else, we VW folks are resourceful ... LOL Nice looking bug!! |
Funny you mention that because I found a few self tapping metal roof screws holding a running board on! |
Posted: Wed Nov 22, 2017 4:44 pm Post subject: 1964 Beetle Update |
During a visit with family in Oklahoma I picked up a few parts that were listed nearby that I will need for the project. I found an original oil bath in decent condition. The top has a pretty big dent in it so I am on the hunt for a better top. I also picked up a few rebuildable Pierburg fuel pumps, a 6V generator/fan, and an original shroud with flaps.
A local VW guy had a rebuild kit so I built the assembly jig and worked on putting one of the pumps back together after a thorough cleaning. The kit didn't come with a new screen so I ordered a screen/gasket set from Doug, 56 Beetle. The pump won't look as nice as the more expensive rebuilds that are available, but it should do the trick. I am contemplating getting the cover and screws re-plated to look a little nicer, but the not-so-perfect look has some appeal to me.
The 1300 came out of the car today as a local buyer is coming to pick it up tomorrow morning.
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Nov 22, 2017 5:11 pm Post subject: Re: My First Beetle Project- 1964 |
I bet the removable apron sure makes engine removal pretty easy. The car looks pretty solid except where you found the hole. Looks like tar? around it? I'd scrape it off to see how it looks underneath. |
rcroane  Samba Member
Joined: January 03, 2013 Posts: 2015 Location: Springfield, Virginia
Posted: Wed Nov 22, 2017 5:57 pm Post subject: Re: My First Beetle Project- 1964 |
Quote: |
A local VW guy had a rebuild kit so I built the assembly jig and worked on putting one of the pumps back together after a thorough cleaning. |
Be sure to check your pump pressure. Most rebuild kits available today are notorious for producing too much pressure because of the main spring. Best to use an original spring. _________________ '65 Sunroof Bug |
Posted: Thu Nov 23, 2017 3:25 pm Post subject: Re: My First Beetle Project- 1964 |
I'm thinking pilottangocharlie HAS to be a bachelor ....no wife would put up with abusing decent towels like those in the pics !! lol _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
