OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1421 Location: San Diego
Posted: Thu Mar 20, 2025 8:15 pm Post subject: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
Symptoms:
Turn ignition key to "RUN" position. No GEN light, no OIL light.
Turn ignition key to "START" position. Nothing happens, still no GEN and OIL lights.
Turned the key all the way to "OFF" then repeated the above 5 or 6 times ... no change in symptoms.
Turned to "OFF" and left the key in that position for 15 - 30 seconds.
Turned key to "RUN" position and the GEN and OIL lights come on as they normally do. Then turned the key to "START" and the engine fires right up and idles fine. Took it for a quick test drive in the neighborhood and it drove great.
Turned it off and let it sit overnight. Went to start it this afternoon and the "GEN and "OIL" lights came on as they should and it starts up fine on the first try.
History:
The only modifications to the ignition wiring are the addition of an inline fuse for the coil wire and a hard start relay, both of which were installed around 4 years ago.
When I bought the car 4 years ago I'd periodically get a "no crank" when attempting to start (I don't recall if the GEN and OIL lights came on or not). Had no starting issues after adding the HSR.
Questions:
Is it most likely the ignition switch needs to be replaced?
I know the ignition switch gets power through the light switch, but would the light switch acting as a distribution point be a suspect as well? (It appears that the ignition feed wire is attached to the same terminal (30) on the light switch that the light switch uses for the feed wire from VR B+ ... so the ignition feed wire is not reliant on a connection within the light switch.)
Is there another component I should be looking at?
Wiring diagram here:
https://www.thesamba.com/vw/archives/info/wiring/bug_6869.jpg
Thanks for your thoughts and suggestions. _________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11163 Location: Huntington Beach, CA
Posted: Thu Mar 20, 2025 11:12 pm Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
Why not use a volt meter to check for power to the switch. Red wire, 30 circuit. If there, then check the output wires, black (key in run position, 15 circuit), red w black tracer (starter feeder wire, 50 circuit). All should show around 12.6 vdc, in their respective positions. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8848 Location: Sunset, Louisiana
Posted: Fri Mar 21, 2025 12:49 am Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
VW_Jimbo wrote: |
Why not use a volt meter to check for power to the switch. Red wire, 30 circuit. If there, then check the output wires, black (key in run position, 15 circuit), red w black tracer (starter feeder wire, 50 circuit). All should show around 12.6 vdc, in their respective positions. |
This is the way. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Fri Mar 21, 2025 9:07 am Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
Thanks guys!
The problem is intermittent, so if I've got good voltage to lighting switch 30, I guess I should wiggle the key while in each position to see if the output voltage varies.
Semi-related question ...
Wouldn't it be beneficial to put an inline fuse on the feed wire from VR B+ to lighting switch 30? I believe it is equivalent to a 10 gauge wire so capable of handling ~35 amps.
Since I'm going to be digging into the wiring anyway, maybe a good time to add a fused distribution block like this so the light switch doesn't have to do that job? Would also provide some additional fused terminals for future needs.
https://ceautoelectricsupply.com/product/atc-ato-f...ion-cover/
If I did this, any recommendations on where to locate it? _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
diamondblue1969 Samba Member
Joined: February 19, 2010 Posts: 142 Location: ONTARIO
Posted: Fri Mar 21, 2025 9:29 am Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
If your problem is intermittent use the ohmmeter and check resistance
between contacts in the switch , see if it goes open or the resistance goes
all over the place . Disconnect the power to the switch first . Resistance
should be close to zero for a good connection. |
Posted: Fri Mar 21, 2025 9:36 am Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
You can do anything you want to your car. That is your choice.
Regarding the fuse block. For me, it would be sacrilegious. I like VW engineering way too much. Simple, elegant, repairable (in the field) and functional. In my 40 years owning/working on these cars, I have never had a wire fail. I maintain my cars to a fault. I am an exception. When I worked at an independent VW repair shop, the abusive nature of the customers towards their cars would have clearly been a benefit! Those people would cut wires, then twist them together and maybe use scotch tape to insulate the horrible splice together. In this case a fuse is a MUST! But if you just maintain your vehicle and keep up on the visual inspections, I am certain all will be well.
There is a saying that applies here. “Don’t go fixing what ain’t broken!” And my personal favorite all time one, “Keep It Simple Stupid”. I live by both! _________________ Jimbo
TDCTDI wrote: |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7502 Location: Houston, Texas
Posted: Fri Mar 21, 2025 3:00 pm Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
The easiest way to check this is with a voltmeter. Jiggle it to make sure. Then follow the wire to the next piece you need to check. This same process works on checking the light switch. You can also check your turn signal switch the same way. _________________ www.vwnos.com [email protected]
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4488 Location: viroqua wi.
Posted: Fri Mar 21, 2025 3:31 pm Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
heimlich wrote: |
The easiest way to check this is with a voltmeter. Jiggle it to make sure. Then follow the wire to the next piece you need to check. This same process works on checking the light switch. You can also check your turn signal switch the same way. |
I agree, but my method is a VOM meter on Ohms. You lift a battery lead and Ohm between the loose battery lead and the other battery lead. If you have a stereo with a constant + you will need to disconnect it. |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13947 Location: White Mountains Arizona
Posted: Fri Mar 21, 2025 4:56 pm Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
More than likely it is the ignition switch. My 68 went thru several as they were not German switch. Finally got one to function. A lil tricky to replace. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Fri Mar 21, 2025 8:16 pm Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
VW_Jimbo wrote: |
You can do anything you want to your car. That is your choice. |
Yes I can and yes it is … and I prefer to make informed decisions, which is why I seek information and opinions from experienced members kind enough to take time to share their knowledge.
VW_Jimbo wrote: |
Regarding the fuse block. For me, it would be sacrilegious. ... if you just maintain your vehicle and keep up on the visual inspections, I am certain all will be well. |
I too admire the elegant simplicity of these cars. I also acknowledge that, in my case, my ’69 is 56 years old and, while copper doesn’t degrade, insulation can and often does. I consider adding inline fuses to currently unfused feed wires because such wires pass through inaccessible passages in the body. Perhaps the wiring I can see appears sound, but that is no guarantee that the wires I cannot see have faired as well. Adding an appropriately sized inline fuse seems a worthwhile precaution that could save me from a dealing with a difficult wire replacement project should a short occur (the rationale for adding a fuse to the coil 15 wire). Using a mini fuse block as a distribution point would just simplify the task of adding fuses to currently unfused feed wires in the trunk. Sure, such safeguards always add some minor complexity, but I think the trade off is often worthwhile. Since I’m not a “concours purist” it’s not a moral dilemma for me.
heimlich wrote: |
The easiest way to check this is with a voltmeter. Jiggle it to make sure. Then follow the wire to the next piece you need to check. This same process works on checking the light switch. |
That’s the game plan for this weekend. Hopefully I don’t have multiple components failing.
gt1953 wrote: |
More than likely it is the ignition switch. My 68 went thru several as they were not German switch. Finally got one to function. A lil tricky to replace. |
I kind of think so too, but will follow the evidence. Not looking forward to replacing the ignition switch. Spent a month one weekend replacing the turn signal switch and dealing with horn circuit issues … that steering column is a rabbit hole of misery.
If the ignition switch is the culprit, I am open to suggestions on where to purchase a quality replacement. I know an NOS would be the ideal, but I need to put food on the table and pay the mortgage.  _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
gt1953 Samba Member
Posted: Sat Mar 22, 2025 7:47 am Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
As far as a vendor to make the purchase...it is crap shoot. Just do not loose that tiny set screw. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
heimlich  VWNOS.com
Posted: Sat Mar 22, 2025 8:14 am Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
I bought one of those switches from a vendor about 5 years ago. I installed. I turned the key. I saw a puff of smoke.
I thought about rebuilding the one that is in there. Those earlier ones are made out of metal so once you bend the tabs out to take it apart it makes it more difficult to reclose it. If you are feeling adventurous you can do that. It might just need to be taken apart, inspected, and cleaned. There are usually tiny springs inside so watch out. There are some threads on how to rebuild the later ones from 71. They might be the same inside but 71 is plastic on the outside and can be easily opened. I think the metal switches are better but they are hard to reclose. _________________ www.vwnos.com [email protected]
Rob Combs Samba Member
Joined: December 30, 2020 Posts: 538 Location: South Bay LA, California
Posted: Sat Mar 22, 2025 11:19 am Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
Our ignition switches carry quite a heavy burden, at least compared to the way more modern cars are wired. The ignition switch shoulders the electrical needs of almost the whole car.
If you want a high-quality, heimlich is your guy. The ones you find on Amazon are all over the place and a crapshoot, at least in the opinions of some of our users who've tried them and had them fail within a few days.
There's a way to make that ignition switch carry far less burden than VW originally intended, and that's to wire it like a modern car - meaning put a relay onto each power-out circuit on the ignition switch. You already have one in place - the "hard start" relay - which enables the circuit 50/starter solenoid leg of the switch, and all of the wiring that runs from the switch to the starter, to do virtually no work. The only current it has to carry is the current required to energize the relay coil, which is well under half an ampere (~300mA last one I checked).
This logic can be extended to every circuit the ignition switch powers, and it'll never work another day in the car's life. All it takes is another one or two of those relay kits, depending on your ignition switch configuration (I can't remember how a `69 is wired; mine's a 71 and is a little different). |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16577 Location: North Florida, USA
Posted: Sat Mar 22, 2025 3:30 pm Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
Rob Combs wrote: |
Our ignition switches carry quite a heavy burden...
The ones you find on Amazon are all over the place and a crapshoot...
There's a way to make that ignition switch carry far less burden than VW originally intended... put a relay onto each power-out circuit on the ignition switch.
The only current it has to carry is the current required to energize the relay coil, which is well under half an ampere (~300mA last one I checked). |
I agree with Rob above. If you want to make improvements to the VW Beetle wiring, adding a few relays will extend switch life by decades. His estimate of ~300mA is actually on the high side. I measured the current draw for some of the SPDT 12v relays I have and they are only in the ~100mA range.
The aftermarket ignition switch market is pretty bad. Even if you supplement one with relays to reduce the current flowing thru the internal contacts, the build quality is pretty poor. Sometimes the internal contacts don't actually touch and you need to tweak them so they make solid contact every time.
I agree with the above suggestion to take your current OE switch apart and clean and grease the internals. This is assuming you actually have the original switch. In the decades befor you git the car the ignition switch may have already been replaced by a cheap aftermarket one. Just take the switch apart inside a cardboard box so any springs and ball bearings that come flying out are captured and don't get lost in the far corners of your shop. The OE VW ignition switch had much larger internal contacts than the currently available aftermarket replacements. All the more reason to add relays on the output circuits to minimize the arcing at the internal contacts.
Whether you get a new aftermarket switch, a NOS VW switch or rebuild your current OE switch... adding relays to the #15 and #50 circuits coming out of the ignition switch will extend the life of the internal contacts giving you years of use (at least for the electrical contacts). Arcing at the ignition switch contacts is what causes the OE ignition switches to fail after a few decades. IMHO, the current type of aftermarket plastic ignition switches available to replace your stock one... are made of such cheap plastic that the relays and internal switch contacts will out live the plastic switch housing. I would expect the plastic housing will crack and fall apart within 5~10years from wear or the plastic failing from UV light exposure. That's just my guess.
If your ignition switch is one with a metal case... take the time to disconnect the far end of the wires and pull the ignition switch and is soldered on wires out as a whole unit. Don't cut the wires.
When I removed my '71 ignition switch I rushed and just cut the wires. After I removed it I decided to take it apart and rebuild it. It worked great! But to reinstall it I had to splice all the wires back together. I regretted that and just bought a new switch and swapped out the old because it looked terrible with the spliced wires. After a couple years the NEW switch failed. I opened it up and saw how small the internal contacts were. I wished I had kept my OE metal switch but I had tossed it in favor of the nicer looking new plastic switch.  _________________ AshMan40
heimlich  VWNOS.com
Posted: Sat Mar 22, 2025 4:48 pm Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
ashman40 wrote: |
Rob Combs wrote: |
When I removed my '71 ignition switch I rushed and just cut the wires. After I removed it I decided to take it apart and rebuild it. It worked great! But to reinstall it I had to splice all the wires back together. I regretted that and just bought a new switch and swapped out the old because it looked terrible with the spliced wires. After a couple years the NEW switch failed. I opened it up and saw how small the internal contacts were. I wished I had kept my OE metal switch but I had tossed it in favor of the nicer looking new plastic switch.  |
For the plastic switches, I have found the aftermarket ones to be an exact copy for the plastic part. I have successfully take the plastic off an aftermarket switch and replaced the German switch plastic with it. This is the spring loaded part I am referring too.
I was in a similar situation as you and I put spade terminals on the wires so that I could easily remove/repair/replace the switch later. _________________ www.vwnos.com [email protected]
Cusser Samba Member
Joined: October 02, 2006 Posts: 33089 Location: Hot Arizona
Posted: Sat Mar 22, 2025 6:59 pm Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
heimlich wrote: |
The aftermarket ignition switch market is pretty bad. |
I guess I'm fortunate; in the 52 years with my 1970 and my 48 years with my 1971, I've replaced the electrical part of the ignition switch on each exactly ONCE (July 1989 on the 1970, and Sept. 1998 on the 1971), and that was over 3 decades ago, so I imagine that those switches were actually made in Europe. Both still work fine these days, no hard start relays either.
Back then in Arizona we had BAP parts, and I got everything for my VWs from them. Maybe a decade ago they were bought out by Parts Authority (not a VW place), who I don't know if they are still in business. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
heimlich  VWNOS.com
Posted: Sat Mar 22, 2025 7:46 pm Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
Cusser wrote: |
heimlich wrote: |
Back then in Arizona we had BAP parts, and I got everything for my VWs from them. Maybe a decade ago they were bought out by Parts Authority (not a VW place), who I don't know if they are still in business. |
Now you're showing off. That might have been the OEM manufacturer you had.
Aftermarket these days isn't as good. _________________ www.vwnos.com [email protected]
Posted: Sat Mar 22, 2025 10:34 pm Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
Geez, you guys sure know how to cheer me up.
Well, after a bit of excavation, I gained access to the lighting switch.
The feed wire from the VR B+ showed 12.4 volts at terminal 30.
With the ignition switch in the RUN position, the wire from ignition switch 15 showed 12.3 volts at the fuse box terminal.
With the key in the START position, there is 11.7 volts at the hard start relay terminal 85.
The GEN and OIL lights come on with the key in the RUN position.
I wiggled the daylights out of the key during the above checks and the voltage didn't drop more than .1 volt.
So whatever caused the symptoms in my original post didn't show itself. At least it gave me the opportunity to clean the terminals and clean and heat shrink the connectors.
Driving until I experience more reliable failure isn't the best plan ... just not keen on doing roadside electrical troubleshooting and repair. Since the available after market switches are of such poor quality, my current thinking is to disconnect the ignition switch and wire in a flush mount generic switch under the dash. The old switch could act as a decoy and steering wheel lock. Any generic switch would be loads easier to replace than the column switch if it failed.
Be glad to hear your thoughts about this idea. _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2050 Location: Wichita, KS
Posted: Sun Mar 23, 2025 4:09 am Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
OldSchoolVW's wrote: |
Be glad to hear your thoughts about this idea. |
One man’s wiring “improvements” or “creative solutions” are often another man’s wiring “puzzles” and “headaches” further down the road — sometimes even for the same man (ask me how I know this - ha!).
Seriously though (as noted by others earlier) it’s ultimately your car. And as such you’re pretty much free to do as you wish with it, for as long as you own it -- whatever makes the most sense and satisfaction for you, personally.
In my case, I took apart, cleaned, and re-lubed my old original ignition switch several years ago (while repairing/refurbing several PO “molestations” to rest of steering column and horn components), and it’s been working fine ever since. Bit of a fiddly job (e.g. there’s some little springs and ball-bearing detents, etc. in there, IIRC), but still do-able w/ a bit of patience and finesse. Just another option to consider… _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
Cusser Samba Member
Posted: Sun Mar 23, 2025 7:20 am Post subject: Re: Ignition Switch Troubleshooting Guidance Please - Stock '69 Bug |
heimlich wrote: |
Cusser wrote: |
heimlich wrote: |
Aftermarket these days isn't as good. |
Heimlich - I think that's why my VWs seem to have less reliability problems than other folks have - the parts I installed back then were of significantly better quality, like my genuine "rebuilt by Bosch" starters and generators, not Chinese stuff.
I must say though: I have O'Reilly lifetime rebuilt alternators in my 1988 Mazda truck and 1998 Nissan Frontier (easier R&R than a VW generator), and they've been good. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
