1970 Convertible Top Replacement
kustoms
kustoms is offline
PostPosted: Fri Feb 14, 2014 10:02 am    Post subject: Reply with quote
Vince, Very nice job.
I just have a few suggestions that will make your life a bit easier. Number one, Pick up some #20 Wiss shears in stead of those medical scissors. Number two, Never use aerosol glue for a top as there is not enough solids in them to hold long term. Use contact cement. Automotive grade would be best but you can use the standard stuff from your local hardware store. You will be able to brush it or spray it. You will not need to use screws to hold things in place. The glue will do the work. Number three, Based on the staple size, it looks like you are using a hand gun. If so pick up a cheap air gun. This will save your hand. Number four, Use #9 blades instead of Exacto knives. Cheaper and better control.
Did you put in the window cable? (Cable that runs from the body up and around the window then down to the other side of the body.) This is a must. It draws the top down and provides pressure for the window seal.
BTW, Very impressed with the fit of the header! Most people screw this up.
Google this.
"Bread and Circuses"
And wondering what the heck happen to my Samba post count?!?
Tom Thompson
Tijuana Kustoms Inc. (TM)
1-516-338-8746
www.tjkustoms.com
bluedot
bluedot is offline
PostPosted: Sat Oct 11, 2014 9:14 pm    Post subject: Reply with quote
I must have read this thread 300 times in the last year, prepping myself for the top install that's I'm finally starting.
My car is a 62 - so I don't have the cable that vince put around the back, and instead uses staples. I have the cables for the door frames and the springs - but I have not seen this one you're mentioning. Can you help me with a reference to it?
Thanks!
swavananda
swavananda is offline
PostPosted: Sun Oct 12, 2014 7:12 pm    Post subject: Reply with quote
Thanks!
That cable is for later verts with the glass rear window /69.5 and newer.
It helps keep the seal tight against the glass.not something your going to need.
h20rider
h20rider is offline
PostPosted: Wed Apr 22, 2015 9:05 pm    Post subject: Rear bow attachment. Reply with quote
Before starting my install, I wanted to check on how to install the rear wood bow. Should it be fastened down with screws? glued? (72 Ghia)
Thanks
tlambert
tlambert is offline
PostPosted: Wed Apr 22, 2015 9:21 pm    Post subject: Reply with quote
The metal bow that the wood bow fits into has holes in the bottom side for countersink screws to go into and then into the wood.
I'm doing a 72 Ghia vert now.
h20rider
h20rider is offline
PostPosted: Wed Apr 22, 2015 11:03 pm    Post subject: Reply with quote
Thanks Tiambert. Just what I needed. Smile
tlambert
tlambert is offline
PostPosted: Thu Apr 23, 2015 6:31 am    Post subject: Reply with quote
Also the wood bow needs to be mounted a certain way into the metal bow. The OG wood bow has a raised lip on the top side that runs the length of the bow. It should be to the rear of the top.
easy e
easy e is offline
PostPosted: Sat Sep 19, 2015 4:12 pm    Post subject: Reply with quote
Thought I'd post sources for the M3.7 closed-back finishing washers (VW part no. N115781):
http://en.hoffmann-speedster.com/golf-und-co./golf...-top-3.7mm
and in M4...
(Nickel over brass)
http://www.spaldingfasteners.co.uk/4mm-5mm-6mm-met...p-washers/
and...
ebay member: northenmoi (stainless M4)
aka: Evan
veedub13
veedub13 is offline
PostPosted: Sat Apr 15, 2017 1:38 am    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
Hi this info has been extremely useful.
Working on a 1971 changing the glass and covers. After multiple adjustments, I still can't get a good fit. There are gaps between the glass and soft top cover at the bottom sides. Looks about 10mm off. The centre part of the glass fits fine, but the sides don't. Are there other adjustments I can make?
Pictures:
Many thanks!
crocteau
crocteau is offline
PostPosted: Sat Apr 15, 2017 6:18 am    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
Hi veedub13, First, that's a beautiful color combination! Also, what type of padding did you use between the frame and the top cover?
As to your question, similar small gaps resulted when I replaced the top on my '71. At the time I hypothesized that a possible remedy might have been to adjust the position of the rear window hinges further upward, but as [email protected] pointed out (https://www.thesamba.com/vw/forum/viewtopic.php?t=297091) that adjustment is limited by the rear cowling. Since the rear window hinge adjustment has a ripple effect on measurements throughout the installation, the only way to test the hypothesis would be to start over, so I thank the German engineers who thought to add the rain gutters to the rear window frame and the drain tubes over the wheel arches, as I haven't had any leaks even in severe downpours of rain.
veedub13
veedub13 is offline
PostPosted: Mon Apr 24, 2017 1:25 am    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
Hey thanks very much for the reply. Padding is just foam that upholsterers use. Unfortunately, some parts of the top were pinched and poked through and I'll need to replace the entire top altogether. I'm also going to attempt to re-measure and fit everything again to get this glass to fit properly.
Brisyb
Brisyb is offline
PostPosted: Fri Apr 28, 2017 11:52 pm    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
Hi Ghiaaddict, do you happen to have a softcopy, or know where I can get, of the Convertible Top, Model 14 manual you show in your post.
I have a 1971 model and am rebuilding the top so correct measurements etc. are needed.
tlambert
tlambert is offline
PostPosted: Thu Jul 06, 2017 10:15 am    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
Ghiaaddict (Vince) hasn't been on here since 2014. I've called him several times and received no answer and no way to leave a message.
Not sure what has happened to him. If anyone has any info on his well being please let us know.
Tim
NOVA Airhead
NOVA Airhead is offline
PostPosted: Fri Jul 07, 2017 1:42 pm    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
I think I got my copy when I ordered a new top from Chuck's. It came with it.
However I did not find it to be much help. The pretty much just followed the instructions and videos here on the forum.
Ghia Owner Emeritus
Karmannwil
Karmannwil is offline
PostPosted: Sat Sep 01, 2018 2:32 am    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
Padding in 3 parts with in the middle horsehair(coconut)
Does anyone have experience with this?, what is the top.
Total thickness is 4 cm is this normal?
sputnick60
sputnick60 is offline
PostPosted: Sat Sep 01, 2018 2:45 am    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
That thickness is correct. The material is coconut husk sandwiched with a modern furniture padding. It is way better that using foam that will decay in a few short years. I would prefer using 100% husk but that might be difficult to find. I know Rugier Huber did stock it, but I've not seen any other supplier. Maybe if you know a furniture restorer that might provide a clue of where to get that stuff.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Bleyseng
Bleyseng is offline
PostPosted: Sat Sep 01, 2018 6:42 am    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
Who or what is Rugier Huber? Have a link?
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
sputnick60
PostPosted: Sat Sep 01, 2018 6:49 am    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
He is a German supplier
https://www.vintagecarparts.de/
But his shop has been closed since April.
Sad
Nicholas
Karmannwil
PostPosted: Sun Sep 02, 2018 12:52 am    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
This paddind I bought at a German supplier. Maybe you can buy this here appart.
https://cabrio.de/de/
Triumpf tr4 1963
Karmann ghia 1969 (in restauration)
Wilfried.
sputnick60
PostPosted: Sun Sep 02, 2018 1:29 am    Post subject: Re: 1970 Convertible Top Replacement Reply with quote
Interesting...I notice he has the wooden bows as well.
The prices aren't super crazy either, for a European supply.
Nicholas
Page 9 of 10
