Brake Switch
vanderjw
vanderjw is offline
PostPosted: Sun Mar 19, 2023 5:03 am    Post subject: Brake Switch Reply with quote
Quick questions about the brake lights:
-The master cylinder has 3 ports on the front. I assume one for each front brake line and one for the switch. If that's right, then I plan to put the switch in a port on the left side facing down at a 45 degree angle.
-The wire to and out of the switch is 12v or ground. Seems like it should be 12v.
Thanks and I did search, did not feel like going through 356 results
Tom_Kathleen
Tom_Kathleen is offline
PostPosted: Sun Mar 19, 2023 6:34 am    Post subject: Re: Brake Switch Reply with quote
If you want a brake switch that lasts a lot longer than the OG type, try one of these - https://www.ecihotrodbrakes.com/inline-brake-light-switch . The switch never sees the brake fluid. You just need 2 1/8 npt to 1.0 brake line adaptors. https://www.carbuilder.com/uk/male-adapter-m10-x-1mm-f-to-18-npt-2 Tom
Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA
Dale M.
Dale M. is offline
PostPosted: Sun Mar 19, 2023 7:03 am    Post subject: Re: Brake Switch Reply with quote
Typically (most that I have seen) has brake light switch in the end port....
vanderjw
vanderjw is offline
PostPosted: Sun Mar 19, 2023 7:08 am    Post subject: Re: Brake Switch Reply with quote
Mine does not look like that. It is for a dual master cyl reservoir and has 5 ports. A quick search shows I probably have one for a super beetle with 4 wheel disc brakes, 20.6 mm. EMPI 2-2808.
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Sun Mar 19, 2023 8:22 am    Post subject: Re: Brake Switch Reply with quote
I also have that master.
Yes the TWO downward angled holes are for the two brake light switches.
modok wrote:
And look at the SHAPE of the curves, just smooth, like gods own slingshot. .
vanderjw
vanderjw is offline
PostPosted: Sun Mar 19, 2023 9:28 am    Post subject: Re: Brake Switch Reply with quote
Do you think I could just use 1 and plug the other?
Dale M.
Dale M. is offline
PostPosted: Sun Mar 19, 2023 9:30 am    Post subject: Re: Brake Switch Reply with quote
Do you mean this one...
IF so it takes dual switches if used in standard application...
vanderjw
vanderjw is offline
PostPosted: Sun Mar 19, 2023 9:33 am    Post subject: Re: Brake Switch Reply with quote
Dale M. wrote:
Do you meaqn this one...
Yes!
DeathBySnuSnu
PostPosted: Sun Mar 19, 2023 12:17 pm    Post subject: Re: Brake Switch Reply with quote
Yes you can plug one. Empi does have a 10 x 1 plug for that.
That being said.....I have not had much luck with the plug.. ..I had a two pack and neither seated and sealed right (leaked).
I wound up putting the second switch in the hole and bam.....no problems.
All depending on your electrical needs....warning lights ect.....you can choose a two pole or three pole.
I did not make an alarm light.....so two of the two poles to wire in parallel, so that either one can make the brake light circuit.
Q-Dog
Q-Dog is offline
PostPosted: Sun Mar 19, 2023 6:55 pm    Post subject: Re: Brake Switch Reply with quote
I only use one switch on my buggy. I took one of the brake light switches to a good old-fashioned hardware store and got a brass plug to match the threads. It's been leak free for about 10 years now.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
EVfun Premium Member
EVfun is offline
PostPosted: Mon Mar 20, 2023 8:39 pm    Post subject: Re: Brake Switch Reply with quote
This is the plug I used. I actually used 3 of them, one on each brake switch plug and one on the top outlet of the dual circuit master cylinder. The brake switch ones because I installed a mechanical switch on the pedal arm. The upper one so I could mount the Volvo master cylinder reservoir "backwards" with the side flat toward the firewall, because it's a bit shapely forward.
I see that number is out of stock now, you might be able to use BQ19, it is in stock and 3/8-24, that size *almost* interchanges with M10, but you cannot torque it too much or it strips.
Wildthings wrote:
jspbtown
jspbtown is offline
PostPosted: Tue Mar 21, 2023 9:44 am    Post subject: Re: Brake Switch Reply with quote
Or you could install both switches, use just one, and have one in place for one fails...which they always seem to.
vanderjw
vanderjw is offline
PostPosted: Wed Mar 22, 2023 12:22 pm    Post subject: Re: Brake Switch Reply with quote
Great Ideas...
I am looking for a double male adapter that is like a brake line on both ends. M10x1.0 by M10x1.0 Male/Male. Seems simple to find but for some reason I cant. If I have to use a short brake line, I will. Its to install the EMPI residual pressure valves I have.
BL3Manx
BL3Manx is offline
PostPosted: Thu Mar 23, 2023 6:58 am    Post subject: Re: Brake Switch Reply with quote
Plug off both ports and use one of these, they provide noticably faster brake lights and the microswitch is much more reliable than the non-German hydraulic switches sold now. https://www.thesamba.com/vw/classifieds/detail.php?id=2140061
y2kbaja
y2kbaja is offline
PostPosted: Thu Mar 23, 2023 12:37 pm    Post subject: Re: Brake Switch Reply with quote
vanderjw wrote:
Great Ideas...
I needed a male-male brake line adapter and just made a brake line 3" long.
