12v Starter on 6v Flywheel Conversion
mitcharvey
mitcharvey is offline
PostPosted: Fri Sep 14, 2007 12:40 am    Post subject: 12v Starter on 6v Flywheel Conversion Reply with quote
Here is an interesting project I just finished. I think it is well worth sharing with all of you.
http://coccinellebleu.blogspot.com/2007/09/12v-starter-on-6v-flywheel.html
http://coccinellebleu.blogspot.com (updated 3/7/08 )
View user's profile Send private message Yahoo Messenger MSN Messenger Classifieds Feedback
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sat Sep 15, 2007 3:42 am    Post subject: Reply with quote
Interesting. I once tried to do something similar many years ago but couldn't get it to work.
You might try posting that link in the "Sticky" for 6V to 12V conversion too.... Sticky: 6 volt to 12 volt?
MUNICH_VR6
MUNICH_VR6 is offline
PostPosted: Tue Oct 23, 2007 9:00 am    Post subject: Reply with quote
I wonder if a 6v pinion gear would fit on a self suported 12v automatic starter? This way I could eliminate the step of bothering with the bellhousing bushing. -mason-
1969 ej22 bus
2014 Q5 tdi
2004 BMW Rockster R1150r
-mason-
View user's profile Send private message Send e-mail AIM Address Classifieds Feedback
max-five
max-five is offline
PostPosted: Tue Oct 23, 2007 2:01 pm    Post subject: Reply with quote
Munich, that's worth a try.
That article was very interesting. Someone should start making new 1 piece bushings and make a million bux. I don't like the idea of a bushing inside a bushing. One is gonna spin and screw things up. And yes, I believe the 6v solenoid should be scrapped in favor of the 12. Since I am a 6v nazi, I won't be trying this...but it is interesting.
'66 Beetle Convertible "Wilson"
'05 New Beetle Convertible "Ladybug"
'69 Deluxe Bus "Sunshine"
Want to buy your original German black '66 bug front seat upholstery...all or part
krisbeetle
krisbeetle is offline
PostPosted: Wed Jan 16, 2008 8:01 pm    Post subject: Reply with quote
anyone else had sucsess with this conversion?
Wayne S. Johnson
Wayne S. Johnson is offline
PostPosted: Thu Jan 17, 2008 12:41 am    Post subject: 12V Starter on a 6V Flywheel with No Changes Reply with quote
You don’t need to spend the time and money to remove the engine, replace flywheel, replace pinion bushing or grind the bell housing. Using a 6 volt starter in a 12 volt conversion will trash your flywheel and starter teeth.
This is a quality remanufactured BOSCH starter, my supplier has 40 years of experience and has sold hundreds of these starters with no returns.
http://www.thesamba.com/vw/classifieds/detail.php?id=551031
HYBRID STARTER 6/12 https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231
Last edited by Wayne S. Johnson on Thu Jan 17, 2008 11:55 pm; edited 2 times in total
krisbeetle
PostPosted: Thu Jan 17, 2008 1:37 am    Post subject: Reply with quote
so I should buy one from you when I have all the parts to do it myself?
anyone have a REAL answer? and dont just want to sell there overpriced junk to me?
bill may
bill may is offline
PostPosted: Fri Jun 18, 2010 5:26 am    Post subject: Reply with quote
1963-1966 bus with optional 12 volt used a 6 volt starter with 12 volt solenoid.i forget the M-Code for this.
there was a 6volt auto-stick / automatic starter that used no bushing also in ghia application.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
Humanure
Humanure is offline
PostPosted: Thu Jun 24, 2010 8:44 pm    Post subject: Reply with quote
I was successful in swapping a 6v drive pinion assembly onto a 12v armature. Although I found that there are at least 2 different drive pinion assemblies and shift levers in 12v starters.
The first picture is my 12v starter with the 6v drive pinion and stacked bushings. I only used it a few times while trying to bench start a 40hp engine, so I won't be able to provide any info towards real-world use. The starter worked like a charm for the short amount of time I used it.
The last 2 pics show 2 differences I found while dismantling extra 12v starters that I had laying around. I'm not sure if 6v starters vary like this or are of one style. I guess I was lucky that I had extra 12v starters laying around and one matched up with the 6v style. To clarify, the pics below show 12v drive pinion assemblies and shift levers; don't mind the damage to the shorter drive pinion on the right.
It is difficult to free fools from the chains they revere.
mitcharvey
PostPosted: Sat Sep 04, 2010 8:22 pm    Post subject: Reply with quote
wow that's totally rad Humanure! I never thought anyone would ever try it. That's interesting there were different types, I guess I got lucky.
But on a sour note, that inner bushing finally disintegrated in my starter sometime this week. It looks like it spun out, maybe I should have used a glue instead of locktite.
Also the inner bushing in the bellhouse is ovaled-out and may go soon too. Both the outer bushings are intact and look unaffected. I'm not sure which one is causing the starter to intermittently go dead, I'm actually thinking the bellhouse bushing, since it would cause the greater lateral movement. But either way it's time for some new ones. I think I'm gonna look to have a new set machined.
I'd post a picture but there's nothing to see, just some flakes of bronze.
But hey, I got nearly three years to the day out of them! pretty stoked about that. I honestly didn't think it'd last more than a year.
smisk
smisk is offline
PostPosted: Sun Sep 05, 2010 6:13 am    Post subject: Reply with quote
krisbeetle wrote "anyone else had success with this conversion?"
I did this conversion about three years ago...no problems with the starter. I used bearing mount to bond the two bushings in place.
As Humanure pointed out the 6 Volt bendix you are going to use needs to be the same design as the 12 Volt you will replace. If the two starter motors are the same length the bendix should be the same design in both. The conversion won't work using one of the newer shorter 12V starters and a bendix out of a longer 6V starter.
'66 Bug
'70 Ghia
Danwvw
Danwvw is offline
PostPosted: Sun Jun 28, 2020 10:06 pm    Post subject: Re: 12v Starter on 6v Flywheel Conversion Reply with quote
So where to I buy the 6 volt starter gear etc...?
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
bastardbus
bastardbus is offline
PostPosted: Thu Nov 11, 2021 2:14 pm    Post subject: Re: 12v Starter on 6v Flywheel Conversion Reply with quote
I think the failure would be due to stacked bushings. I think a solid one piece bushing would be the ticket. Would really be no different then stock. I see someone is making these and selling on samba here now. I wonder if he uses a single new or stacked bushing.
Samba Member #95
smisk
smisk is offline
PostPosted: Thu Nov 11, 2021 4:24 pm    Post subject: Re: 12v Starter on 6v Flywheel Conversion Reply with quote
I'm still using the same starter I converted 15 years ago.
'66 Bug
'70 Ghia
dustymojave
dustymojave is offline
PostPosted: Mon Nov 15, 2021 9:09 pm    Post subject: Re: 12v Starter on 6v Flywheel Conversion Reply with quote
In my '58 Baja, back in the mid 70s I converted it from split case to tunnel case trans, 36hp 1200 to 40hp 1200 with 83mm big bore pistons for 1385cc, and converted the whole car to 12V. I did all this for my dad to have a Baja Bug. The Bug had already been crashed into many times in its 375,000 miles, people then didn't care about just another Bug in Southern California. There were probably well over a million of them in the area anyway. Common as Immigrants in SoCal (including those who had immigrated from other parts of the US). For the 12V conversion, I used the original starter (2-owner car and the 1st was a friend and dad did all the mechanical work on it from new...So we KNEW that it was the original) with a 12V solenoid. Simple swap and the solenoid was only like $12 then. Worked great until the 1385 was worn out at nearly 750K miles. Then I upgraded to a 1600 and put in an SR17 (brain fade...I think that's the correct designation for the self supporting auto stick starter). Had to replace that with another same somewhere around 900K miles. Now has 956K. 3rd starter motor.
Richard
SoCalBajas Member
bastardbus
PostPosted: Thu Jun 23, 2022 8:51 pm    Post subject: Re: 12v Starter on 6v Flywheel Conversion Reply with quote
Did you do the "stacked" bushing trick or something else?
I took apart a 6V and 12V starter today and it looks to me it would take a 14mm od by 11mm id bushing to do a direct conversion without stacking. I have looked around online but no luck finding a suitable bushing/bearing. Anyone have any tips on supplier?
Samba Member #95
fl59bug
fl59bug is offline
PostPosted: Fri Jun 24, 2022 4:20 am    Post subject: Re: 12v Starter on 6v Flywheel Conversion Reply with quote
Bastardbus sorry to take this a bit off-topic but I looked at your joined date and wow, July 13 2000! You're "O.G" here on thesamba. much respect! 🙂
Seb67
Seb67 is offline
PostPosted: Fri Jun 24, 2022 1:35 pm    Post subject: Re: 12V Starter on a 6V Flywheel with No Changes Reply with quote
THIS
1964 Type 1
Wayne S. Johnson
PostPosted: Fri Jun 24, 2022 4:37 pm    Post subject: Reply with quote
Over 200 Hybrid starters sold in the last 12 years. Not one has failed or needed rebuilding.
The warranty covers starters against defects in materials and workmanship for a period of one year from the date of purchase.
vwpieces Premium Member
vwpieces is online now
PostPosted: Mon Nov 03, 2025 7:47 pm    Post subject: Re: 12v Starter on 6v Flywheel Conversion Reply with quote
I have found the 11mm ID x 14mm OD bushing to make this work without stacking your worn out bushings
Thumbs Up Thumbs Up for DIY
I have a limited supply available
https://www.thesamba.com/vw/classifieds/detail.php?id=2770502
68 BUS
83 JETTA TURBO DIESEL
83 2dr JETTA 16V
81 Turbo Diesel Jabbit
