Another boring Test Stand thread again for the 100th time
Page: 1, 2, 3, 4, 5  Next
vaughn bros.
vaughn bros. is offline
PostPosted: Sat Oct 03, 2009 12:48 pm    Post subject: Another boring Test Stand thread again for the 100th time Reply with quote
Dont laugh too hard. Laughing Laughing It will work for what I need it for. It had to be built on a budget so WTF. The tube is .250 wall and the header is .375 wall "C" channel. Its all mig welded and got painted today with some commercial grade galvanized paint. Gonna wire and plumb it maybe tomorrow.
Dale M.
Dale M. is offline
PostPosted: Sat Oct 03, 2009 4:24 pm    Post subject: Reply with quote
Only thing see wrong is no bottom brace on plate.... You are going to have 300 pound bucking and shaking, cantilevered on one single weld.... Structurally its a poor setup... You need a bar from crossbar at top to bottom behind plate belhousing is bolted to....
Dale
fastinradford
fastinradford is offline
PostPosted: Sat Oct 03, 2009 4:25 pm    Post subject: Reply with quote
seems like an overkill, but looks nice.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Oct 03, 2009 4:28 pm    Post subject: Reply with quote
Must take up a lot of room when not in use.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
vaughn bros.
PostPosted: Sat Oct 03, 2009 6:45 pm    Post subject: Reply with quote
Dale
Actually, if you look close at the back side, you will see 1 of 2 large gussets that are also .250 thick. We overlaped the plate onto the header so that gave us a good weld on front top and a good weld on back.
I like your prediction though of bucking and shaking. I will video my first run with it just in case your right. Might be fun to watch a test stand wobble down the drive and into the road. I will post on youtube.
However you will owe me a beer if it is smooth and steady.
Vee Dub Nut
Vee Dub Nut is offline
PostPosted: Sat Oct 03, 2009 7:05 pm    Post subject: Reply with quote
Yea you have a little gusset on there, but you still have a bunch of weight that is cantilevered on that plate. All the gusset did was move the axis down lower. It would be very easy to add another cross bar on the bottom to strengthen it up.
Sure would suck for a newly built engine to hit the floor cause something didn't hold.
Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut
mharney
mharney is offline
PostPosted: Sat Oct 03, 2009 7:13 pm    Post subject: Reply with quote
Y'all can't touch my wooden engine stand.
The Noof
The Noof is offline
PostPosted: Sat Oct 03, 2009 7:16 pm    Post subject: Reply with quote
Gotta love Tennessee ingenuity Cool
Mr. 010
Glenn is offline
PostPosted: Sat Oct 03, 2009 7:17 pm    Post subject: Reply with quote
Made from old Jack Danials barrels.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
mharney
mharney is offline
It was conceived and built in Kansas, before I moved to TN. Then I made another one when I moved here. Smile
Wayne S. Johnson
Wayne S. Johnson is offline
PostPosted: Sat Oct 03, 2009 7:36 pm    Post subject: Reply with quote
My test stand measures torque and RPM. HP can be calculated form the data.
It has two B-17 aircraft generators, which pivot on bearings to apply force to a load cell. It can generate 800 amps at 30 volts, which is 24,000 watts. The load bank can toast a slice of bread measuring 3 feet by 3 feet. It can be used with gas engines or electric motors. My electric car motor in the picture generated 72 foot pounds of torque at 500 amps.
HYBRID STARTER 6/12 https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231
Last edited by Wayne S. Johnson on Sun Oct 04, 2009 11:59 am; edited 1 time in total
koolkarmakombi
koolkarmakombi is offline
PostPosted: Sat Oct 03, 2009 9:07 pm    Post subject: Reply with quote
Wayne S. Johnson wrote:
My test stand
Shocked
grimace007
grimace007 is offline
PostPosted: Sun Oct 04, 2009 3:32 am    Post subject: Reply with quote
did i hear 1.21 jiggawatts?!?!?!
Brian
68 sedan
Dallas Air Coolers
perrib wrote:
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. Smile
cr@M wrote:
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory.
mharney
mharney is offline
PostPosted: Sun Oct 04, 2009 8:28 am    Post subject: Reply with quote
Some folx just have a lot of time on their hands. Smile
Looks awesome Wayne.
Max Welton
Max Welton is offline
PostPosted: Sun Oct 04, 2009 9:27 am    Post subject: Reply with quote
That is just too cool!
Where on earth did you come up with B17 aircraft generators?
What are you using for the load bank?
Max
1967 Type-3 Fastback
Wayne S. Johnson
PostPosted: Sun Oct 04, 2009 9:30 am    Post subject: Reply with quote
Just a interesting project for a PhD Thesis.
Doctor W. S. Johnson
Last edited by Wayne S. Johnson on Sun Oct 04, 2009 9:32 am; edited 1 time in total
The Noof
The Noof is offline
PostPosted: Sun Oct 04, 2009 9:32 am    Post subject: Reply with quote
Come in,Tokyo... Cool
Wayne S. Johnson
PostPosted: Sun Oct 04, 2009 9:48 am    Post subject: Reply with quote
Max
The loads were made with two banks of Nichrome resistance wire; each load consists of 15 wires 12 feet long. Each Nichrome wire is wound into a coil and mounted to two aluminum buss bars. Each load has a resistance of 0.075 ohms, which draws 400 amps at 30 volts. The generators can operate at 1,600 amps (almost 100,000 watts) for a short period of time. The load turns red when operating at full power; it looks like a large heater and heats up the garage in a few minutes.
Max Welton
PostPosted: Sun Oct 04, 2009 10:16 am    Post subject: Reply with quote
Thanks!
So the 15 (per bank) wires are configured in parallel?
Max
Wayne S. Johnson
PostPosted: Sun Oct 04, 2009 10:22 am    Post subject: Reply with quote
Max Welton wrote:
Thanks!
Max
Yep, I'm still looking for a 3' x 3' slice of bread to toast.
Page 1 of 5
