sctbrd Samba Member
Joined: May 06, 2013 Posts: 297 Location: Moravia, Czech Republic
Posted: Tue Jul 01, 2025 11:47 am Post subject: Torsion arm clips- source? |
My tire rubs the inner wheel well because the torsion arm stop is worn or was ground down in the past.
I just finished centering the steering box and doing the alignment, so I am sure there is nothing with the tie rod setup.
The stop is reduced on both sides.
The Bentley shows a clip that can be used to stop the rubbing.
Is there a source for a clip like this, before I try a more creative solution?
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23448 Location: Kimball, Mi
Posted: Tue Jul 01, 2025 12:43 pm Post subject: Re: Torsion arm clips- source? |
I don't know of anybody selling them (maybe ISP is). You might want to look thru the "local manufacturing" book to see if they show them there. It doesn't look to hard to make one. I'd also look thru the Samba classifieds to see if anyone is selling them (maybe the type 3 detectives?). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 4030 Location: San Jose, CA
Posted: Tue Jul 01, 2025 3:32 pm Post subject: Re: Torsion arm clips- source? |
Bobnotch wrote: |
I don't know of anybody selling them (maybe ISP is). You might want to look thru the "local manufacturing" book to see if they show them there. It doesn't look to hard to make one. I'd also look thru the Samba classifieds to see if anyone is selling them (maybe the type 3 detectives?). |
I've never really seen these during my time at ISP. I also can't remember the last time I've seen any come up for sale.
The local manufacturing book might be a good start. I can do a quick glance when I get some time. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Posted: Wed Jul 02, 2025 10:00 am Post subject: Re: Torsion arm clips- source? |
squaretobehip wrote: |
Bobnotch wrote: |
The local manufacturing book might be a good start. I can do a quick glance when I get some time. |
Yeah, those were my only thoughts on them or who might have them. I've never seen them in the wild in person either. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
sctbrd Samba Member
Posted: Wed Jul 02, 2025 10:20 am Post subject: Re: Torsion arm clips- source? |
Yeah, I thought he'd probably be one of the few places that might have them, if anybody did.
They're not really commonly used. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Jul 02, 2025 11:21 am Post subject: Re: Torsion arm clips- source? |
Nice! _________________ 1963 Notchback - Ruby Red
Follow ISP West on:
mdege Samba Member
Joined: January 16, 2018 Posts: 1066 Location: Niederkruechten, Germany
sctbrd Samba Member
Posted: Thu Jul 03, 2025 4:58 am Post subject: Re: Torsion arm clips- source? |
Mario has a set for me, thanks, might help the next person. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35999 Location: Conejo Valley, CA
Posted: Thu Jul 03, 2025 8:07 am Post subject: Re: Torsion arm clips- source? |
A long while (decades) back, I needed them on one side. Turns out I had a bent torsion arm, and when replaced, I didn't need it anymore. I'm pretty sure I chucked them a couple of moves ago. Really hurt the turning radius for u-turns.
Maybe a large thick worm clamp could add a little help there? You could add thin rubber under it to "tune" the thickness. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Posted: Thu Jul 03, 2025 8:46 am Post subject: Re: Torsion arm clips- source? |
KTPhil wrote: |
A long while (decades) back, I needed hem on one side. Turns out I had a bent torsion arm, and when replaced, I didn't need it anymore. I'm pretty sure I chucked them a couple of moves ago. Really hurt the turning radius for u-turns.
Maybe a large thick worm clamp could add a little help there? You could add thin rubber under it to "tune" the thickness. |
Yeah, that was my thought, along with having a beetle rim (wrong offset on that side). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
sctbrd Samba Member
Posted: Thu Jul 03, 2025 9:01 am Post subject: Re: Torsion arm clips- source? |
[quote="KTPhil"]A long while (decades) back, I needed hem on one side. Turns out I had a bent torsion arm, and when replaced, I didn't need it anymore. I'm pretty sure I chucked them a couple of moves ago. Really hurt the turning radius for u-turns.
The next part of the Bentley page says that is the turning radius is too large with the clips, you can grind the stops down, but to be careful of the clearance.
It looks to me a PO may have done this, since both sides look to be ground down and the same amount.
Unless they constantly slammed the steering against the stop on both sides very hard and wore them down that much!!
I wanted the clips, and if there is some reason they are too much for turn radius, Ill add a spacer of some other kind- the hose clamp is a great idea. |
