New engine build by ladies
Page: 1, 2, 3 ... 27, 28, 29  Next
Joannekay
Joannekay is offline
PostPosted: Wed Dec 13, 2017 4:25 am    Post subject: New engine build by ladies Reply with quote
Sharp64
Sharp64 is offline
PostPosted: Wed Dec 13, 2017 4:43 am    Post subject: Re: New engine build by ladies Reply with quote
If I’m not mistaken your #4 rod is upside down. Hopefully this was corrected before assembly.
1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
Joannekay
PostPosted: Wed Dec 13, 2017 5:04 am    Post subject: Re: New engine build by ladies Reply with quote
Yes..fixed b4 case closed..thank u..
Sharp64
Sharp64 is offline
PostPosted: Wed Dec 13, 2017 5:13 am    Post subject: Re: New engine build by ladies Reply with quote
Out of curiosity, what all did you do? What size was it originally? Did you rebuild it to factory or increase displacement? Did you rebuild the heads or just clean them up and put them back on? In the circled area it appears you are missing the plate that belongs there. Helps cool the heads. I also don't believe you're supposed to use sealant between the jugs and the case. What condition was the case? Were the align bore or thrust out of spec?
Also, looks like the crankshaft pulley may be smaller and result in the fan turning slower and increase temperatures. Did you rebuild any of the components or just buy new? Looks like you put an aftermarker SVDA on, what are your plans for carburation? Some of the OG carbs don't play well with the SVDA as the vac signal is incorrect. You may be better off cleaning up the OG distributor and carb and using those. Check the fuel pressure on that fuel pump. A lot of the aftermarket ones put out too much pressure. Again, you may have been better off cleaning up and using the old one instead of spending money on new. More information on what all you did would be great if you're looking for input. If you're not we can all bugger off.
1967 Ghia
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Wed Dec 13, 2017 5:23 am    Post subject: Re: New engine build by ladies Reply with quote
Most of the women mechanics I’ve worked with over the years have done better than the men. They take time double check and are detail oriented, especially in metal working or that which requires a good eye.
Sharp64
Sharp64 is offline
PostPosted: Wed Dec 13, 2017 5:30 am    Post subject: Re: New engine build by ladies Reply with quote
I don't doubt it at all. I'm impressed that they tackled this as I'm still looking at my stack of parts trying to get the courage to jump in.
1967 Ghia
Joannekay
PostPosted: Wed Dec 13, 2017 5:31 am    Post subject: Re: New engine build by ladies Reply with quote
Thanks guys 4 comments.
We bought all new parts.same size case.1600 standard..happy 4 comments.
Joannekay
PostPosted: Wed Dec 13, 2017 5:34 am    Post subject: Re: New engine build by ladies Reply with quote
The extra fin on heads was in the way of thermostat rod..we filled it for 5 hours careful not to bend rod..heads new ..bad aftermarket..
Sharp64
Sharp64 is offline
PostPosted: Wed Dec 13, 2017 5:39 am    Post subject: Re: New engine build by ladies Reply with quote
Seriously, you may have been better off rebuilding components and saving the cash. May be worth your time to muddle through the rest of my comments and check some things.
Here's a good article and diagram of all the tin that you should have:
http://www.vw-resource.com/engine_tin.html
1967 Ghia
Joannekay
PostPosted: Wed Dec 13, 2017 5:50 am    Post subject: Re: New engine build by ladies Reply with quote
Joannekay
PostPosted: Wed Dec 13, 2017 5:54 am    Post subject: Re: New engine build by ladies Reply with quote
Sharp I’m not sure what u are saying..we decided 2 purchase all new & build..hard 2 check if crankshaft is balanced..case had small cracks..heads had done there time..thank u 4 comments but I don’t find them helpful .
Sharp64
Sharp64 is offline
PostPosted: Wed Dec 13, 2017 6:02 am    Post subject: Re: New engine build by ladies Reply with quote
bugger off it is then. Good luck.
1967 Ghia
lovethatconvertible
lovethatconvertible is offline
PostPosted: Wed Dec 13, 2017 6:40 am    Post subject: Re: New engine build by ladies Reply with quote
Nice work going on in your shop. Please keep an eye on that new style thermostat, I've heard and read they can be sketchy at best. Keep the pic's coming
1960 Convertible
bluebus86
Banned
bluebus86 is offline
PostPosted: Wed Dec 13, 2017 7:00 am    Post subject: Re: New engine build by ladies Reply with quote
new style wax thermostats are known to fail with flaps closed. original types fail with flapsnopen. which do you want??? the new types only have to fail once to ruin the motor. source a good used orignal type.
see link below on safety wires and engine fires.
good luck, Bug On!
gt1953
gt1953 is offline
PostPosted: Wed Dec 13, 2017 7:03 am    Post subject: Re: New engine build by ladies Reply with quote
As mentioned Looks nice and clean assembly...Do source out a stock thermostat.
72 type 1
72 Squareback
PostPosted: Wed Dec 13, 2017 7:10 am    Post subject: Re: New engine build by ladies Reply with quote
I think he was trying to say it’s standard operating procedure to measure the parts for tolerance and wear, that and a little non destructive testing will tell you if parts are serviceable.
This may be hard to do if you don’t have the measuring equipment and experience and know what to look for. This is where a machine shop comes in.
The crank may have just needed polishing and they don’t go out of balance with use. They are either balanced or within spec from the seller, or maybe not it’s up to you to check. In fact it only gets slight mention but it’s a great idea to take all the rotating parts in for balance prior to assembly, you can exceed factory specs for a really smooth long lasting engine with a little effort here.
Looking at your pic make real sure that tarboard is secure, it would be a real shame to suck that into the fan and cook a new engine. Have fun and congrats on tackling that project. Few here know the feeling of DIY. Very Happy
Cusser
Cusser is offline
PostPosted: Wed Dec 13, 2017 7:29 am    Post subject: Re: New engine build by ladies Reply with quote
I'm pretty impressed.
Looks like you stayed with non-doghouse, and used the Brosol Solex 30/31 PICT carb. I use that carb on my 1600cc engine, and have been OK with it.
Sharp64
Sharp64 is offline
PostPosted: Wed Dec 13, 2017 8:24 am    Post subject: Re: New engine build by ladies Reply with quote
But what distributor are you running it with?
1967 Ghia
flyboy161
flyboy161 is offline
PostPosted: Wed Dec 13, 2017 8:30 am    Post subject: Re: New engine build by ladies Reply with quote
Looks like you're doing a great job! Keep the pics coming
1968 Westfalia
https://www.thesamba.com/vw/forum/viewtopic.php?t=792825&highlight=
My father's 1970 Beetle-
http://www.thesamba.com/vw/forum/viewtopic.php?t=603879
The 1964...Diamond in the rough
http://www.thesamba.com/vw/forum/viewtopic.php?t=612776
My 1958 Morocco Bug-
http://www.thesamba.com/vw/forum/viewtopic.php?t=611483
heimlich Premium Member
VWNOS.com
heimlich is online now
PostPosted: Wed Dec 13, 2017 11:38 am    Post subject: Re: New engine build by ladies Reply with quote
Good stuff. I'm always trying to get my wife involved.
Page 1 of 29
