Current stock muffler options?
oibovveroi
oibovveroi is offline
PostPosted: Thu Aug 02, 2018 10:32 am    Post subject: Current stock muffler options? Reply with quote
Are the ill fitting dansk the best stock option? That’s about all I’m seeing at the usual online parts supply.
vwoldbug
vwoldbug is offline
PostPosted: Thu Aug 02, 2018 12:52 pm    Post subject: Re: Current stock muffler options? Reply with quote
There is a NOS Leistritz made in W. Germany in the classifieds to check on .
oibovveroi
PostPosted: Thu Aug 02, 2018 1:36 pm    Post subject: Re: Current stock muffler options? Reply with quote
The 40hp exhaust is compatible to the 1600DP?
Please excuse my ignorance
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Thu Aug 02, 2018 1:48 pm    Post subject: Re: Current stock muffler options? Reply with quote
no, 40 HP are narrower.
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
hanksjim1
hanksjim1 is offline
PostPosted: Thu Aug 02, 2018 3:27 pm    Post subject: Re: Current stock muffler options? Reply with quote
The Leistritz come up regularly on ebay for ~$100. I bought several.
bluebus86
Banned
bluebus86 is offline
PostPosted: Thu Aug 02, 2018 9:16 pm    Post subject: Re: Current stock muffler options? Reply with quote
Ill fitting is a very bad option, an old used correct fitting one is better. dont settle for ill fitting.
Bug On.
bluebus86
Banned
PostPosted: Thu Aug 02, 2018 9:18 pm    Post subject: Re: Current stock muffler options? Reply with quote
yes, short stroke verses long stroke cranks change over all motor width, hence side to side distence between the heads and their exhaust ports. the 40 horse had a shorter stroke.
Bug On!
oibovveroi
PostPosted: Thu Aug 02, 2018 11:49 pm    Post subject: Re: Current stock muffler options? Reply with quote
Is there a difference between one online dealers $75. Dansk and the other $135 dansk muffler?
I have a German one. But it’s from the 70s maybe early 80s and very crusty. No holes, but I don’t know if it still has any inerds left.
vwoldbug
vwoldbug is offline
PostPosted: Fri Aug 03, 2018 12:02 pm    Post subject: Re: Current stock muffler options? Reply with quote
The ad I speak of is in the 1968 and up section . I did a search for muffler in the 1968 parts section . The sticker on the muffler says 1300 cc to 1600 cc . I do know a 40 hp muffler won't fit a 1600 engine .
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Fri Aug 03, 2018 2:01 pm    Post subject: Re: Current stock muffler options? Reply with quote
I just installed a Bosal unit, great fit, sounds a bit throatier than an original German one but still gets a bit of that original "fweem" under acceleration.
Cheburashka
Cheburashka is offline
PostPosted: Fri Aug 03, 2018 6:36 pm    Post subject: Re: Current stock muffler options? Reply with quote
Just got a Dansk in the mail. I don't know what people are complaining about. The parts lined up pretty well.
Of course, that took a little persuasion. . .
And quite a bit of heat and brass.
[/img]
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Fri Aug 03, 2018 9:02 pm    Post subject: Re: Current stock muffler options? Reply with quote
I just don't believe anyone should have to do THAT MUCH work to an exhaust to get a good fit.. straight out of the box. I bought a Dansk exhaust for my early bay and it was the same way. It needed too much work and I was never happy with how my engine performed with it on there. My biggest pet peeve is the fresh air pre-heaters. They were so far off that I finally had to yank them out altogether and run the fresh air tubes straight to the heater box. I even tried to use the preheaters from a stock VW muffler, but the pipe shape and geometry is different enough that they wouldn't go on the aftermarket exhaust at all.
There are no good stock options that I personally know of.
Robert in Memphis
Engine rebuild thread
hanksjim1
PostPosted: Sat Aug 04, 2018 6:49 am    Post subject: Re: Current stock muffler options? Reply with quote
Just buy this one and be done with it:
https://www.thesamba.com/vw/classifieds/detail.php?id=2187438
Tim Donahoe
Tim Donahoe is offline
PostPosted: Sun Aug 05, 2018 3:26 pm    Post subject: Re: Current stock muffler options? Reply with quote
I just checked out the reviews on the Bosal muffler. It seems that TDC may be into something. The manufacturer brags about the perfect fit. They also mention quality, too; but a good fit is a good start.
So ... when the time comes, I’m going to give the Bolton a shot. It certainly can’t be worse than Dansk, and it might deliver the quality and fit the mention.
Tim
Let's do the Time Warp again!
Richard O'Brien
AlmostHeavenWV_VW
AlmostHeavenWV_VW is offline
PostPosted: Sun Aug 05, 2018 3:31 pm    Post subject: Re: Current stock muffler options? Reply with quote
RockAuto's got those:
https://www.rockauto.com/en/moreinfo.php?pk=1080376&cc=1368851&jsn=387
1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor
sb001
sb001 is offline
PostPosted: Sun Aug 05, 2018 6:22 pm    Post subject: Re: Current stock muffler options? Reply with quote
Just a simple question I'm wondering...
Why are all the aftermarket mufflers' preheat tubes for the heat riser on the opposite side as the original VW?
They are all on the right side, the original VW was on the left:
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
AlmostHeavenWV_VW
PostPosted: Sun Aug 05, 2018 7:19 pm    Post subject: Re: Current stock muffler options? Reply with quote
Maybe the switch was to consolidate the manufacturing lines of the mufflers once the Mexican Beetle got the spin-on filter oil pump? I know that pump/filter combo won't clear the left-hand preheat tube, maybe VW just began making all of the mufflers with it on the right to avoid having two different parts being made? and the aftermarket followed suit as well?
Just a guess
1600DP AK case
Solex 34PICT3 Carb
TDCTDI
TDCTDI is offline
PostPosted: Sun Aug 05, 2018 8:50 pm    Post subject: Re: Current stock muffler options? Reply with quote
FWIW, that tube is actually the return. On the pictured exhaust, the manifold actually gets it’s heat from the port directly on the #2 exhaust flange, it then flows through the heat riser then through that tube to return to the exhaust flow at the lower pressure side of the exhaust system.
sb001
sb001 is offline
PostPosted: Sun Aug 05, 2018 9:40 pm    Post subject: Re: Current stock muffler options? Reply with quote
Aah.
So then would it make any difference that the return tube is on the opposite side on all these aftermarket units?
1600 SP engine
TDCTDI
TDCTDI is offline
PostPosted: Mon Aug 06, 2018 4:08 am    Post subject: Re: Current stock muffler options? Reply with quote
sb001 wrote:
Aah.
No sir, the manifold just needs one side to have a higher pressure on one side so that the exhaust wants to flow through it.
