Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap)
Page: Previous  1, 2, 3 ... 17, 18, 19 ... 21, 22, 23  Next
cmonSTART
cmonSTART is offline
PostPosted: Wed Oct 14, 2020 10:48 am    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
It has to be one of my favorite builds. I love the opposition between the rims/tires/brakes and the paint. Well done sir!
'78 Bus 2.0FI
de K1IGS
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Oct 14, 2020 11:30 am    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
that bus is epic, and the only one I lust after here on the forum
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Vee Dub Nut
Vee Dub Nut is offline
PostPosted: Wed Oct 14, 2020 5:35 pm    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
Thank you sir! Its been a fun project for sure, and I'm super happy with the end result. I've always like the pro-touring type muscle cars, classic looks with all modern powertrain and suspension. So that's the direction I've been moving with this thing all along. Still got a few things on my to-do list left, but can't beat it where it is now.
Thanks man! I take that as a huge compliment considering the level of Bus(es) you've built. I appreciate the props.
Did a little cruising around this afternoon. This was the real test of the adjustments made in the rear after my initial rubbing issues (i.e. redrill and spacers vs adaptors). Happy to report that everything in the rear is tucking well and has no clearance issues. Also getting the front brakes bedded in, and they are GOOOOOOOOOOOOOOOOD Twisted Evil
Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut
fokker100
fokker100 is offline
PostPosted: Thu Oct 15, 2020 2:21 pm    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
Sweeeeeeeet!
How’s the braking? Improved or same? I honestly didn’t know you could tuck an 8.5” in the rear, I guess it has to be in the sweet spot but still, wow!
You are an adventurer, I like your style 😁
Ride_On
Ride_On is offline
PostPosted: Thu Oct 15, 2020 3:02 pm    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
Ha! Maybe we'll have to step up and make our buses will become brake twins too!
Great job and great documentation - kudos and thanks Vee Dub Nut!!
fokker100 wrote:
Sweeeeeeeet!
1977 Westfalia 2.0 FI Skills EJ25 w SubaruGears 5sp
https://www.thesamba.com/vw/forum/viewtopic.php?t=687254
2018 Golf Sportwagen 4MO DSG (Dieselgated 2013 Golf Wagon TDI DSG)
Vee Dub Nut
PostPosted: Thu Oct 15, 2020 6:09 pm    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
fokker100 wrote:
Sweeeeeeeet!
Braking is awesome... definite improvement over the stock parts. Less pedal force for the same stopping power, super solid pedal feel, and they are VERY responsive. Plus they should be able to take quite a bit more repeated breaking without fade (spirited driving, mountain passes, etc), as they have the ability to shed a heat a lot better than the stock solid disk.
Yea me too originally... but did some digging and found some info that gave me a bit of hope, so I went for it. You have to be RIGHT on the money with everything, and it's not for the faint of heart, but it CAN fit. When I dropped from the 19mm adaptor and went with redrilled hubs and the 13mm spacer, I pulled the wheel in as far as I possibly could. The wheel hoop is RIGHT UP ON the drop plate (like I said, not for the faint of heart). But this gives me the best balance for clearance between the outer sidewall and outer fender lip, and inner sidewall and spring plate.
Thank you sir!
So far I'd definitely recommend the brakes... I'm loving them. Biggest hurdle for most folks is that with the 944 front hubs, you're pushed to the 5x130 PCD. This means Porsche wheels or some other sort of adaptor or aftermarket wheel.
As I mentioned on IG, these Porsche calipers are also very large. Compared to a comparable 4 pot Willwood caliper with the same size pistons, the Porsche calipers are much more massive. But they are also significantly more stiff in their design as a result. It may also be obvious, but you have to run a 16 or 17" wheel to clear it all. But they are OEM quality, have dust seals, etc... If you buy them new like I did, get ready for sticker shock. Shocked I think they charge extra for that name carved in the side of them. Laughing
67 Beetle (TBD)
Vee Dub Nut
PostPosted: Thu Oct 15, 2020 6:23 pm    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
Just a few more pics of the calipers themselves for detail.
For size reference, holding one in my hand. They're not small...
67 Beetle (TBD)
Vee Dub Nut
PostPosted: Thu Oct 15, 2020 6:28 pm    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
And because we all love more pictures.. I'll leave this one here too. Enjoying the fall weather here in north Georgia Cool
67 Beetle (TBD)
Sloride
Sloride is offline
PostPosted: Thu Oct 15, 2020 7:04 pm    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
Great job as usual! Raising the bar for the rest of us. Well done.
1972 Westfalia - 1.8 VW in-line h2o conversion
Ottawa, Ontario, Canada
Link to the engine swap:
http://www.thesamba.com/vw/forum/viewtopic.php?t=565304&highlight=
1964 Ruby Red Beetle
https://www.thesamba.com/vw/forum/viewtopic.php?t=705757&highlight=ruby+red
fokker100
PostPosted: Fri Oct 16, 2020 9:48 am    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
That will probably be the next update, absolutely, I still plan to enjoy driving the bus as is though next year after 3 years without it 😅
As for Lanner, I totally agree, he takes the extra step to take the time to explain in detail what to do, I have been impressed, and for a rare time it is a shop in my “neighborhood”, why go elsewhere!
And for US people, Canadian money is cheap 👌
panel
panel is offline
PostPosted: Sun Oct 18, 2020 11:15 am    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
I've never seen black KYB's. Just silver and white. What's the deal with these ones ?
My '65-Subaru EJ20 Turbo conversion
vwwestyman
vwwestyman is offline
PostPosted: Sun Oct 18, 2020 12:34 pm    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
I can't answer your question beyond saying that is what is on my Bus, too. I believe I got them from the FLAPS.
Dave Cook
1973 Wild Westerner
My Thing
richparker
richparker is offline
PostPosted: Sun Oct 18, 2020 3:18 pm    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
The Excel-G are black, the older Gas-A-Just are white and the new Gas-A-Just are silver.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
Vee Dub Nut
PostPosted: Sun Oct 18, 2020 4:36 pm    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
As Rich noted, those are Excel-G's. Somewhere here in the bay forum I had heard of a recommendation of running Gas-Adjust in the rears, and Excel-G's in the front as a good combo for Buses.
Mine already had gas adjust's in the rear when I bought it, so when I did the front suspension a few years ago, I picked up some Excel-G's for the front. They have been great so far.
Personally, my experience with Gas-Adjusts have been pretty mixed. No real complaints on the ones in the Bus, but I swore them off in my Beetle. Absolutely terrible and WAY to stiff on the Beetle. Was like riding in a wagon with no suspension. Some cheapy oil shocks rode significantly better in it.
67 Beetle (TBD)
Vee Dub Nut
PostPosted: Sun Oct 18, 2020 4:39 pm    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
Absolutely agree... Lanner was/is a great guy to work with. Super knowledgeable, helpful, and just a nice guy to boot. He and I were also talking shop about the Subi swap. He's got a late bay that's going under the knife soon. I was happy to help share info from my build. Should be killer!
67 Beetle (TBD)
Vee Dub Nut
PostPosted: Sun Oct 18, 2020 4:41 pm    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
Yup.. think I snagged mine off rock auto. They've been great so far.
67 Beetle (TBD)
Vee Dub Nut
PostPosted: Sun Oct 18, 2020 4:49 pm    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
Because I'm a picture whore...
I grabbed this one before moving the little tikes slide over to grandma's house. I've hauled all sorts of junk on this rack since I got it. Just super handy. Let me tell you, if you don't think you get enough looks driving a Bus around in general, strap a kids slide to the top Laughing Basically EVERYONE was giving us the WTF look as we drove across town.
From the local ATL VOLKS Vintage VW meetup this morning. Had about 30 cars show up. Awesome weather today, and we had a cool backdrop for pics.
And lastly, just a cool angle I grabbed in the shop. Like I said, not everyones cup of tea, but I love the way this thing has come out. We enjoy the heck out of it.
67 Beetle (TBD)
richparker
PostPosted: Sun Oct 18, 2020 6:04 pm    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
Personally I like the ride the Gas-A-Justs offer on a Westy, especially a fully loaded one. I liked them so much I even put a set on my Nissan pickup this winter.
Bus looks great, I’m gonna repost the mural pic on my Bays and Murals thread.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
fokker100
PostPosted: Mon Oct 19, 2020 7:17 am    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
Awesome pics, a beautiful bus!
That’s good news that Lanner is working on a late bay conversion, he should upgrade the brakes in the rear as well, as I honestly don’t know what to put there, his knowledge will be awesome.
Do you plan to upgrade the rear as well?
I know the original brakes are amazing on the bus, but sometimes the way we drive those nowadays, I won’t be unhappy to put discs in place of drums one day with this kind of engine and mountain driving.
Vee Dub Nut
PostPosted: Mon Oct 19, 2020 9:16 am    Post subject: Re: Vee Dub Nut's 74 Bay Transporter (& Subaru EJ25 Swap) Reply with quote
Thanks Rich!
As far as the Gas-Adjusts, I've got no complaints on the ones in the rear of my Bus. I would imagine the extra weight of a Bus would help make them have a softer feel than they did on my Beetle.
67 Beetle (TBD)
Page 18 of 23
