bigdirt09 Samba Member
Posted: Tue Jan 01, 2019 7:55 am Post subject: Re: Sekurit vs. Sigla glass |
| My 60 panel has which I’m pretty sure all original glass. Has sekurit every where except front windshields are Delog. |
Joined: April 27, 2002 Posts: 6880 Location: Pentwater, Michigan
Posted: Fri Jan 04, 2019 9:01 am Post subject: Re: Sekurit vs. Sigla glass |
| oakman wrote: |
Tim, is that the piece from your 57' Kombi? That's a cool one! |
Yes, 1957 Kombi. All of the glass is Sigla, even the windshields which could have been replaced at some point.
There are no pinholes anywhere near the two snowflakes. It has to be a defect in the plastic. I'd agree with heat being an agent in the creation. The bus sat outside in the high Mojave Desert for many years- Littlerock, CA, home of the EZ Camper.
_________________ Roads Scholar
Member# 2059 |
mdege Samba Member
Joined: January 16, 2018 Posts: 1113 Location: Niederkruechten, Germany
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Sun Feb 09, 2020 10:35 am Post subject: Re: Sekurit vs. Sigla glass |
Resurrecting an old thread.
I have seen no discussion of date codes on any of the glass.
While re installing glass on the 306 Kombi, I came across this stamping on the edge of the glass.
Appears to me to be a date code. It read 12 U 9
Any insight on this?
As another data point to the general discussion, unmolested Sept 58 Kombi has a mixture of
SIGLA
AS-1
and
SIGLA
AS-1
D06
glass all around No pattern as to which windows have which logo with the possible exception of both popouts are D 06. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
John Ghia Samba Member
Posted: Thu Sep 10, 2020 7:40 pm Post subject: Re: Sekurit vs. Sigla glass |
Does anyone know if the slider glass share the same dimensions? Can I use a Sekurit glass as a pattern for a Sigla slider? _________________ BUS BOYZ |
Posted: Thu Sep 10, 2020 7:47 pm Post subject: Re: Sekurit vs. Sigla glass |
| John Ghia wrote: |
| Does anyone know if the slider glass share the same dimensions? Can I use a Sekurit glass as a pattern for a Sigla slider? |
Yes
Original glass is 5mm thick and most replacement glass available now (here at least) is 6mm.
I used 6mm glass in the kombi with original seals and it fit fine.
Might be a little tight with new seals?
Just something to be aware of. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Posted: Thu Sep 10, 2020 8:17 pm Post subject: Re: Sekurit vs. Sigla glass |
Thanks Riff Raff. Yes I’ve been looking for 5mm laminated glass and have only found tempered glass in 5mm. I wasn’t t sure if the overall outside shape was exactly the same, Sekurit vs Sigla. So now I can take the Sekurit to the glass shop and have them copy it, minus the holes. _________________ BUS BOYZ |
greentoad Samba Member
Posted: Wed Nov 25, 2020 3:53 pm Post subject: Re: Sekurit vs. Sigla glass |
| mdege wrote: |
| On German buses it's Securit all around, unless you special ordered laminated windshields. The M-Code for that was 090 |
I've got most of the securit glass from a 15w euro, there's side glass, door glass, rear corner glass and hatch glass. Pretty sure the safaris are securit too and these are laminated, were the special order euro windshields securit, been trying to work out the glass for years. |
Douglas Denlinger Samba Member
Joined: May 23, 2003 Posts: 1410 Location: Arizona's version of the east coast
Posted: Sat Oct 01, 2022 2:35 pm Post subject: Re: Sekurit vs. Sigla glass |
September of 60, US spec bus, would the windshields be Sigla or Delog....over all consensus?? Thanks _________________ Transporter Restorations
Upholstery Haus
Active 23 Window Samba Collector/Restorer,since 1986 |
House Minutia Militia
Posted: Mon Jan 09, 2023 12:17 am Post subject: Re: Sekurit vs. Sigla glass |
| I believe it would have come with Sigla ~~ D 06 windshields. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 72023 Location: Phoenix 602
volksbus Samba Member
Joined: November 02, 2005 Posts: 222 Location: Chicago, Illinois U.S.A.
Posted: Tue Jun 04, 2024 7:36 pm Post subject: Re: Sekurit vs. Sigla glass |
Help. I'm trying to find.a drawing with dimensions for my front windscreen glass, 1967, not safari. _________________ "Get in the bus!"
1967 SO-42 Campmobile "Klaus"
1963 DC Truck
1967 Dodge A-108 CampWagon |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26422 Location: Olympia Wash Rinse & Repeat
Posted: Thu Jun 06, 2024 11:42 am Post subject: Re: Sekurit vs. Sigla glass |
| volksbus wrote: |
| Help. I'm trying to find.a drawing with dimensions for my front windscreen glass, 1967, not safari. |
The window opening is your best bet if you do not have a piece of example glass handy. Use a piece of cardboard to trace it out. Then someone should be able to give you the top to bottom dimension. Say just for example that measurement is 6 mm more than your tracing, then add 3mm all the way around to your template. _________________ In Stereo, Where Available! |
Posted: Mon Jun 17, 2024 7:34 am Post subject: Re: Sekurit vs. Sigla glass |
Correct measurements from a glazer:
Notes taken from both an OG surviving windscreen and a re-cut that was in my bus more than 30 years.
1963 DC Truck
