VW 3051 ball joint tool dimensions
DanHoug
DanHoug is offline
PostPosted: Fri Feb 19, 2021 1:20 pm    Post subject: VW 3051 ball joint tool dimensions Reply with quote
if anyone out there that has the VW/Snapon 3051 ball joint tool and would be willing to measure it i'd like the following:
length:
OD:
ID one end:
ID other end:
-dan
www.thefixitworkshop.com
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Feb 19, 2021 5:56 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
seeing i own a van these days i wanted that tool, but seems to be on intergalactic backorder
i made my own if you're interested in dimensions. she ain't pretty because i made it from scrap but it works fine
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
DanHoug
DanHoug is offline
PostPosted: Fri Feb 19, 2021 6:03 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
aup. please!
-dan
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Feb 19, 2021 7:25 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
ID 64mm
height 77 mm
OD 70mm
those are approximate, within +/- a mm
the cut out is about 49mm wide and 45mm tall
note: the ball joint stem will pass thru the hole a bit, but i have other pates with holes in them to make it work.
the ID is like a mm bigger than the OD of the ball joint. seeing i was a bit short on pipe you can see where i ground out the upper part to clear the knuckle. in a perfect world i would have added another 1/2-3/4 of an inch but it works just fine
Jake Raby wrote:
Brian wrote:
galencurrington
galencurrington is offline
PostPosted: Fri Feb 19, 2021 7:45 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
https://vw.snapon.com/SpecialToolsDetail.aspx?itemid=28450108
Shows in stock
I got mine off German eBay it’s still on its way.
"asking and getting are two different things"
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Feb 19, 2021 8:31 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
interesting, i couldn't order one a month or so ago, and tried again only to have it bounce back.
thanks for the tip, i will try again
Jake Raby wrote:
Brian wrote:
dabaron
dabaron is offline
PostPosted: Sat Feb 20, 2021 2:46 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
in April/May i'm going to need this tool. i hope to never need it again, but quality ball joints, even when quality, aren't so quality.
and so it goes. poo-tweet.
1991 Vanagon GL Camper
DanHoug
DanHoug is offline
PostPosted: Sat Feb 20, 2021 3:30 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
i've ordered two TRW ball joints from those Latvian eBay rascals that have all the good parts. $32 each post paid. we'll see if i was resourceful or not. could NOT find any stateside with the cast bottom aka Lemforder or TRW.
i need a ball joint in hand to do some hardware store cruising... Schedule 40 and 80 2" black iron pipe looks promising. maybe weld a 40 and an 80 together for the different diameters.
they're on the same slow boat that my fuse block connectors traveled over on, but at least THOSE are in San Francisco port of entry now.
-dan
RolandD
RolandD is offline
PostPosted: Sat Feb 20, 2021 4:27 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
Don't rule out a short piece of exhaust tubing No nee4d for a cut out, it is thin enough . I use an arbor press.
Roland
DanHoug
DanHoug is offline
PostPosted: Sat Feb 20, 2021 4:59 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
Roland
really?! it didn't crush? i'll check that out.
-dan
GreggK
GreggK is offline
PostPosted: Sat Feb 20, 2021 6:16 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
Here is my attempt at taking some pictures with splits on almost every finger tip. Not as easy as I thought it would be.
Overall length.
Outer.
Thicker inner.
Thinner inner.
This one might help too.
Do notice I held a few of those measurements at an inch. Hope it helps.
Dabaron, I have the tool and press and I'm not far. Feel free to get in touch when its time. I also posted some pictures on this thread, end of page one. https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
'86 2wd Poptop transplant
FAS TDi engine swap. Peloquin LSD
https://www.thesamba.com/vw/forum/viewtopic.php?t=692188&highlight=slow+but+steady
DanHoug
DanHoug is offline
PostPosted: Sat Feb 20, 2021 7:33 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
this is really helpful, Gregg. thanks! i was thinking 2" black pipe was the same but this is way larger.
-dan
GreggK
GreggK is offline
PostPosted: Sun Feb 21, 2021 8:51 am    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
Here are the dimensions using a caliper. I did my best to get it centered.
Here are the thin side.
And I think Skills is correct that the cut out is important too.
Here is the cut out.
I'll double check that I got the pictures under the correct locations.
GreggK
GreggK is offline
PostPosted: Sun Feb 21, 2021 8:52 am    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
The first two pictures are the thick side.
dabaron
dabaron is offline
PostPosted: Sun Feb 21, 2021 9:39 am    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
is this tool in Colorado or Philly... asking for a friend Laughing
GreggK
GreggK is offline
PostPosted: Sun Feb 21, 2021 1:32 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
Philly yo!
DanHoug
DanHoug is offline
PostPosted: Sat Mar 06, 2021 6:09 am    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
this will be my attempt at tool 3051.. exhaust tubing another member had tried and it worked. i'm hopeful it will clear everything it needs to without the cut away.
will exhaust tubing be strong enough to press it in? we'll see! with a straight on push in the press it might.
-dan
RolandD
RolandD is offline
PostPosted: Sat Mar 06, 2021 7:48 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
Yup, that looks familiar.
Roland
DanHoug
DanHoug is offline
PostPosted: Sat Mar 06, 2021 8:46 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
Roland! was that you that had used exhaust tubing? if so, thanks for the idea!
-dan
ALIKA T3
ALIKA T3 is offline
PostPosted: Sat Mar 06, 2021 10:23 pm    Post subject: Re: VW 3051 ball joint tool dimensions Reply with quote
There's a whole thread about this tool here
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20
