Door rubber pics and information
ted698
ted698 is offline
PostPosted: Mon Jun 30, 2025 7:45 am    Post subject: Re: Door rubber pics and information Reply with quote
I have to say the photo's on Page 1 of the various OG moulded NOS seals are a thing of beauty.... such a shame these are not re-man'd properly - I would buy a set for sure!
Another question I have is the seal for the front door tops, I have often seen a thinner seal located here with quite a concave surface, so the seal has a U shape moulded into it, with a flat bottom.
Some photos show this concave section outwards, so the frame top seals against it, others have it the other way around, so the square profile is against the frame, with the U shape innermost.
I had some on my late bus, and guess they were OG... does anyone re-man this shape seal?
Also the leading edge of the front portion of the main door seal was a different shape again, with a rounded edge, I guess to help with the door shut action to slide over the rounded portion of the seal.
I'm not convinced this current 'one size fits all' seal we all battle with is the most elegant solution! Rolling Eyes
Buskraut Premium Member
Buskraut is offline
PostPosted: Wed Jun 25, 2025 10:10 pm    Post subject: Re: Door rubber pics and information Reply with quote
volksbus wrote:
I am having a devil of a time finding the weatherstrip on the left.
I need the smaller, darker, less firm variety for the cargo doors on my 67 SO-42, for a variety of reasons.
I found out the hard way that both West Coast Metric and Wolfsburg West sell the same product (on the right).
That's weird... I bought a set from WCM in July 2024 and received the darker stuff on the left. I had a couple of issues: the pieces for the door tops were too short... they are supposed to taper as they approach the locking rods. I ended up grabbing pieces from another set and belt sanding the ends. The other problem I had was that the doors wouldn't close/latch until I thinned the long piece on the forward door. I took about 2mm off on the belt sander. Now everything fits great.
I recently bought a set from CIP1 and received the lighter stuff on the right. Haven't tried it yet, but it seems too narrow and will need gluing, although its soft and more compressible than the darker seals.
Erik S
'65 Type 251 / Deluxe
'03 Eurovan MVWK
BarryL Premium Member
BarryL is offline
PostPosted: Wed Jun 25, 2025 6:20 pm    Post subject: Re: Door rubber pics and information Reply with quote
Shopped here?
https://www.steelerubber.com/?srsltid=AfmBOoq0KYQ6EfFv0uARlCHlXvdUO9aUKIlm78Cd7ojLTeTUOT-YSnAh
volksbus
volksbus is offline
PostPosted: Wed Jun 25, 2025 5:15 am    Post subject: Re: Door rubber pics and information Reply with quote
Please help. All leads appreciated. Thanks!
"Get in the bus!"
1967 SO-42 Campmobile "Klaus"
1963 DC Truck
1967 Dodge A-108 CampWagon
DeadBlow
DeadBlow is offline
PostPosted: Mon May 26, 2025 9:29 am    Post subject: Re: Door rubber pics and information Reply with quote
Great.... Looks like I'll have to buy a new set of cargo door weatherstripping... I've installed the current kit according to the diagrams posted above by Everett, but forgot that the original was notched in the rear. so to try and fix it I shaved off the bulky portions that protrude out of the channel recesses. The Wolfsburg West stripping is stout and pretty firm. My door has been binding from the bulk of the stripping near the hinges and I've shaved more and more trying to get my door to close and it's just jacked now... And the door still won't close completely. I can barely get it to hold close but the latch doesn't engage completely and the pins at the top and bottom are not aligned to plug into their pockets in the body....
Is there another supplier that sells the stripping that doesn't use such firm, unforgiving material?
Buying things on the internet.... that's a sport!
1962 Doka
Pepperbilly
Pepperbilly is offline
PostPosted: Wed Sep 14, 2022 9:38 am    Post subject: Re: Door rubber pics and information Reply with quote
Those clips are the originals. They were used on SO42s but I don’t know about other camper models.
Bill
DUDE1125
DUDE1125 is offline
PostPosted: Wed Sep 14, 2022 9:24 am    Post subject: Re: Door rubber pics and information Reply with quote
Thanks for the insights Pepperbilly. The doors seemed to close fine with out the seals so I think the body work is reasonably good. It looks like the seals are too thick and I'll need to sand them like you suggested.
I like those clips that hold your cabinet in place. Do they have a name? I wasn't sure how I was going to place the cabinet back in the bus. I can't remember what was holding it if anything when I took it out years ago.
Thank you
Pepperbilly
PostPosted: Tue Sep 13, 2022 12:34 pm    Post subject: Re: Door rubber pics and information Reply with quote
The first thing you have to establish is your door fit without any seals in place. Hopefully your metal work is spot on otherwise this is gonna turn into a fight to get the seals to seal.
One of the big problems with new seals is that they are not the originals. New after market seals will be uncompressed and usually too thick. A good tool to have is a bench belt sander to sand whatever thickness you desire. I had to do this on several new seals.
Look at my photos and you can see the indent in the seal that you want. I was lucky and reused my original top double door seal. That is the type of indent you want to achieve on most all your seals. This shows the door is sealing properly.
You are pinching at top and bottom? The pinch should be even all across the top. If you are not getting that pinch indent all over then it may be the doors are not fitted correctly.
Bill
DUDE1125
DUDE1125 is offline
PostPosted: Tue Sep 13, 2022 11:38 am    Post subject: Re: Door rubber pics and information Reply with quote
sorry if this is a double post
here's a wider angle view of the dooor
Pepperbilly
PostPosted: Tue Sep 13, 2022 9:12 am    Post subject: Re: Door rubber pics and information Reply with quote
What door are we looking at here? Need a wider shot. It is not uncommon to make modifications to aftermarket seals.
Bill
DUDE1125
DUDE1125 is offline
PostPosted: Tue Sep 13, 2022 8:28 am    Post subject: Re: Door rubber pics and information Reply with quote
So I place my seals in as per the diagram and the door is pinching in the top and bottom corner. Is this common? I'm not sure if its my crappy body work shifted the hinge locations. I've tried adjusting the door location with no improvement. Is it as simple as trimming some foam off the corner?
thanks for any guidance
Pepperbilly
PostPosted: Wed Feb 09, 2022 1:19 pm    Post subject: Re: Door rubber pics and information Reply with quote
I used the WWest gray door seals on my ‘67 Westy. The front doors are the problem. I find the seals are not thick enough especially where the forward beltline “bulge” in the area of the rear view mirrors. I have water and wind leaks in that area. I noticed the original seals are overlapping and fill the space completely. The new seals are only one thickness. What to do?
Bill
BarryL is offline
PostPosted: Tue Jul 07, 2020 2:49 pm    Post subject: Re: Door rubber pics and information Reply with quote
robin.richard wrote:
So, without the left and right seals (on body) how does the rain stay out? Does it just run to the top of the rocker seal? Then where?
Just out and away whereas the mid-door gap has a hole in the rocker that leads to drains below.
robin.richard
robin.richard is offline
PostPosted: Tue Jul 07, 2020 1:41 pm    Post subject: Re: Door rubber pics and information Reply with quote
EverettB,
They seem to close fine, althoughlooking at the door gaps the upper/outer edge of the door is not perfectly flush like the lower edges of both doors. Less than an 1/8". This may be cause by not trimming the seals in the high spot area mentioned. I might try removing the seals tomorrow and see if there is a major change in alignment.
-Rich
Drive your bus!
PostPosted: Mon Jul 06, 2020 11:00 pm    Post subject: Re: Door rubber pics and information Reply with quote
If you put seals on the left and right up and down channels on the body, the doors won't shut.
Did you trim them or thin them down?
I've tried it before and there's too much seal there to allow them to shut if there's seals on the doors and the body
robin.richard
PostPosted: Mon Jul 06, 2020 6:21 pm    Post subject: Reply with quote
In response to someone's question in another thread, I am posting here since this thread is in the Bus FAQ.
For the cargo doors, the only rubber on the body are the 2 horizontal pieces that run across the top and bottom of the cargo door opening on the body.
Top center is the cargo door set up.
Top and Bottom strips are on the body
The rectangles are on the doors.
Okay, you learn something new everyday day - the cargo doors only use the upper and lower horizontal seal on the body for the cargo door opening.. That would explain why they were missing many years ago when I replaced my cargo door seals with a seal kit? I ended buying extra seals just to place them in the gaps I thought were missing seals.
Should I remove them? Why wouldn't VW put seals in those gaps?
-Rich
Drive your bus!
dirtyfrank
dirtyfrank is offline
PostPosted: Sun Jul 05, 2020 12:06 pm    Post subject: Re: Door rubber pics and information Reply with quote
I want to add my experience to this conversation. I bought the WW cargo door seals and made the mistake of not trimming out notches around the door pin areas and the hinge areas. This made my doors not close "true" and while trying to force them closed I accidentally broke the glass on one of my Hehr pop-out windows Mad . Definitely trim at least 2/3 of the back of the seal away around these areas, maybe even 3/4. I used a utility knife with a new blade and carefully sliced the seal to fit these areas and it worked for the most part. the doors probably will close better with removing as much material as possible, i'm hoping that keeping them closed for a few days will "train" the seals into place and the doors will close more easily. i have a 1959 double-door ez/sundial camper in (mostly) rust free condition, meaning the channels for the seals are in good condition.
easy e
easy e is offline
PostPosted: Sat Apr 01, 2017 4:03 pm    Post subject: Re: Door rubber pics and information Reply with quote
Just wanted to show how the upper/lower pieces of the weatherstripping for the cargo doors are.
It's tapered by about 1/8" thickness at one end.
Here's two 211 841 829 211841829
I thought the tapered area would be placed over a raised metal pressing in the base of the door weatherstripping channel.
But, what I thought was a little odd... is that it means the sharp cornered side of the seal is in the channel recess.
The sides of the cargo door opening (on the bus) have their weatherstripping placed with the rounded corners in the channel.
I guess there isn't a 'rule'... that sharp corners always in/out.
aka: Evan
easy e
easy e is offline
PostPosted: Sun Nov 30, 2014 6:26 pm    Post subject: Reply with quote
Looking at Neil's NOS cargo body seal up above... anybody ever use one of the concaved front door seals there?
I'm asking because the square profile ones that come in the kits seem too bulky.
aka: Evan
KombiMadness
KombiMadness is offline
PostPosted: Wed Aug 27, 2014 11:35 pm    Post subject: Reply with quote
kenshapiro2002 wrote:
With the OG front door seals, they were sliced and lap glued...over each other, where the body bulges out...just above the beltline. I'm using the new WW grey seals, and I'm guessing they should just be straight on glued in with no slicing and dicing? Like to hear from anybody who has installed the WW door seals as to whether they glued them in as a solid piece or did the factory type build up at that point.
Yes, on my 59 they were glued in as a solid piece, no slicing or dicing. Fit is good and they seal well.
My brother & I on the roof of Dad's Splitty circa 1967 - I'm the half pint with the skinny legs!
