Axle length
Page: Previous  1, 2
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Thu Feb 21, 2019 6:17 pm    Post subject: Re: Axle length Reply with quote
nikke911 wrote:
Changed from short to long axles on my splitbeetle. Problem now is the damper doesn.t line up anymore. They fit perfectly on the shorttube but the angle is different on the long tubes. Is there a readily made kit for this or do i have to make my own spacers?
Your early Beetle tube has the shock bolt parallel to the tube, where the later tube has the bottom bolt angled. Have you tried simply rotating the bottom of the shock?
Fubawu
Fubawu is offline
PostPosted: Tue Jun 09, 2020 10:30 am    Post subject: Re: Axle length Reply with quote
I'm a bit confused here.
I have a 66 and believe that I have 67-68 swing axles. As the hub/bearing carrier seems to be slightly wider than stock. Is it possible to change only the bearing housing to the proper 66 and earlier? I believe this is the difference in length no? If this is done will the axle spline still work or will it be too long?
EVfun Premium Member
EVfun is offline
PostPosted: Wed Jun 10, 2020 8:02 am    Post subject: Re: Axle length Reply with quote
You have to change the axle, it is shorter too.
Wildthings wrote:
Fubawu
Fubawu is offline
PostPosted: Wed Jun 10, 2020 9:04 am    Post subject: Re: Axle length Reply with quote
I figured as much..thanks for the confirmation.
65stroker
65stroker is offline
PostPosted: Mon Oct 17, 2022 12:05 pm    Post subject: Re: Axle length Reply with quote
So I have a '68 (long axles, long splines, extended snouts on drums) and I'm about to upgrade to rear discs. I bought the rear disc brake kit for a 58-67 along with spacers and now I realize my EMPI Fuchs won't take the rear center caps because of the longer splines and spacer.
What are my options?
1. Can I convert to shorter pre '67 tubes, axles, bearings, and cap?
2. Or would '67 axles (If found) work with the '68 setup as is and give me some room for the center cap?
65stroker
PostPosted: Wed Oct 19, 2022 3:14 pm    Post subject: Re: Axle length Reply with quote
I know I brought this back form the dead... Anyone able to provide some wisdom on this?
EVfun is offline
PostPosted: Wed Oct 19, 2022 7:15 pm    Post subject: Re: Axle length Reply with quote
You can put '67 axles in '68 tubes. You cannot put short axles ('66 down) in the tubes. You might look into longer caps -- that would be a LOT easier that removing the transaxle to swap axles.
Wildthings wrote:
nize
nize is offline
PostPosted: Sun Dec 29, 2024 1:53 am    Post subject: Re: Axle length Reply with quote
Ok so I need some advice...
I need to do a long to short axle conversion swap on my ghia. If I search on the forums there seems to be a fact that you need 60-66 short axles. Why is this? Cant I use earlier drive shafts from a split case beetle or isnt that going to work?
----------(VW)----------
1954 Kombi
1957 lowlight ghia coupe
EVfun is offline
PostPosted: Sun Dec 29, 2024 8:29 am    Post subject: Re: Axle length Reply with quote
I've been told that the axles used on splitcase transaxles were wimpier. They will work, they just are not as strong. You also have to take the splitcase transaxle apart to get the axles out.
The axle tubes are slightly different too. The lower shock mount is not at a 45 degree angle like on later Bugs, but strait with the shock bolt running perpendicular to the vehicle. Also, if using the early axle tubes be sure to get the clamp for the brake hose. It is a separate bolt on part with the early splitcase axle tubes, but welded on part of tunnel axle tubes.
Oh, and 1 more minor point. 1960 Bugs used the splitcase transaxle too. So what are would most be looking for is 1961-1966 axles and tubes. They should be very common.
Wildthings wrote:
esde
esde is offline
PostPosted: Sun Dec 29, 2024 8:31 am    Post subject: Re: Axle length Reply with quote
The earlier split case shafts will work, but they are not as strong as the 60-66 shafts. And, if you try to use there earlier axle tubes, you need the earlier bearing caps that go with the tubes (different bearing depths), and the early backing plates (different thickness). Best to just use 60-66 parts to keep it easy.
EVfun is offline
PostPosted: Sun Dec 29, 2024 3:53 pm    Post subject: Re: Axle length Reply with quote
Esde brings up a really good point. There are 4 different swing axle bearing caps and 3 different axle tube end shapes to go with them.
1. Early 1958 model year and older. The axle tubes and caps have to be kept together because machined differences in the large O-ring fitment won’t interchange with later parts. Also, they were designed to work with slightly thinner backing plates. Some people have reported leakage when used with later backing plates.
2. 1958 through 1964. These were designed to work with an oil slinger, like earlier rear axles tubes and caps. They are often used without one because for many years the slinger was not available new and most replacement rear brakes drums were not drilled to accept it.
3. 1965 through 1967. These functionally interchange with the previous design but switched to having the axle seal leak deflector built into the bearing cap. Older brake backing plates need a hole or slot added to allow this system to work. This is the first version to use a paper gasket behind the bearing cap, to seal this new oil leakage drain.
4. 1968 only on US sold Bugs. This system was used on later swingaxle Bugs sold in other parts of the world. The difference I notice is that the amount of the axle bearing that is in the axle tube and the amount in the cap was changed. This retained the oil slinger in the bearing cap design, so they look a lot like the 1965-1967 parts.
5. IRS bearing caps are different than swingaxle caps. They do not have the built in oil slinger.
Wildthings wrote:
Ovally
Ovally is offline
PostPosted: Mon Dec 30, 2024 1:26 am    Post subject: Re: Axle length Reply with quote
Do you have a source for that information?
According to the VW parts list the axles 111 501 201A are the same up to chassis 1161021300 (VW Type 1 -- 7/66).
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018
nize
nize is offline
PostPosted: Mon Dec 30, 2024 1:34 am    Post subject: Re: Axle length Reply with quote
Thanks for clearing things up. I will try to go ahead and use my split case axles then.
1954 Kombi
Page: Previous  1, 2
Page 2 of 2
