allamaabroad Samba Member
Posted: Mon Dec 05, 2022 1:52 pm Post subject: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
Gauging interest:
I’m developing a crank trigger wheel and sensor for my own project, I’ll be getting the parts made soon here and I’m wondering if anyone may be interested in it.
Kit will include a trigger wheel that mounts to the front of the pulley, VR sensor, sensor bracket, and longer crank bolt for roughly $110. Price could come down to roughly $90 with enough quantity
This will require no machining, direct bolt on and go for half the price of other systems.
All parts will be CAD plated or otherwise finished.
The sensor being used is very common and can be found at almost any local auto parts store, so no getting stranded if the sensor goes bad.
I’ll post up the drawings later for those that may be interested. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3321 Location: Hamble, Hampshire, UK
Posted: Mon Dec 05, 2022 2:18 pm Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
I have been working slowly along similar lines - buying a more generic trigger wheel, cutting a larger hole 1 7/8" diameter in the centre and welding it to a 2 1/2" disc of 1/16" sheet steel to keep using a standard length pulley bolt..
One concern I have which I currently am still considering is how to lock the trigger wheel to the pulley. (I am currently thinking of drilling and tapping two holes in the trigger wheel 180 degrees apart that go into holes in the pulley, not fixing holes but alignment. Or using grub screws into dimples in the pulley hub)
I dont know what you have considered, I am just describing my thoughts.
I sit there with a spare pulley and the timing wheel and a digital caliper thinking where to drill ..
There are two reasons - one being that as you tighten the pulley bolt, keeping accurate timing will be difficult, especially if you ever have to remove the crank pulley.
The second, less likely I can imagine is something like the belt jumping off, grabbing the trigger wheel and pulling it out of timing on the way off the pulley. This is in my mind because of a recent nightmare with a toothed belt that wore out in about 300 miles, then started jumping off, leaving me with another new spare toothed belt and a journey of 250 miles. (eventually I woke up at 4am in a hotel room, realised I had trapped a solid V belt when I did some wiring for a refrigerator, recovered that belt at sunrise in the hotel car park, and drove home no problem)
My target is an EDIS-4 wasted spark based system (limp mode is attractive ) with a custom microcontroller for centrifugal and vacuum advance. _________________ Ancient vehicles and vessels
Posted: Mon Dec 05, 2022 3:05 pm Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
mikedjames wrote: |
My target is an EDIS-4 wasted spark based system (limp mode is attractive ) with a custom microcontroller for centrifugal and vacuum advance. |
My design closely mimics the design of the CB performance kit. The wheel will be keyed to the pulley, and fit to the bore of the pulley as well. This prevents the wheel from rotating on its own and also keeps it concentric.
If you’re interested, the wheel by itself will likely cost just a hair more than the generic wheels, potentially less if I get enough interest. |
esde Samba Member
Joined: October 20, 2007 Posts: 6335 Location: central rust belt
Posted: Mon Dec 05, 2022 3:23 pm Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
Will it still fit inside a stock pulley tin? _________________ modok wrote:
Posted: Mon Dec 05, 2022 3:30 pm Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
esde wrote: |
Will it still fit inside a stock pulley tin? |
Yessir. Wheel diameter is gonna be roughly 5.5” and stick out .5” from the face of the pulley. With the tin I have (pretty certain it’s OG VW), there’s loads of clearance. |
EVfun  Samba Member
Posted: Mon Dec 05, 2022 3:54 pm Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
This would be more interesting if it was a complete kit, a bolt on and plug in system to eliminate the distributor. We are seeing some programmable distributor options, if crank fire was a price step above that it would look attractive. (Especially for the person who accidentally chews up the distributor crank gear.) _________________
Wildthings wrote: |
Posted: Mon Dec 05, 2022 4:04 pm Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
EVfun wrote: |
This would be more interesting if it was a complete kit, a bolt on and plug in system to eliminate the distributor. We are seeing some programmable distributor options, if crank fire was a price step above that it would look attractive. (Especially for the person who accidentally chews up the distributor crank gear.) |
Certainly could consider doing this, using microsquirt or megajolt and making a sort of kit.
For the time being, the audience would be more directed towards those that are making the switch to EFI or some form of electronic engine management. |
modok Samba Member
Joined: October 30, 2009 Posts: 27672 Location: Colorado Springs
Posted: Mon Dec 05, 2022 9:00 pm Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
Nicely PLATED trigger wheel is a very good idea to keep it from rusting.
Not a big deal but a FINE detail.
powdercoating CAN BE too thick, I learned that.  |
Posted: Mon Dec 05, 2022 10:18 pm Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
modok wrote: |
Agreed, that's why everything steel will be CAD plated...just have to figure out whether to do zinc or black, the black plating looks quite nice.
All other parts will be 6061 aluminum. I wanted to do anodizing on them, but the parts are physically too small for anyone to be interested in anodizing them for me. |
Posted: Tue Dec 06, 2022 4:01 am Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
That looks really nice, thanks for sharing. _________________ Ancient vehicles and vessels
Posted: Fri Dec 09, 2022 10:24 pm Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
Some updates:
Design has been refined, trigger wheel is much smaller.
Working on 3d printing everything now to check the design on a real engine.
Crank sensor bracket is still a WIP and the sensor may end up being moved over to the right and tilted 10 degrees or so to allow for better belt clearance with different size pulleys.
I'll be taking orders hopefully by the end of next week, if you're interested feel free to send me a PM. |
Posted: Wed Apr 05, 2023 12:43 pm Post subject: Now Available: Cheap New Bolt-on Crank Trigger kit |
Finally back with an update, and it's a big one:
I got my bus up and running on full EFI about 5 weeks ago and have put about 1000 miles on it without any major hiccups. I feel totally confident about this crank trigger setup I've created, so now I want to offer up what I've made to those who are interested.
Here it is setup on my personal engine. My setup provides a clean look while still showing off that the engine is running crank trigger.
The trigger wheel is a 36-1 toothed wheel made from 3/16" black zinc plated steel. The wheel is attached to a 6061 aluminum hub that keys to the front of the crank pulley. This allows for repeatable alignment and near perfect concentricity of the wheel.
Crank sensor bracket is made from 3/16" stainless steel and CNC bent. It bolts to the top two 8mm case half studs and features a jacking screw for vibration reduction and fine tuning of the sensor gap. The sensor itself is a VR sensor from a Chevy Aveo and can be found at most local parts stores. The bracket fits all pulley sizes from power pulley to 7" without interference.
Finally we have the distributor plug. I wanted something that was super functional and low profile and would blend in with the curves of the case. This cap is held in place using the original stud and is made from 6061 aluminum to blend in with the engine case. Unlike other distributor plugs, this is low profile and positively attached to the block, so it doesn't stick out like a sore thumb and there is no possibility of it popping out. The plug accepts stock VW distributor seals.
This kit is available for sale now.
Compatible with T1 engines with all common crank pulley sizes.
Compatible with all aftermarket ECU's (Megasquirt, Microsquirt, Megajolt, Haltech, Speeduino, etc.)
100% bolt on, no machining, no special pulleys, and no modifications required
Kit includes:
- Trigger Wheel
- Extended Crank Pulley Bolt & Washer
- Crank Sensor Bracket
- Crank Sensor
- Crank Sensor Plug (3 pin EV1)
- Distributor Plug
- Installation Hardware
$115 for the kit with shipping anywhere in the US included.
For more info or to order a kit, feel free to PM me or see the classified ad below.
https://www.thesamba.com/vw/classifieds/detail.php?id=2610814
I'm super excited to offer a more affordable way to bring the goodness of EFI to our VWs. Countless hours have gone into developing a quality product with low cost manufacturing to produce a high quality setup with simple DIY installation and pricing nearly half that of comparable setups.
I look forward to hearing from all those that are interested
- Adam |
19-VW-74 Samba Member
Posted: Wed Apr 05, 2023 9:29 pm Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
I think this is pretty sweet. I’ve been thinking of going with crank trigger ignition when I switch to dual idfs because they don’t produce enough vacuum for an SVDA.
Now that the CB Black Box is up to $250, crank trigger is looking even better. With this kit, a Speeduino, and a “New Beetle” 4 post coil, you could have crank trigger for under $350, with the ability to go to EFI later. About the same as the Black Box and a locked cheapo 009.
Couple questions:
Is the trigger wheel press fit on that aluminum hub, or just clamped over the pins with the crank bolt? Are the pins an interference fit? How precise is the fit with the keyway? Within a degree of rotation?
Is there any adjustment for the VR sensor to dial in TDC? Shim it with washers? Or is that all done in the software anyways?
Does this kit work with a stock stamped steel pulley?
Is the distributor plug several piece bolted together? Or pressed together? Is it steel or aluminum?
Is there any concern about the distributor drive gear rubbing against the distributor plug?
Somewhat unrelated question: what are you using for throttle bodies on your setup? Curious how you are doing idle control? _________________ -Austin
My 1974 Standard Beetle Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=492617 |
Posted: Wed Apr 05, 2023 10:23 pm Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
19-VW-74 wrote: |
Couple questions:
Somewhat unrelated question: what are you using for throttle bodies on your setup? Curious how you are doing idle control? |
All excellent questions! The main thing with the design of this is that it was all designed around being laser cut from flat stock, so that's why there's some different design choices.
Quote: |
Is the trigger wheel press fit on that aluminum hub, or just clamped over the pins with the crank bolt? Are the pins an interference fit? How precise is the fit with the keyway? Within a degree of rotation? |
The dowel pins are a press fit. They're mainly for positioning, but they do keep the assembly together pretty well. What truly holds everything together is the crank pulley bolt. The fit to the keyway is very tight, to the point where I've had to tweak the fit on a couple of them. I've had the trigger wheel off and on my engine a handful of times and the timing has remained exactly the same. It's definitely within a degree or less.
Does this kit work with a stock stamped steel pulley? |
Having the sensor exactly on TDC is not necessary, but I do include some washers as shims to help with alignment. The actual alignment itself is done in the EFI software with trigger offsets (This wheel has a 88-89 degree offset). The kit works with all pulleys, stock pulley won't be a problem at all.
Is there any concern about the distributor drive gear rubbing against the distributor plug? |
Distributor plug is multiple pieces bolted together. It's all well sealed together with a good quality thread sealant, and the fit of the plug is very good. I've had no problems with leaking on this design.
As far as the distributor gear goes, this design (like almost all others on the market) requires that the drive gear be removed. They're just aren't any good reliable options for keeping the gear in place without it causing damage.
Throttle bodies are 45mm SherryBerg units. They're from Aliexpress and do come with a handful of issues out of the box, but I was able to fix them up by throwing $30 and a couple hours of my time at them. When I bought them they were less than $200 for the pair.
Idle control is done through ignition timing in Tuner Studio. The throttle bodies have adjustable stops just like an IDF carb.
I see you're in Utah? I bet I've got a couple things you'll be interested in. Shoot me a PM and we can chat. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4054 Location: San Diego
Posted: Thu Apr 06, 2023 7:48 am Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
Minor detail, but most cases will need longer studs to mount the sensor bracket.
And I see them in the kit now |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4934 Location: Stuck in Ohio
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1405 Location: North Carolina
Posted: Thu Apr 06, 2023 1:48 pm Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
OK School me! I’m 64yrs old and all my VWs over the last 40 yrs have basically run with dual Webers or Dells, 009s & Bosch blue coils. As I near completion of my 2332 which initially will be carbed with a set of NOS 48 Dells, Mallory dizzy & Bosch coil I find myself wanting more in terms of ignition especially since I plan to convert to turbo once broken in. I currently have a new in the box MSD dizzy that I was planning to lockout, combine with the Blackbox and perhaps the new Miller ignition CD that I’m patiently waiting on test results from JPaull as my turbo ignition.
However this crankfire opens up new options. I’m someone who doesn’t want to go thru the learning curve or have to purchase a labtop to create custom ignition maps and I’m sure I’m not the only one. So my question is can I combine this crankfire setup, with the backbox and use one of the maps within and the Miller Ignition if it gets the thumbs up and keep on trucking(dubbing)?
Thanks |
jvwgarrett Samba Member
Posted: Sun Feb 23, 2025 5:21 am Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
are you still selling these? |
BFB Samba Member
Posted: Sun Feb 23, 2025 8:42 am Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
I wouldnt even use OP to take out my trash or give him any suggestions of how to do it, this guy scammer.
Remember he came out with the knock off Black box in the 3D printed cases?
I DM’ed him one day and said i had an idea and a whole new market he could sell his boxes to, and that id be interested in partnering up if he was.
He agreed to working out an arrangement and said he’d send me a couple free boxes to get things rolling.
After i explained to him that what the boxes lacked was the ability to time single and twin cylinder engines ( i had already discussed this with C.B. 1st FWIW .. ) and leaves a whole market of small engine racers untapped. I had a friend who built engines for race carts and he said they will mill the heads and run something 12:1 CR but theres nothing much they can do with timing so they run methanol.
So anyhow, after this discussion and arrangement agreements allamaabroad just ghosts me, no contact at all despite me sending numerous DM’s , and he was visiting the Samba because id seen his “ last visited” and he’d been here , just ignored my DM’s.
I may be a dick, but im no liar nor thief , if i make a deal with a man ill follow through come hell or high water. Obviously allamaabroa is not and does not, yall take it for what you want _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
94touring Samba Member
Joined: October 24, 2020 Posts: 506 Location: Tulsa - OK
Posted: Sun Feb 23, 2025 9:02 am Post subject: Re: Gauging Interest: Cheap New Bolt-on Crank Trigger kit |
jvwgarrett wrote: |
Appears he got out of the game. I have one of his fuel injection kits sitting in a box I never got around to playing with. |
