donjordan Samba Member
Posted: Mon Sep 05, 2016 5:36 pm Post subject: New to Vanagons and abruptly shut off on me. [SOLVED] |
Hi all,
I bought a 1985 vanagon (digijet) a couple months ago and I had a sudden loss of power a couple weeks ago while on the freeway. I've been following diagnostic procedures but need a little help.
PROBLEM
I was driving on the freeway and after driving ~30 miles the engine just shut off. Almost like a switch got flipped. While I was waiting around for the tow truck I decided to try to start the van (about 30 minutes after initial shut off) and it started up. It ran great so I decided to drive the rest of the way to my destination. Later that night I was driving home and after approximately 30 miles, the same thing happened. I waited thinking that maybe a component was getting hot and needed to cool down but I could never get it going again. Towed home.
WHAT I KNOW
The engine is getting enough air and it does have spark (it will fire if I spray starter fluid in the intake). I have hooked up an oscilloscope to the fuel injectors and cannot see a pulse while cranking. This is my problem, but why? Based on research, the ecu sends pulses to the injectors based on the hall effect signal, but since there is spark I assume that the hall sender is operational.
Also, fuel pressure is ~31 psi.
WORK DONE SO FAR
After doing research on this site and elsewhere on the internet, the problem to me seems to be electrical. I started by cleaning all of the ground connections, replacing TempII sensor, ignition switch and took a gamble and had the ecu rebuilt. It still does not run.
QUESTIONS
Is bench testing the AFM a good indication of its performance during normal operation? I measured the resistance of the wiper strip, air temp, and applied an external voltage to measure the wiper voltage output. All looks good, no drop of voltage anywhere.
Another thing that I was looking into was the hall effect sensor. According to what i've read, I should be seeing 0 to 2V minimum as the engine turns over. I am measuring 2V to 7V. This is out of spec but I'm getting spark. Does the hall effect sensor control spark or fuel, both?
Thanks!
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10322 Location: Mt Lemmon, AZ
Posted: Mon Sep 05, 2016 6:32 pm Post subject: Re: New to vanagons and abruptly shut off on me. |
I had a similar failure and it was a relay that heat got to. It would cool down and work again but I replaced it before it got to the point of total failure.
In my case it was the fuel pump relay - but since you have pressure that is not your problem. But there is another relay right next to it in that same black box:
I'm thinking that other one (the outboard one IIRC) is for the ECU. You might confirm it is okay (or not) with a simple substitution if you have a spare or by jumpering the socket if you don't. |
Californio Samba Member
Posted: Tue Sep 06, 2016 10:06 am Post subject: Re: New to vanagons and abruptly shut off on me. |
In my experience, the AFM doesn't usually cause a sudden failure like that. They wear down and you get Vanagon syndrome (coughing, bucking, etc.) but not usually total failure to start.
A failed Hall Sensor or a broken wire to it could cause the symptoms you're talking about, |
Posted: Tue Sep 06, 2016 10:08 am Post subject: Re: New to vanagons and abruptly shut off on me. |
| Well no, actually--if it started again when cool, probably not the Hall Sensor. |
RicoS Samba Member
Posted: Tue Sep 06, 2016 10:30 am Post subject: Re: New to vanagons and abruptly shut off on me. |
| Californio wrote: |
One thing Ive realized over the years, you cannot say anything definitive about a failing Hall SENDER. Hot or cold, wet or dry, new moon or full, a queefed out Hall Sender can cause everything from a hard start to an instant shut down.
If the Hall Sender is about to shit the bed, the tach will drop like a rock to zero whenever the engine dies - like a switch was flipped.
Richie |
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2157 Location: Plymouth, MA
Hammy1 Samba Member
Posted: Tue Sep 06, 2016 11:55 am Post subject: Re: New to vanagons and abruptly shut off on me. |
I too had issues with one of the relays. It would run fine but when I shut it off it wouldn't start until it cooled down. I also wasn't getting injector pulse during cranking. It's worth a try.......
Regards'
Jon h. |
Posted: Fri Sep 09, 2016 7:48 pm Post subject: Re: New to vanagons and abruptly shut off on me. |
UPDATE
I installed a new hall sensor tonight and she started right up! Thanks for all of the insight.
Don |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1509 Location: Deep South of the Great White North
Posted: Fri Sep 09, 2016 8:00 pm Post subject: Re: New to vanagons and abruptly shut off on me. |
Excellent news,.
I had a similar experience and resolution...
http://www.thesamba.com/vw/forum/viewtopic.php?p=7984468 _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
RicoS Samba Member
Posted: Sat Sep 10, 2016 8:11 am Post subject: Re: New to vanagons and abruptly shut off on me. |
| donjordan wrote: |
UPDATE
Don |
A " [***SOLVED***] " tagged onto the subject line would be a nice thank you.
Richie |
Posted: Sat Sep 10, 2016 12:46 pm Post subject: Re: New to vanagons and abruptly shut off on me. |
| ftp2leta wrote: |
We have another thread going on... please change your title to SOLVE.
I read the whole thread for nothing
Ben |
Updated with new title. Sorry that you had to read the "whole" thread for nothing. Hope I didn't waste your whole day. |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Sat Sep 10, 2016 2:53 pm Post subject: Re: New to vanagons and abruptly shut off on me. |
| ftp2leta wrote: |
Ben |
Please see that the original poster is a very new member of Samba and he may not have known to insert a SOLVE...( really its SOLVED ) to his latest post. As far as reading it for nothing ben, you didn't. You added a rude comment which does count for something.  |
JustsomeKentuck Samba Member
Joined: July 19, 2016 Posts: 69 Location: Louisville KY, y'all!
Posted: Sat Sep 10, 2016 4:49 pm Post subject: Re: [SOLVED] New to vanagons and abruptly shut off on me. |
Perhaps he wasn't being rude, but was just making a suggestion. IDK, but it didn't seem rude to me.
Perhaps a Smiley Face Emoji and everyone wouldn't of gotten so worked up.
Ah, the Internet. Hard to judge intention in such few words. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 72020 Location: Phoenix 602
Posted: Sat Sep 10, 2016 5:00 pm Post subject: Re: [SOLVED] New to vanagons and abruptly shut off on me. |
Thanks for adding a SOLVED thing to the title.
This is nice sometimes.
Don't worry about the comments above, sometimes it's hard to know people's intents from text.
In general I assume the best of people until I discover otherwise.
This has served me very well in life. _________________ How to Post Photos
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
RCB Samba Member
Posted: Sun Sep 11, 2016 7:28 am Post subject: Re: New to vanagons and abruptly shut off on me. |
| ftp2leta wrote: |
| donjordan wrote: |
Many thanks and also welcome!
No I was not rude at all. Yes I can be and was to many time here, but I'm older now
Ben |
Greetings ben, I think rude may have been the wrong word to describe your original comment. Considering your valuable contribution to The Samba and the wisdom you so frequently share with its members, I could have substituted the word surprised instead of rude. My sincere apologies if I offended you or any readers and please...please, continue posting when you have the time and energy. |
