DanHoug Samba Member
Joined: December 05, 2016 Posts: 5915 Location: Bemidji, MN
Posted: Tue Jan 30, 2018 5:56 pm Post subject: Re: gates barricade 5/16" fuel hose clamp |
Christopher nails it. i bought my Oetiker clamps based solely on the OD spec of the hose i bought.... mistake. they were too tight. you gotta measure the bump at the ferrule with the hose on.
i got the Oetiker on, but had to lube the hose with Sylglide to slide them over the ferrule bump.
-dan |
Posted: Tue Jan 30, 2018 4:30 pm Post subject: Re: gates barricade 5/16" fuel hose clamp |
Directly from the Oetiker catalog -
| Quote: |
Clamp Sizing
The following applies as a guideline: To determine the correct
clamp diameter, push the hose onto the attaching material, (e.g.
the nipple), and then measure the outer diameter of the hose.
Select a clamp whose average value of the size range is slightly
greater than the hose’s outer diameter. To ensure full ToothLock®
engagement and a sufficient closure of the clamp the nominal
diameter has to be reduced by at least 2.2 mm (> 40% of the
original ear width) and the correct closing force has to be applied
during assembly. |
Because different hose brands and models could have different wall thicknesses, it is necessary to measure instead of assuming one clamp size will fit all 5/16" hose (for example). _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
baltik Samba Member
Posted: Tue Jan 30, 2018 3:35 pm Post subject: Re: gates barricade 5/16" fuel hose clamp |
Bringing this back from the dead
what's the right way to size Oetiker clamps?
is it:
1. one size up from OD
2. one seize up from OD when installed over barb
3. OD should fall as close as possible to the middle of the Oetiker range
4. OD installed over barb should fall as close as possible to the middle of the Oetiker range
I have read that gates barricade OD is 14-14.5mm
here are the relevant clamps
16700013 12-14.5mm
16700014 12.3-14.8
16700015 12.8-15.3
16700016 13.2-15.7 |
1vw4x4 Banned
Posted: Fri Oct 10, 2014 10:44 am Post subject: |
You people really know how to spend money. Pinch clamps are available
in any size you want. That's the key. Beverage companies seem to need
a lot of these. They are typically stainless steel and are about .03 to .05 each. YES that is five cent.
Bars and restaurants use these all the time. I have about 4000 of these in maybe 6 different sizes.
THey work great, look great, and are cheap. |
rubbachicken Samba Member
Posted: Wed Oct 08, 2014 1:20 pm Post subject: |
those pliers are WAY to big for fuel line clips though.
i use just a regular pair of pliers, for the fuel line clips, those are for coolant hose clips _________________ lucy our westy
lucy's BIG adventure
meet 'burni' |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4778 Location: Arizona Highways
Posted: Wed Oct 08, 2014 1:19 pm Post subject: |
yep
no special tools required _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
kamzcab86 Samba Moderator
Posted: Wed Oct 08, 2014 9:47 am Post subject: |
go look under the hood on a new VW, these are all over the fuel lines, if you have the right size for the hose, they clamp very well, remember over tightening damages fuel line anyway, like i posted i put them on my van first, before using them on anyone elses, they are fine.
| Phishman068 wrote: |
Are those rated for fuel injection pressures?
I can't see how they possibly can be and certainly won't be using them on my bus anytime soon. They just seem so weak.
Heck, I put a new carb on our Dodge truck recently and It used these, and I wasn't overly confident with their tension to hold on a fuel line that operated at a few PSI, let alone the high pressures of the vanagon system.
To each their own I guess. |
meet 'burni' |
physast Samba Member
Posted: Wed Oct 08, 2014 8:26 am Post subject: |
| borninabus wrote: |
| ABA 21013 Stainless 13mm bolt style clamps are what you want. |
Like this?
http://www.amazon.com/AAS-Fuel-Injection-Clamps-FI...K4VRGQWJ5A
I read somewhere that these are good for low pressure hose. But these say FI in the description. _________________ 1967 L633 VW beetle (currently being restored...slowly)
1991 Orly Blue Vanaru 2.5L |
Posted: Wed Oct 08, 2014 8:08 am Post subject: |
ABA 21013 Stainless 13mm bolt style clamps are what you want. _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Wed Oct 08, 2014 7:54 am Post subject: |
I think I might stick with the ABA ones from vancafe for now. I have not heard of them failing yet.
Since I am using the 5/16 gas line I just want to make sure they get snug and stay put. _________________ 1967 L633 VW beetle (currently being restored...slowly)
nmerrill Samba Member
Joined: January 07, 2014 Posts: 388 Location: Vermont
Posted: Wed Oct 08, 2014 7:38 am Post subject: |
| Come to think of it, I think these are only used on the GTI for cooling system hoses. |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 2024 Location: Pittsburgh PA (ish)
Posted: Wed Oct 08, 2014 6:13 am Post subject: |
Hopefully not a significant drift...
Is there a specific tool out there for this type of spring clamps? I always use pliers of one sort or another...
Yes, they are all over my GTI.
Oddly, the emissions pipes also have Oetiker style clamps on them. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
Posted: Tue Oct 07, 2014 8:29 pm Post subject: |
sorry i have no idea, i don't have any gates fuel line, what's the OD of the gates fuel line, i can go and measure what i have, if that would help.
| physast wrote: |
Do you know if this fits the gates 27348 hose? I might give these a try. |
meet 'burni' |
Posted: Tue Oct 07, 2014 7:15 pm Post subject: |
| rubbachicken wrote: |
these are what i've been using for the last couple of years, i've gone through 300 or so, all the vans i've put fuel lines have had these fuel line clips these are reuseable unlike the oetiker clamps, and a good bit cheaper.
i had them on lucy for over a year before i put them on other peoples vans, no leaks on any of them.
if you pop the hood on a modern VW you will find these all over the place, and they are LOT more expensive if you buy them from VW  |
Do you know if this fits the gates 27348 hose? I might give these a try. _________________ 1967 L633 VW beetle (currently being restored...slowly)
Posted: Tue Oct 07, 2014 7:08 pm Post subject: |
if you pop the hood on a modern VW you will find these all over the place, and they are LOT more expensive if you buy them from VW  _________________ lucy our westy
meet 'burni' |
Posted: Tue Oct 07, 2014 5:50 pm Post subject: |
The clamps I used are:
Oetiker 16700013 Stainless Steel Hose Clamp, One Ear, 7 mm Band Width, 9/16" Hose ID, 12 mm - 14.5 mm Hose OD Range (Pack of 100).
They're available on amazon for $27, so $0.27 a piece.
They do seem quite tight though, and I may be moving up to the next size up for some applications. I have used them on most of the engine and fuel connections with no problem though, they tighten down really nicely.
I am using Goodyear Hose, so i'm not sure if the OD is any different but it should be pretty much the same. _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry." |
kalispell365 Samba Member
Posted: Tue Oct 07, 2014 5:11 pm Post subject: |
If you are doing a Subaru conversion anyway, the factory stainless Subaru fuel clamps are the nicest Ive ever come across, and they are on your donor(or any 1990 and newer Subaru at the junkyard).I use them on all fuel lines on the Vanagons. _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
