Transmission oil?
shouldabeenhotrods
shouldabeenhotrods is offline
PostPosted: Tue Aug 18, 2009 7:03 am    Post subject: Transmission oil? Reply with quote
Hey all, i'm doing my first tune up/maitenance on my '57 beetle, and I was wondering what transmission oil I should use? I can't find 90W..or i'd use that like the book says. anyone have any recommendations? it's got a '60s tranny. i'm new to the VW scene. thanks!
1955 3 fold Oval
2017 500 Abarth
1929 Ford Model A
2017 Lincoln Continental
Motorhead55
Motorhead55 is offline
PostPosted: Tue Aug 18, 2009 8:02 am    Post subject: Reply with quote
I also have a full synchro in my bug and I just recently switched to Valvoline Syn Power full synthetic 75/90wt. It has made a world of difference on shifting! Cold shifting is now very easy.
2007 Dodge Cummins Diesel 4x4 6spd stick
1939 WILLYS pickup
1967 Triumph Tiger Cub
p horvath
p horvath is offline
PostPosted: Sun Aug 30, 2009 12:25 pm    Post subject: t oil Reply with quote
redline mt 90.
PostPosted: Sun Aug 30, 2009 1:02 pm    Post subject: Reply with quote
Transmission oil topic
http://www.thesamba.com/vw/forum/viewtopic.php?t=276529
mr matt
mr matt is offline
PostPosted: Tue May 13, 2025 3:18 pm    Post subject: Re: Transmission oil? Reply with quote
For my 1955 tranny,
Would this oil be fine to put in?.. not sure about the comment of "rear axles not requiring hypoid oils" - just don't get that.
Dang cracked axle boot..
Thank you
1955 3-fold semaphore Oval beetle
1971 Convertible beetle
1977 Westfalia, FI, Berlin interior
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Tue May 13, 2025 3:42 pm    Post subject: Re: t oil Reply with quote
p horvath wrote:
redline mt 90.
x2
Jimbo
TDCTDI wrote:
67rustavenger wrote:
esde
esde is offline
PostPosted: Tue May 13, 2025 3:44 pm    Post subject: Re: t oil Reply with quote
VW_Jimbo wrote:
p horvath wrote:
redline mt 90.
x2
X3
every trans I've ever filled with it has shown improved shifting
modok wrote:
Max Welton
Max Welton is offline
PostPosted: Tue May 13, 2025 5:13 pm    Post subject: Re: t oil Reply with quote
esde wrote:
VW_Jimbo wrote:
p horvath wrote:
redline mt 90.
x2
X3
X4.
Max
1967 Type-3 Fastback
mr matt
mr matt is offline
PostPosted: Tue May 13, 2025 5:33 pm    Post subject: Re: Transmission oil? Reply with quote
OK... pricey.... but I have to admit, my transaxle is worth it.
Of course I read the 70+ page on GL4, vs GL5, as well as another thread, and for me.. want to go with GL4...which I think the redline is... have to double check.
Thanks all.
mr matt
mr matt is offline
PostPosted: Tue May 13, 2025 5:53 pm    Post subject: Re: Transmission oil? Reply with quote
And is now ordered! ...
VW_Jimbo is offline
PostPosted: Tue May 13, 2025 8:49 pm    Post subject: Re: Transmission oil? Reply with quote
Thanks all.
Scott who owns MCM rebuilds racing transmissions for VW cars. He swears by Redline. He turned me onto Redline and I have not gone back!
Jimbo
mr matt
mr matt is offline
PostPosted: Wed May 14, 2025 4:40 pm    Post subject: Re: Transmission oil? Reply with quote
Another confirmation, thanks!
Soon I will be changing out my 77 bus tranny fluid... if anyone continues to read this, do I used the same oil?
I can ask this in the bus forums otherwise....
splitjunkie
splitjunkie is offline
PostPosted: Fri May 16, 2025 8:45 am    Post subject: Re: Transmission oil? Reply with quote
mr matt wrote:
For my 1955 tranny,
Thank you
VWs don't have hypoid ring gears so it should be fine, however, the consensus is that the Redline oil is the best.
Chris
Bruce
Bruce is offline
PostPosted: Fri May 16, 2025 1:26 pm    Post subject: Re: Transmission oil? Reply with quote
splitjunkie wrote:
mr matt wrote:
For my 1955 tranny,
The dedicated gear oil topic is now 70 pages long. There is no consensus on what oil to use.
Since Matt is asking about his 77 Bus, it does have a hypoid R&P, so it needs to use GL-5 gear oil.
Now, for all the nancys out there that fear GL-5, there do exist gear oils that are GL-4 and GL-5 rated.
I strongly recommend synthetic 75W-90. Then when the gear oil is cold, it shifts just like when the gearbox is warmed up in the summer.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri May 16, 2025 2:13 pm    Post subject: Re: Transmission oil? Reply with quote
It was just pointed out to me, that early transaxles use different bearings and "might" need a different gear lube than newer transaxles, so I unlocked it.
Please, if you have questions on other transaxles use other existing topics.
GL 4 or GL 5 - "Official Gear Lube Topic"
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Mr. 010
Glenn is offline
PostPosted: Fri May 16, 2025 6:37 pm    Post subject: Re: Transmission oil? Reply with quote
Please do so.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
esde
esde is offline
PostPosted: Fri May 16, 2025 7:09 pm    Post subject: Re: Transmission oil? Reply with quote
My point to Glenn was, that the early non synchro roller bearing transmissions are much more primitive than the later transmissions. What they were originally intended to run, and what works best in them now, and why is not really the same discussion as the dedicated oil thread..
I've got a few things to add, when I'm back on my laptop
modok wrote:
pastellgreen
pastellgreen is offline
PostPosted: Sat May 17, 2025 2:38 am    Post subject: Re: Transmission oil? Reply with quote
I don't know the problem, but simply use the oil VW recommended to use and used itself. Is it really that hard?
Transmission: mineral oil SAE90 GL4 after MIL-L-2105. I drive every day since 20 years beetle only, summer and winter. You can also use 80W90 if you want.
pastellgreen
PostPosted: Sat May 17, 2025 2:54 am    Post subject: Re: Transmission oil? Reply with quote
Interesting!
Mr. 010
Glenn is offline
PostPosted: Sat May 17, 2025 4:13 am    Post subject: Re: Transmission oil? Reply with quote
That was a lot of years ago and things change... usually for the better. Oil today is better formulated than it was in the 50's.
When light bulbs need to be replaced, in your house, do you insist on finding incandescent bulbs or do you use LEDs?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
