mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2952 Location: North Carolina
Posted: Thu Dec 08, 2022 6:08 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
Dave I seem to remember changing this seal without totally pulling the engine. I think I strapped the transaxle up and/or put it on a jack (can't remember when I bought my transmisison jack), hung the engine from the crane, unbolted the moustache bar and TC, and was able to swing everything around enough. I seem to recall that this way I did not have to undo all the hoses etc and it was significantly easier. I think I also had to remove the muffler shield, maybe a couple other things. Could I be wrong? Absolutely. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
Posted: Thu Dec 08, 2022 6:26 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
| danfromsyr wrote: |
even more reason to install a poly vinyl garage  |
Besides the obviously visual of a tent garage, there is also a lack of flat land to set one up on.
My entire lot slopes down from the street, eventually draining into the Schuylkill River.
Anyway, the morning dawns, upper 40's with a forecast for Sun and temps in the 50's.
Looking at some of my hoses, they show oil damage on some and an abraded spot on the main return hose over the transaxle.
It was rubbing on the accelerator rod from the transmission. It is well worn, this was a disaster waiting to happen.
There always seems to be an upside to things going wrong if you look for them.
This may explain my sluggish throttle body return too, it would not always return to idle and I was blaming the cable from the pedal.
A trip to BusDepot (1 1/2 hrs round trip) is clearly in my future. It is a pleasant drive through the countryside to get to their new place...... all is good.
Ironically the abrasion was caused by BusDepot's stainless steel pipes.
I didn't like how they fit when I installed them and I did the best I could getting them in. The return pipe sits a tad long, it is pushing the hose towards the rear and against the transmission. I'll need to be extra careful putting on the new hose, maybe even trimming it a tad shorter.
So.......
In their defense it could be on me for poor installation, 🤷♂️
I had no instructions, the pipes were not marked in any way that made sense to me and despite a phone call asking...... I bumbled through it the best I could. I admit I was tired and it was cold, I just wanted that Van on the road by the time I got to those pipes.
Now, to Finish my coffee and off to the salt mines!
Ghia
Vanagon
Beetle
Posted: Thu Dec 08, 2022 7:00 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
| mikemtnbike wrote: |
| Dave I seem to remember changing this seal without totally pulling the engine. I think I strapped the transaxle up and/or put it on a jack (can't remember when I bought my transmisison jack), hung the engine from the crane, unbolted the moustache bar and TC, and was able to swing everything around enough. I seem to recall that this way I did not have to undo all the hoses etc and it was significantly easier. I think I also had to remove the muffler shield, maybe a couple other things. Could I be wrong? Absolutely. |
Thanks for the suggestion,
I plan on simply removing the axles, dropping it all as a unit, undo the engine bolts and move it just enough to get the new seal in.
I don't want to "accidentally" stress the aging wires or tug on hoses.
I use a homemade engine hoist to hang and manipulate the engine around.
Ghia
Vanagon
Beetle
DuncanS Samba Member
Posted: Thu Dec 08, 2022 9:02 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
Groan--the mere thought of this makes my circumphericals ache. A job that makes my singe wire--someplace--issue pale by comparison.
Good luck, Dave. Your car will thank you for the early Christmas present. Add a ribbon to help him/her/they/it feel the holiday spirit and you will be rewarded by 30 miles to the gallon.
Duncan |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17282 Location: Brookeville, MD
Posted: Fri Dec 09, 2022 6:48 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
Don't worry, Dave. I just talked to the electrician and he will have the heat on in the new garage we built on your neighbor's property by 10 this morning. I already called AAA and they are moving your car on my account. Should all be toasty by 11.
It's 14 outside up here this morning and I'm going out to the unheated garage to try to sort out the no start later on. Haven't started up the wood stove inside.
An early Merry Christmas from the weather gods.
Good luck with it.
Duncan |
space Samba Member
Posted: Fri Dec 09, 2022 7:04 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
| DuncanS wrote: |
Good luck with it.
Duncan |
Do you have to pour thicker pads for the lift? _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
4Gears4Tires Samba Member
Posted: Fri Dec 09, 2022 7:26 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
I used to run one of these, they are extremely loud due to the heavy duty fan used. They certainly put out some BTUs. I would turn it on, go make and eat breakfast, and come back to a warm garage. Things would slowly get colder over the hours but I'd always be hesitant to turn it back on due to noise.
I much prefer this style. I'd run through a tank in a weekend if I was working in the garage the entire time.
https://www.homedepot.com/p/Mr-Heater-Tank-Top-45-.../304907200
_________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
space Samba Member
Posted: Fri Dec 09, 2022 8:15 am Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
Im using a Berko electric heater Keeps my garage VERY comfy
its more like a small furnace w/o the fumes _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2744 Location: Philly, mang
Posted: Fri Dec 09, 2022 1:56 pm Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
hurry up, we need to know where the next drip is coming from  _________________ 1991 Vanagon GL Camper
i had no idea i wanted to be a mechanic |
Posted: Fri Dec 09, 2022 4:18 pm Post subject: Re: HERE WE GO!! .... 1990 Tintop! |
Did I finish?
One word answer?
No.
I invested a surprising amount of time into playing with my Stainless Steel cooling pipes.
They were ill fitting when I installed them and they actually created a coolant hose rubbing situation that could have been catastrophic.
I loosened clamps, I rotated pipes, I pushed, I wiggled, I cussed a little bit but once the dust and foul words settled, the fit is acceptable, not great, but I've got all the hoses clear of obstructions.
I'm not thrilled with the kit but it is now simply okay........
(My original plastic pipes were rendered unusable by repairs done by a PO)
What is left?
*Add coolant and bleed.
*Hook up left axle
*Remove right axle and replace torn boot
*And an optional extra, change the engine oil.
Half a day tomorrow.
Engine back in........(God is under it lifting it into place, thus the heavenly glow) (actually it is the Sun shining under the Van, thanks low Winter Sun angle)
Thanks to my home made engine hoist, installing this engine was a painless breeze!
As always, this has taken longer than anticipated but..........
Ghia
Vanagon
Beetle
