Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23456 Location: Kimball, Mi
Posted: Fri Sep 01, 2023 1:19 pm Post subject: Re: Trevor's Fasty Build |
Sounds like you're out driving the car and doing "running repairs" on it to make it more enjoyable.
As for the sunroof seals, they're mostly "wind seals" and don't keep the water out. That's what the drain tubes are for. One of the first things I worked on with my Notch was to repair the sunroof drain pan (was rusted out in sections), and replace the drain tubes front and rear.
On my wife's Fastback, I replaced the stationary window seals with used pop out seals that I got from a guy in Ohio (this was before ISP had them available). They were complete, and now I have a set of spare glass for them. Always good to have spare parts when you're so far away from California. The pop outs were the one thing that she wanted me to put back in the car, after she drove it one summer.
Between the sun roof and the pop outs in my Notch, I love having both.
It's good to hear that you're driving the car, and fixing the little things, as that's how you enjoy it. Getting rid of any rattles and things are always good.
As for painting the elky, your wife just wants it to happen, so she looks good driving it.
It's good to hear you're still around and driving your Fastback. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2182 Location: Gardnerville, NV
Posted: Thu May 15, 2025 2:28 pm Post subject: Re: Trevor's Fasty Build |
Bobnotch wrote: |
It's good to hear you're still around and driving your Fastback. |
Oh yeah, always lurking. any chance i can get, i drive the Fastback. this weekend i have to replace the flywheel, i had a chipped tooth on the std weight one and since it was just a plain cast flywheel , that led to more teeth going away... so, out comes the motor to replace the flywheel with a CB performance forged lightened one.
and if that isnt enough.... of course the "while im in there's" start to rear their ugly heads... so i ordered the new rear subframe bushings, as i have had the old ones in there with washers for spacers to get the modified swingaxle with irs pockets subframe to make the engine sit where it is needed so i can get the bellows on.... that was a mouthful. and of course ... its time for shocks... so off come the Coil overs, readjust the torsions, and on will got the Gas-a-just's.
lastly , I went ahead and figured it was time as the passenger front brake hose is wet around the fittings, to replace them with braided stainless brake hoses , I've heard this goes a long way to making the brakes feel quite a bit more firm, not that i have noticed any pedal feel issues recently. lastly , once all this is done.. time for new rubber out back. tires look like slicks so time for a new pair of 205 70 r15's... i realized a couple of weeks ago that i actually have 205 65's on right now... while they have been fine. I need a little more sidewall to get my rpms down at speed. currently 70mph is 3600 rpm... it used to be closer to 3400 with the worn out transmission, and Steve "Clatter" did such a great job on it I don't want to touch it.
in work news , the ICON VW pistons are really becoming a hit. we now carry revmaster barrels for the 94 and 92's (92's are thick walled with 94mm registers). 90.5's A's and B's are on the way.. as well as revmaster 85.5 and 90.5 barrels in the works. If anyone who's reading this has a set of ICON's, THANK YOU. we have worked really hard to give the community a quality high performance product at an affordable price.
next upgrade on the list is the rear disc kit, which i may have by the time the season is up lol. which is fine because I've been working on my garage since late this last winter... I dont have heat out there and i have finally had it.... so we'll be putting in a ceiling , tape/texture and paint and installing a heater so i can finally go out and work on the car in the winter , or reload ammo... etc. I hate that the garage is only usable 6 months out of the year.
I know I say this every time.. but i will actually try to take pictures while working on Donald this time. try to have some proof i actually do things  _________________ If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Scotty D Samba Member
Joined: February 08, 2020 Posts: 286 Location: Claremont CA
Posted: Thu May 15, 2025 3:30 pm Post subject: Re: Trevor's Fasty Build |
Good to hear you're still working on it. I'm spoiled living in southern California, but even still, I can appreciate not wanting to work in a freezing cold environment.
Post some pics!!  |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11087 Location: Black Forest, CO
Posted: Fri May 16, 2025 8:40 am Post subject: Re: Trevor's Fasty Build |
Max Welton wrote: |
You know Trevor ... there's an Invasion next year.
Max |
Wisconsin though.... id have to meet up with you in CO and train there with ya _________________ If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Posted: Wed May 21, 2025 8:01 am Post subject: Re: Trevor's Fasty Build |
last weekend ... got plenty done. but still more to do. when it came to reindexing the springplates i went two outer splines on the driver side and fought it to get it back in place only to discover... thats way too frick'n high.. so i will back it off 1 spline and hopefully should end up just about perfect.. install the shocks and new brake hoses and should be good to go..
let me just be very honest here... i hate adjusting rear spring plates... mainly cause i havent done them enough... running coil overs out back for so long i was able to get away without any adjustments.
so hopefully tonight when i get home i can blast it apart and put it back together and be at the "right" ride height im looking for. _________________ If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Posted: Tue May 27, 2025 7:41 am Post subject: Re: Trevor's Fasty Build |
Saturday after mowing the lawn and some honey-do's I got around to setting the ride height correctly.. back to 1 outer spline and the ride height ended up being perfect. Installed the new KYB's out back , and took Donald for a spin. this is going to sound rediculous ... but keep in mind I have a tendency to put things off thinking everything is fine. with the bushings for the rear subframe, new rear shocks I have never experienced a smoother ride in Donald than i had on saturday afternoon. he felt like a newer car with how he was riding.
I got back to the house and noticed the distinct smell of burning oil... great... wonderful. well it turns out i didn't have the filler neck tube clamped at the top... and this is going to sound odd... but it started sucking oil from the filler into the cooling duct then blowing it all over the top of the motor... even had oil coming from the mating halfs of the inner fan housing. Great so thats fixed right? but wait there is more! as if that wasnt enough.. the rear mainseal wasnt doing its job.. so drip drip drip out of the rear main.
So , the engine has to come back out. ordered a new rear main seal, and new KYB's for the front now. after the engine gets cleaned and put back in i will adjust the front again. going to raise the front by one outer spline. since after some reading it looks like it changes the front height by 2 inches instead of 2.5 on the inner splines. so i should still have a slight rake... but now the tires wont touch so bad in the front.
this next weekend I am going camping with the family so no work will get done , i should be able to get it done the following weekend before i have to fly out to to Indiana to meet up with one of our major Professional engine rebuilders we supply. hopefully when i get back I can take the fastback for a nice drive. Time for some throttle therapy.  _________________ If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
