harrymarlin Samba Member
Joined: June 07, 2018 Posts: 784 Location: Washington, DC
Posted: Thu Feb 07, 2019 10:56 am Post subject: Rear luggage shelf tar board? |
This black tar board (looks similar to thickness and material of what is under my front seats) is on the back of my 1967 convertible rear luggage shelf (under the carpet). I can't find this listed in the reproduction catalogs - does anyone know if this is stock, and, if so, what part it is, or how I can find a reproduction?
Thanks!
-Harry |
don1357 Samba Member
Joined: April 15, 2017 Posts: 387 Location: Palmer Alaska
Posted: Thu Feb 07, 2019 3:10 pm Post subject: Re: Rear luggage shelf tar board? |
If you are taking it out, use modern sound dampeing material that will actually do what it was meant to do. Nobody is going to be pulling the carpet to look at it. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8850 Location: Sunset, Louisiana
Posted: Thu Feb 07, 2019 3:13 pm Post subject: Re: Rear luggage shelf tar board? |
Your's looks good ... I see no reason to remove it. But if you do, Call Chuck at Chuck's Convertible Parts. If it is available, he will know. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Thu Feb 07, 2019 8:29 pm Post subject: Re: Rear luggage shelf tar board? |
Yeah ....I'd remove it carefully and check for any rust issues behind it. Clean it up (mild wire brush) ....spray it flat black, and reglue it in place. PL Premium construction adhesive works great. That should give you a 'near orginal' look ...for the carpet lifters. _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Posted: Sat Feb 09, 2019 7:04 am Post subject: Re: Rear luggage shelf tar board? |
This, from Chuck:
"it is the 3 piece rear well padding we list,it has tar between the layer,that is probably what you saw when you pulled yours out."
Although, for being in the center layer, it seems certainly well attached to the metal!
- Harry |
