GERMANAIRE Samba Member
Joined: August 25, 2007 Posts: 782 Location: BUFORD,GA.
Posted: Sun Jan 28, 2018 6:11 pm Post subject: Re: Original Engine Traders Thread |
Well thought I would post this Engine up here. Seems to fall between
April and May of 1959. I took this engine out of a 53 Zwitter I had which was incorrect and has just been sitting under my work bench for several years in case something comes up
Douglas Denlinger Samba Member
Joined: May 23, 2003 Posts: 1404 Location: Arizona's version of the east coast
Posted: Tue Jan 30, 2018 4:21 am Post subject: Re: Original Engine Traders Thread |
Would like to find for a 60...... 5 073 407 thru 5 157 563.
Thanks any help GREATLY appreciated!! _________________ Transporter Restorations
Upholstery Haus
Active 23 Window Samba Collector/Restorer,since 1986 |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 24081 Location: NYC/Upstate/ROW
Posted: Tue Jan 30, 2018 7:38 am Post subject: Re: Original Engine Traders Thread |
Be careful buying any motor represented by serial number..the file of engines and VINS is not secure, so if someone has laid there hands On it itβs easy to make an engine to a number spec.
Verify parts, progressive refinements etc. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
mdege Samba Member
Joined: January 16, 2018 Posts: 1071 Location: Niederkruechten, Germany
Posted: Wed Jan 31, 2018 1:43 am Post subject: Re: Original Engine Traders Thread |
Just a short note on re-stamping. To give you an insight why VW used to re-stamp replacement engines.
In Germany the shops were required to re-stamp the cases before engine codes were introduced, because that was the only way for the inspection guys to tell if the right engine was installed in the car.
These days all you need is the correct engine code on the case.
Any change of engine to a different engine type must be recorded. The engine size, hp and emission standard have influence on the taxes and the insurance premiums you pay. _________________ - Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
1984 Standard: My son wanted a bug for his first car |
Thompson2 Samba Member
Joined: June 06, 2018 Posts: 660 Location: Portland, OR
Posted: Thu Sep 06, 2018 10:15 am Post subject: Looking for a specific engine. |
My '63 Bus was originally titled using the engine number instead of the chassis number. I know it's a super long shot, but since I have the info, I thought it would be cool to see if I can find the original engine (or at least the case).
Anyone happen to have engine number 0243487 lying around?
Thanks! |
Posted: Thu Sep 06, 2018 12:37 pm Post subject: Re: Looking for a specific engine. |
Thompson2 wrote: |
Thanks! |
Someone will soon.
