loverofpeace Samba Member
Posted: Wed Jan 27, 2021 8:15 am Post subject: Running wires from engine bay to cab |
Is there an easy way to run a pair of wires from the engine bay to the cab? I'm installing a DC/DC charger and spent about 15 minutes looking for a place to thread them through without any luck.
I figured I'd ask here before going with the drill a hole/grommet method tomorrow.
Thanks in advance! |
4Gears4Tires Samba Member
Posted: Wed Jan 27, 2021 8:18 am Post subject: Re: Running wires from engine bay to cab |
Easy way? Yes. Leave the engine cover off and and then lay them on top of the back seat and then run them straight to wherever they need to go.
The less easy way, but more helpful, is you will need to drill a hole/grommet somewhere like you said. Holes already exist in the front and below the rear bench. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
termuehlen  Samba Member
Joined: May 02, 2012 Posts: 1032 Location: Redwood City
Posted: Wed Jan 27, 2021 8:31 am Post subject: Re: Running wires from engine bay to cab |
I ran a whole bundle of wires underneath the exterior. I have used them for various purposes, mostly exterior lighting. I came up in through the front behind the dash. Canโt remember exactly where, probably with the headlight wires. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17137 Location: Brookeville, MD
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6926 Location: Fort Lauderdale, Fl.
Posted: Wed Jan 27, 2021 8:35 am Post subject: Re: Running wires from engine bay to cab |
I ran a 5 conductor cable from the engine bay underneath along the Drivers side to come up in the center.
Just in front of the stick shift behind the heater cover there is a oval rubber plug that you can poke a neat hole in and run the cable up to the Dashboard for instruments and such. _________________ This free advice is worth exactly what you paid for it.
Posted: Wed Jan 27, 2021 10:39 am Post subject: Re: Running wires from engine bay to cab |
Thanks for the help guys I'll look for the ones in the center near the stick shift/heater hoses/rear bench. If that doesn't work I'll just drill. Wishing everyone a pleasant day/evening! |
Posted: Wed Jan 27, 2021 11:12 am Post subject: Re: Running wires from engine bay to cab |
loverofpeace wrote: |
Do not drill a hole in your Vanagon! _________________ This free advice is worth exactly what you paid for it.
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8396 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Jan 27, 2021 6:26 pm Post subject: Re: Running wires from engine bay to cab |
I used an orange outdoor-rated extension cord, plug ends cut off & fished
as described...3 connectors ensconced in multiple layers of protection...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
16CVs Samba Member
Joined: February 22, 2004 Posts: 4233 Location: Redwood City, California
Posted: Thu Jan 28, 2021 12:21 am Post subject: Re: Running wires from engine bay to cab |
What gauge of wiring are you trying to run? Just control type wires? If you have a 86 or newer with no cruise you might be able to use the the unused wires in the breakout box on the left.
If not there are plenty of unused openings under the van and as others have said you can just follow factory wiring and go right up into the dash.
Some more information may be helpful.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Posted: Thu Jan 28, 2021 2:43 am Post subject: Re: Running wires from engine bay to cab |
Using two 16mm2 wire (awg 6) wires. Would prefer it to not go through the front of the car as my dc/dc will be behind the drivers seat and would prefer for it to be about 4m one way. Going to the breaker box and back would probably make this a bit longer. Draw should be 25a Max (though constant of 18a).
Checked for holes behind the rear bench as one of you pointed out. Didn't find any there. Will look up front in a few hours when I have more time. |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23837 Location: NYC/Upstate/ROW
Posted: Thu Jan 28, 2021 5:30 am Post subject: Re: Running wires from engine bay to cab |
Nice sizing, 6 awg is correct for that. _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐ |
kourt Samba Member
Joined: August 13, 2013 Posts: 2311 Location: Austin, TX
Posted: Thu Jan 28, 2021 8:31 am Post subject: Re: Running wires from engine bay to cab |
If you have a deleted rear seat heater (or don't use it and are prepared to delete it) the wiring harness for that gives you three or four lines run from the engine bay area to the dashboard. I used that extensively for "other" wiring runs.
kourt |
Posted: Fri Jan 29, 2021 3:37 am Post subject: Re: Running wires from engine bay to cab |
kourt wrote: |
kourt |
Thanks kourt, this is a european VW Transporter with a hightop conversion so there was never a rear seat heater there. |
Posted: Fri Jan 29, 2021 5:17 am Post subject: Re: Running wires from engine bay to cab |
Oh well now you have to post some pictures!  _________________ This free advice is worth exactly what you paid for it.
Posted: Fri Jan 29, 2021 6:38 am Post subject: Re: Running wires from engine bay to cab |
Steve M. wrote: |
Oh well now you have to post some pictures!  |
A few months ago in Sicily:
Posted: Fri Jan 29, 2021 6:42 am Post subject: Re: Running wires from engine bay to cab |
Steve M. wrote: |
And one more from the Dolomites (The eastern Italian Alps)
DuncanS Samba Member
Posted: Fri Jan 29, 2021 7:49 am Post subject: Re: Running wires from engine bay to cab |
Those are good sized wires. There should be no problem running them under the car, but where do you need them inside? If in the front, then you can bring them up and through grommets behind a headlight. If you prime the sides of the drilled hole, there won't be any problem. Or through the areas where the heater valve control cable goes. If under the driver's seat, you can either do the grommet thing or cut the pad under the carpet/rubber in front to make a groove. Tape them down to the metal with strong--Gorilla tape, do you have that?--and relay the carpet. Between the seat pedestal and E brake lever and through into the pedestal cavity.
The ECU grommet in the firewall is large and you should be able to get the wires through there if they are needed in the back.
Another possibility is through a new grommet drilled into the PS snorkel. Do it on the forward side and high enough above the engine deck for easy access with the drill. Then it can run behind any panel you may have and exit at the firewall.
Don't be afraid to drill. This is a vehicle being modified to give you what you want--not some show piece museum 100% original item.
Duncan |
ledogboy Samba Member
Joined: September 19, 2005 Posts: 599 Location: Scappoose, OR / Oakland, CA
Posted: Fri Jan 29, 2021 9:14 am Post subject: Re: Running wires from engine bay to cab |
I have my DC/DC charger behind the drivers seat and opted to bring the wire up through the old vent hole in the driverโs battery box. I replaced the old lid with plexiglass and cut out a half moon to allow the wires to run back and forth from the charger to my lithium bank under the seat. _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
