zerotofifty Samba Member
Posted: Fri Jul 18, 2025 10:29 am Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
Another thing. DUST. Have fresh airfilter. And some dust out there is corrosive. Like powdered salt. So wash the van well even the engine when done
Oh assuming you have on open differential. If you do get a tire off the ground with one tire, or end ip in soft tractionless sand in the back, then You lost all drive, cause of the open diff. But you can use the parking brake to provide drag on the free spinning wheel to allow the other wheel to drive. Youtube has videos on this technique _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
Posted: Fri Jul 18, 2025 9:02 am Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
Here is a nice video
https://www.youtube.com/watch?v=T7PL4h0Bf7I
Vanagon off road in Death Valley BUT 4wd
Do a search on the Youtube for VW vans in Death Valley, there are some 2wd videos too. _________________ Sorry About That Chief.
Words to live by. |
Posted: Fri Jul 18, 2025 8:55 am Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
I have had lots of fun in my Van, 2 wd in Death Valley on off road tracks. I have street tires, but they are oversized and have a minor lift via gas assist shocks. The vans have great traction, and good clearance.
I got her to trail heads where only 4wd trucks and Jeeps parked, folks thought I had 4wd.
The key is a good knowledgeable spotter for the difficult spots, air down your tires, YOU MUST air down your tires for traction, thus you need a pump to put them back to highway pressure. You may need to deflate to at least half pressure, or maybe even less. Deflating will greatly improve traction, and on graded trails with washboard bumps, will keep you from vibrating you van to pieces, it makes a HUGE difference High tire pressure is you enemy when off road.
Make sure you have valve stem caps, and a few spares also have a tire plug kit, and some spare valve stem valves and the tool to insert them. The caps are critical for keeping dirt out of the valve. You need a pressure gage too.
I recommend an air compressor, and have a back up hand pump, a bike hand pump will be very slow, maybe 200 pump strokes or more per tire, but it is better than nothing if your compressor poops out on you. ALWAYS reinflate for highway speeds.
Have some boards or similar soft ground aid, and a shovel and gloves so you can where needed build up the trail to help you clear tough spots. Know how to pick a good track. Stick to well traveled trails if you are going single vehicle, dont go off on a very deserted trail on your own. Carry LOTS OF WATER this time of year. Folks have gotten stuck and DIED out there do to lack of water. Id consider at least 5 gallons per person as a reserve, you may go through well over a gallon per person per day just to stay alive. And this is for a high traffic trail.
You will find you will get very poor MPG when off roading, you may only get 1/3 or less of normal MPG, so plan for VERY high fuel burn, suggest carry gas cans, as there are few gas stations out there. A full tank may only get you 60 miles if it is a really rough trail, slow going, lots of idling, all in first gear.
Have a first aid kit and understand how to use it.
Cell phone coverage is NOT existent in much of this area, plan accordingly
Have some spare parts, consider some radiator hose and clamps that can be used to splice a busted main coolant pipe.
Make sure she is tuned up, spare oil, belts, and such. make sure your CVs are good, no torn boots and such
Have a board to be placed under the jack for use on soft or unlevel ground, else you may not be able to change a tire on soft sand.
The Van will test your skills, it can be fun and very rewarding.
I usually go in the winter, nice 70F days, freezing cold nights.
The park lodge has a nice shower and a huge hot spring fed swimming pool, always a nice place, I think it is about 8 bucks for use of the pool and showers, take advantage of that
Watch some YouTube channels for off roading advice on how to pick good tracks over obstacles. There are many on this subject. Having a good spotter is key, the spotter MUST also watch those videos so the spotter understands how to pick the right track for each tire.
The Van is one of the more capable 2wd vehicles, but dont go crazy.
A mans got to know his limitations, so dont go trying the most extreme stuff unless you have a well equipped Jeep.
Some of the mines are really cool to go into in the Panamint area also.
The Defense Mine is a real gem, three levels, with a 300 foot vertical shaft accessed by a rickety wooden ladder. For the mines, watch your footing always, wear a N95 mask, as their is rat and bat poop, usually near the entrances, and lots of dust. Leather gloves recommended and lots of flash lights and/or spare batteries, water.
https://www.youtube.com/watch?v=SENg8nYIy7o
I have driven my Van to the defense mine, but had to stop short of it in the Van and hike, my jeep makes it a lot further.
The Talc mine, the Pink Elephant are a bit easier to drive to.
Oh, and the Trona Pinnacles is very cool place to visit, even camp at, it is an EASY off road trail to get to it, very out of this world rock formations. Used as a movie set for StarTrek, Lost in Space and other TV shows and movies. Highly recommend it
https://www.wideopenspaces.com/trona-pinnacles/
Have fun _________________ Sorry About That Chief.
Words to live by. |
E1 Samba Member
Joined: January 21, 2013 Posts: 8328 Location: Westfalia, Earth
Posted: Fri Jul 18, 2025 8:14 am Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
Many posts above presumed we were discussing traveling in summer, because we’re in summer.
When asking total strangers for help, it’s perfectly reasonable to spend a few precious seconds in being clear what you’re asking to not *waste people’s time and good intentions*. I am far from alone here in pointing this out.
I spent an hour posting above based on what was asked. Did you?
It’s not my fault that people have forgotten how to communicate, how to be gracious, nor how to do much of anything for themselves. Excusing any of that just makes the snowball grow. _________________ 1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
Subtracting weight makes you faster everywhere." — Colin Chapman
Jonathan Weisheit, Race in Peace:
https://www.youtube.com/watch?v=z3dS7xiFn7I&t=500s |
shadetreemech Samba Member
Joined: October 05, 2005 Posts: 816 Location: Claremont, CA
Posted: Fri Jul 18, 2025 8:04 am Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
E1 wrote: |
..."this brand-new poster with three inane threads as their first three posts can’t be bothered..." |
Dude,
C'mon, man. None of us were born full-grown from the head of Zeus. We all learn by asking questions. You well know what follows.
For the OP: Be forewarned; you bare your throat when you jump in here. Be aware that, most of the time, responses you don't like ain't your fault.
Love you, Eric.
Dan _________________ '84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY" |
E1 Samba Member
Posted: Fri Jul 18, 2025 7:19 am Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
Seems this brand-new poster with three inane threads as their first three posts can’t be bothered to spend ten seconds telling us their trip isn’t until NOVEMBER.
How did any of us ever travel before the web? _________________ 1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
dodger tom  Samba Member
Joined: March 25, 2013 Posts: 1935 Location: Central Coast, CA, but we're all still Ukrainian and Californian
Posted: Thu Jul 17, 2025 5:07 pm Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
i’ve driven a ‘62 split and a ‘69 bay to death valley, and went off pavement in both. course the reduction gears in the split helped. never been to warm springs though, so i can’t comment.
i will comment on timing. i wouldn’t drive a brand new range rover to death valley until november. _________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
Shonandb  Samba Member
Joined: January 12, 2019 Posts: 2082 Location: Vancouver, BC
Posted: Thu Jul 17, 2025 4:48 pm Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
6 out of 10 times you'll be fine but have you ever had to spend 16 hours in temps above 105F or in temps up to 115F for extended periods of time? If you decide to go, invest in a sat phone and over prepare. Extreme heat can be oppressive and affect your judgement. Good luck! _________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18825 Location: Retired South Florida
Posted: Thu Jul 17, 2025 4:09 pm Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
I would just ignore the warnings. Why does my Home Depot bucket have a drowning warning? Warnings are just busy work for people who write warnings. Death Valley, 40 year old vehicle, what could possibly go wrong?
I’d run it by AI.  |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17175 Location: Brookeville, MD
E1 Samba Member
Posted: Thu Jul 17, 2025 3:54 pm Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
Deleted. _________________ 1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
dougnlina  Samba Member
Joined: January 19, 2016 Posts: 304 Location: San Francisco, CA
Posted: Thu Jul 17, 2025 3:49 pm Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
Are you talking about going to the Saline Valley Warm Springs (outside of DVNP) or to Warm Spring (via Anvil Spring Canyon)? Warm spring via Anvil canyon is not that bad, or it wasn't four years ago (DV roads change yearly with the rains)
I have had my van as far in as Striped Butte Valley if the later. I have a syncro but there was nothing that a standard van with a TBD and clearance could not do, mechanically anyway, doing Mengal pass is another story altogether.. Have Good tires and a good full sized spare (or two) as you will be driving over skull sized rocks with razor edges.
I probably would not do it again, but I was fascinated by the story of the Germans who disappeared out there and wanted to check it out. (See: https://www.otherhand.org/home-page/search-and-rescue/the-hunt-for-the-death-valley-germans/)
Be aware that if you are going solo and you break down, that it will probably cost 5 figures to get your rig pulled out of there. On top of that there is no cell coverage, and as DV is Military Operations Area, less private aircraft activity, so communication via VFR radio is spotty.
I was out there in November so heat was not an issue but it I would not do it in the summer heat. Certainly if you do this go in eyes wide open realizing that you are on your own, your rig needs to be in top notch condition, you need to plan for breakdowns, repairs, extractions, extreme heat, long term survival contingencies. Its named Death Valley for a reason. _________________ "Grover" a '87 Syncro Poptop 1.8T
"Olive" a '60 Ragtop Beetle (retired) |
E1 Samba Member
Posted: Thu Jul 17, 2025 1:16 pm Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4252 Location: Redwood City, California
Posted: Thu Jul 17, 2025 12:48 pm Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
I built it to use it, I will cure the problem with the oil filter and wait to see what happens next.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2724 Location: Philly, mang
Posted: Thu Jul 17, 2025 12:36 pm Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
how much money is a rescue or vehicle recovery? i'm sure it's more then a Jeep rental. _________________ 1991 Vanagon GL Camper
i had no idea i wanted to be a mechanic |
kamzcab86 Samba Moderator
Posted: Thu Jul 17, 2025 12:30 pm Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
National Park Service - Death Valley wrote: |
[The] hot spring area [is] approximately 35 miles from the nearest paved road. A high-clearance vehicle and all-terrain tires are necessary to access this campground and road/weather conditions may necessitate 4-wheel drive. |
I wouldn't attempt it... however, your luck may be different from mine. _________________ ~Kamz
2016 Golf GTI S
16CVs Samba Member
Posted: Thu Jul 17, 2025 12:09 pm Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
Check in with park rangers first. They advised 4WD and off road tires and at least one spare.
I had all that and picked up a rock that pierced my oil filter.
4Gears4Tires Samba Member
Posted: Thu Jul 17, 2025 11:39 am Post subject: Re: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
You want to get risk getting stuck in Death Valley?
Do you have a locker in your 2WD van? Honestly, it's probably ok because conditions are dry and hard packed but if you're traveling alone with 2WD (really 1WD) in Death Valley, that's pretty high consequences for failure. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
Peter Kosho Samba Member
Posted: Thu Jul 17, 2025 10:44 am Post subject: Driving stock 89 Westy to Warm Springs Valley in DVNP??? |
Some online sources say you should have 4WD but I have 16" wheels and have driven on dirt with no problems even to Usal beach on the Lost Coast. Any recommendations for driving style or route would be appreciated! |
