Sticky Wheel After Brake Rebuild
Freebirdbeachbum
Freebirdbeachbum is offline
PostPosted: Mon Feb 11, 2019 8:51 am    Post subject: Sticky Wheel After Brake Rebuild Reply with quote
I did a complete rebuild on the drum brakes (i.e. new master cylinder, new wheel cylinders, new shoes, turned drums) and repacked the bearings.
Three of the four wheels spin freely but the left front is dragging badly and I've not yet even bled the system (yes, I have fully backed-off the adjuster star wheels).
Any thoughts?
Thanks,
Ken
1971 Super Beetle Convertible
1986 Alfa Romeo Spider
2017 Triumph Tiger Explorer
1972 Honda CB750 Four
1980 Honda 500CX Custom
1968 Benelli Cobra
1965 Moto Guzzi Lodola GT
1973 Moto Guzzi Eldorado
bluebus86
Banned
bluebus86 is offline
PostPosted: Mon Feb 11, 2019 8:58 am    Post subject: Re: Sticky Wheel After Brake Rebuild Reply with quote
Any thoughts?
Thanks,
Ken
remove drum, inspect shoes for propper seating on holders, make sure springs, e brake and associated parts are correctly installed. make sure shoe ends are correct shape.
Also sometimes the shoes are not centered well, but will become centered when brakes are activated.
Bug On!
FeelthySanchez
Location: Now is that a real poncho, or a Sears poncho?
FeelthySanchez is offline
PostPosted: Mon Feb 11, 2019 9:34 am    Post subject: Re: Sticky Wheel After Brake Rebuild Reply with quote
No mention of the return spring. Look it over: properly seated/have enough tension?
modok wrote:
I would like if you had enough clue to communicate what you are doing.
Ryan Tucker wrote:
Enough clue..Whats that mean?
OldIronSpine wrote:
What is a boost retard?
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Where do you put the inter cooler for it at? And does it use its own coolent?
Before I commit, I'm going to do more research because I don't really know what piston rings are.
vernonc
vernonc is offline
PostPosted: Mon Feb 11, 2019 9:41 am    Post subject: Re: Sticky Wheel After Brake Rebuild Reply with quote
Are the adjusters installed properly? They only go in one way because of the 'angle' in the slot.
mort
"Those who don't read newspapers are un-informed. Those who do read newspapers are mis-informed." Will Rogers
'69 sedan, low mileage, all original.....currently being 'freshened-up' for road trips and daily driving...just not every day
Freshening-up link http://www.thesamba.com/vw/forum/viewtopic.php?t=617386
Eric&Barb
Eric&Barb is offline
PostPosted: Mon Feb 11, 2019 12:04 pm    Post subject: Re: Sticky Wheel After Brake Rebuild Reply with quote
Sounds like a bad brake flex line. Flex lines are actually each one line inside the other. What happens is the inner sleeve after so much time (about 8 to 10 years) breaks up and turns the line into a one way valve. Pressure will go to the wheel, then takes a long time to go back to the MC. Causing the shoes to drag against the drum and possibly causing a fire.
If it has been about a decade or who knows when flex lines were last replaced. Then time to do so and save you more headaches out on the road.
In Stereo, Where Available!
Freebirdbeachbum
PostPosted: Tue Feb 12, 2019 6:18 am    Post subject: Re: Sticky Wheel After Brake Rebuild Reply with quote
Sorry, forgot to also include new flex lines.
1968 Benelli Cobra
Freebirdbeachbum
PostPosted: Tue Feb 12, 2019 6:39 am    Post subject: Re: Sticky Wheel After Brake Rebuild Reply with quote
I ruled out the drum and the bearings as problematic by swapping with the right side. It seems the drum gets hung up pressing it on the last 1/4" or so.
Can anyone spot a problem here:
1968 Benelli Cobra
vernonc
vernonc is offline
PostPosted: Tue Feb 12, 2019 6:56 am    Post subject: Re: Sticky Wheel After Brake Rebuild Reply with quote
This is a 'wild ass guess' but could the backing plate be slightly bent? This could cause the back of the shoes to have a slightly larger diameter than the front.
mort
Q-Dog
Q-Dog is offline
PostPosted: Tue Feb 12, 2019 7:08 am    Post subject: Re: Sticky Wheel After Brake Rebuild Reply with quote
One of the adjusters is installed upside down. Slot angle needs to match shoe angle. Check the wheel cylinder slots to make sure one of them isn't upside down too.
(rear wheel, but same deal)
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
Cusser
Cusser is offline
PostPosted: Tue Feb 12, 2019 7:18 am    Post subject: Re: Sticky Wheel After Brake Rebuild Reply with quote
Bottom right adjuster slot needs to be rotated 1/2 turn so slot lines up.
bluebus86
Banned
PostPosted: Tue Feb 12, 2019 9:11 am    Post subject: Re: Sticky Wheel After Brake Rebuild Reply with quote
make sure pistons are fully retracted,
Bug On!
74 Thing
74 Thing is offline
PostPosted: Tue Feb 12, 2019 9:35 am    Post subject: Re: Sticky Wheel After Brake Rebuild Reply with quote
It is the adjuster screw on the right bottom of the photo as indicated above. Remove that shoe, then rotate the screw 180 degrees, then reinstall.
If you look at the adjuster screws they are angled and the shoe should sit flat in the screw face-if not you have it installed backwards!
ashman40
ashman40 is offline
PostPosted: Tue Feb 12, 2019 12:08 pm    Post subject: Re: Sticky Wheel After Brake Rebuild Reply with quote
Here's some pics that help illustrate what the others are talking about:
In the upper pic you can see that on the late model adjuster screw the slot is cut all the way to the threads on one side. This is the top of the adjuster screw.
You can see this in the bottom pic on the right side as the screw is virtually cut away so you can see the bottom of the shoe rests on the slant inside the slot. Compared to your pic where the shoe is being held further away by the inverted screw slot.
AshMan40
Freebirdbeachbum
PostPosted: Tue Feb 12, 2019 11:07 pm    Post subject: Re: Sticky Wheel After Brake Rebuild Reply with quote
Y’all are pretty good. Both adjusters were upside down. Thanks so much.
1968 Benelli Cobra
