Erik G Samba Member
Joined: October 16, 2002 Posts: 13564 Location: Tejas!
Posted: Fri Jun 12, 2015 12:28 pm Post subject: |
EasternNotch wrote: |
Erik G wrote: |
Erik G wrote: |
Been dodging rain and Flooding
Yesterday, installed my "full circle" horn ring. what a pain in the arse, every hole had to be enlarged, the post for the horn wire had to be filed down. Nothing horrible, just not as straightforward as it should be (nothing non-stock ever is, right?) |
that's odd mine was simple to install no mods necessary. |
really? Where did you get yours from? the plastic screw bushings didn't fit, the horn wire screw was fine but the back side wouldn't fit the contact ring and even then, I had to open up the holes on the contact ring in order to line up with the holes on the actual horn ring. The button was also a very tight fit |
I got mine from someone on here- its aftermarket for sure- does shave a vw part number but no vw symbol like the originals had. Mine didn't come with the plastic bushings or the horn wire screw or tab so I just used the ones from my stock horn bar which was NOS when I got it. |
Yeah, it comes without all that so I re-used my stock original ones
I'm guessing someone had already fitted it and did the work for you. Like I said, it's no biggie but just goes to show nothing fits like stock _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Mon Jun 15, 2015 9:02 am Post subject: |
Air up my leaky front tires and went for about an 8 mile shake-down.
That's as far as this car has been driven since about 2010.
There's a rattle at real low RPMs, and the engine was a little warmer than I expected when I got back.
Overall, YEA!  _________________ Everything known to man has been written.
Readers are Leaders! |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 6041 Location: Brooklyn
Posted: Tue Jun 16, 2015 9:47 am Post subject: |
 _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
EasternNotch Samba Member
Joined: January 19, 2006 Posts: 637 Location: Boston Metro West
psychopork Samba Member
Posted: Tue Jun 16, 2015 7:34 pm Post subject: |
I tore down the new to me AS21 long block. I found out the heads are 2 different numbers. One is 155 and the other is 69. (pictures in gallery) I also spotted the numbers there and it seems to be stamped A?006622.
I know this is probably a type 1 case but it is the best I can find in my price range. I plan to freshen it up and piece the tins together for a type 3 style cooling.
Proceed with the flogging. _________________ Tighten it till it snaps, then back it off half a turn. |
Mexicant Samba Member
Joined: December 31, 2010 Posts: 99 Location: Colorado
Posted: Tue Jun 23, 2015 9:11 pm Post subject: |
Tinted the windows
chaosisme Samba Member
Joined: August 29, 2005 Posts: 1164 Location: Orange County, Ca
Posted: Tue Jun 23, 2015 10:10 pm Post subject: |
Installed my (formerly) NOS AAR today. Car starts and idles much better now. _________________ '65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's |
Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1386 Location: Bella Coma Canada
Posted: Thu Jul 02, 2015 1:05 pm Post subject: |
Finally some shop and air time on the hoist.
I drained the Black engine oil and see that the transaxle is covered in baked on dirt and oil. I pulled the plugs out of the bottom of the transaxle a little fuzzy stuff on the magnets but the 90w looks clean but low.
I'm going to add fresh oil and adjust the valves
Both axle boots are long gone. I'll order some new ones.
The right front brake was seized. So I pulled the double nuts and outer wheel bearing . The wheel and drum came off with the help of a old chain saw bar that I plasma cut some holes to mount on the drum using longer thread lug bolts and with a BFH's help and lots of rocking up and down.
I sanded the rusty drum and cleaned the shoes and put it back together, it spins nice.The shoes are riveted style. I'll be going through the complete brake system later.
first time view of the bottom and all in all it looks good even the battery area shows no holes. I did notice the bleeder location on the rear wheels.
the Left Bleeder looks like it should
The Right Bleeder - must be the wrong cylinder or can it be flipped to have the bleeder on the top?
I'll replace all the fuel and vacuum hoses and take the carb apart for a cleaning when I get the carb kit.
having fun
cheers
Hank _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS |
Posted: Thu Jul 02, 2015 4:16 pm Post subject: |
1962 1500 Notchback
Fresh oil in and turning the generator nut with a 13/16" open end and aligned the notch and rotor for #1 and down through the hole in the cooling tin to the first of the 3 marks on fan.
I popped off both valve covers and was amazed on how clean the inside was after sitting so long
.008 feeler fit too loose so I tighten.
I adjusted both #1 cylinder valves and intake on #2 and exhaust on #4
Then turning the generator nut again 180* but I could not get past #4 cyl. spot on distributer
I turned the gen nut CCW to try to sneak up on #3 cyl from the other way.
No luck maybe a valve stuck down or something is in either # 2 or #4 cylinder
so my dream of starting it up after a long rest won't happen. I'll get a friend to turn the engine while I look at the valve action.
Looks like I'll pull the engine at least it rolls now.
cheers
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23494 Location: Kimball, Mi
Posted: Thu Jul 02, 2015 9:09 pm Post subject: |
Shot some paint and clear on my roof. It doesn't look bad, but I plan on wet sanding it, and shooting another coat on it. Pics to folow in the next day or so in my "not a thread" thread. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
Posted: Fri Jul 03, 2015 2:45 pm Post subject: |
I took an hour and dropped the engine out. The sun was so hot I shut my garage doors .
The hoist and my rolling metal work table, made that job fun
I sprayed lots of "P" oil on every bolt and nuts and screws that have to come off to get into the heads to see what the stoppage is.
The flywheel teeth have some wear. The heat riser on the exhaust is pinched off. good end play though.
I haven't had this much fun with my pants on for a long time
cheers
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 4042 Location: San Jose, CA
Posted: Fri Jul 03, 2015 7:44 pm Post subject: |
I bought a couple tires. I should probably buy the rest.
_________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4509 Location: Illinois
Posted: Sat Jul 04, 2015 7:00 pm Post subject: |
I dropped the front end 1 inner spine (1.5") and destroyed an outer right tie rod end in the process.
Before:
After:
Now I just need to get around to hooking up the brakes and I can drive it. |
t3kg Samba Member
Posted: Sun Jul 05, 2015 10:42 am Post subject: |
t3kg wrote: |
Looks good Josh. What disk brakes are you using?
edit: Never mind, I just found all the details on your blog... |
....yeah. It's safe to say that I've had some *moments* of frustration with them.  |
t3kg Samba Member
Posted: Sun Jul 05, 2015 11:39 am Post subject: |
t3kg wrote: |
So I take it if you were to do it again you'd go with a disk kit from another source? |
Definitely. |
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1894 Location: Feeling, Minnesota
Posted: Sun Jul 05, 2015 12:22 pm Post subject: |
Mexicant wrote: |
Tinted the windows
The tint is probably too dark, if you're driving it off the road like that.
J/K - It looks good, and probably helps keep the interior cool in the summer. _________________ 1968 Regatta Blue Squareback |
Posted: Sun Jul 05, 2015 8:53 pm Post subject: |
ataraxia wrote: |
Before:
After:
With all of the frustrations with the disc kit, I'm sure you already test fitted a hub cap, to make sure it clears the lug studs right? You also removed the paint from the lug nut seat on the rim too? Just asking, as I'd hate to hear about you loosing a tire somewhere.
After reading what you went thru, I'm actually glad I went with the SoCal bug kit, and modified a set of disc spindles for my T-34. Using Chris's spacer made aligning everything a lot easier. The single piston Rabbit calipers worked great on it too. The only drawback to the SoCal kit was that it uses 12mm lug bolts (stock VW lug bolts), and I have a coffee can of 14mm ones.  _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
