aquifer  Samba Member
Joined: August 30, 2021 Posts: 399 Location: Nebraska
Posted: Fri Aug 08, 2025 12:00 pm Post subject: .06” end play |
I saw a 1776 engine online. I was slightly interested but it said the end play was .06”. I asked if he meant.006”. He said no if you go that tight on a new bearing it will lock up.
I’d never heard that. Is that true? I’m eventually going to rebuild a 1600 dp for my 67 and am trying to learn all I can. Thanks in advance! _________________ Project vehicles:
1967 Beetle #1. Bought in 2024, mostly original, October 1966 build date. Java Green.
1967 Beetle #2. Bought in the mid 80's, restored myself in the late 90's, June 1967 build date. Java Green.
1998 Jaguar XJR. Bought in 2015, rust free AZ car, refurbished myself. Driven in nice weather.
Parts needed:
Door panels for a '67 in the original Gazelle color (dark tan/light brown).
Floor mats & kick panels for a '67 in the original brown color. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79896 Location: Sneaking up behind you
Posted: Fri Aug 08, 2025 12:03 pm Post subject: Re: .06” end play |
.003"-.005" is the factory spec. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11099 Location: Black Forest, CO
rcooled Samba Member
Joined: September 20, 2008 Posts: 2789 Location: Santa Cruz, CA
Posted: Fri Aug 08, 2025 12:20 pm Post subject: Re: .06” end play |
aquifer wrote: |
He said no if you go that tight on a new bearing it will lock up. Is that true? |
Absolutely not!
And don't even consider buying anything from this guy either  _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Posted: Fri Aug 08, 2025 12:47 pm Post subject: Re: .06” end play |
rcooled wrote: |
aquifer wrote: |
Absolutely not!
And don't even consider buying anything from this guy either  |
Supposedly it only has 3,000 miles on it and was fairly cheap, which is why I was initially interested. I thought the end play thing was a typo til he confirmed it.
Definitely not interested anymore! Thanks for the replies. I'm sure I'll have a ton of questions whenever I go down the road to rebuild my engine, but in the meantime I'm stocking up on information.  _________________ Project vehicles:
Parts needed:
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16673 Location: North Florida, USA
Posted: Fri Aug 08, 2025 2:53 pm Post subject: Re: .06” end play |
aquifer wrote: |
I saw a 1776 engine online. I was slightly interested but it said the end play was .06”. I asked if he meant.006”. He said no if you go that tight on a new bearing it will lock up. |
I found this page which lists common crank endplay ranges for popular engines:
https://www.enginelabs.com/engine-tech/blueprint-s...t-endplay/
You can see from the above table the largest value is 0.012" = 12-thousandths of an inch (12/1000). That's seller is suggesting 0.060" = 60-thousandths of an inch (60/1000) is acceptable end play for a relatively new engine. That is 5x the largest value on the table!
The VW spec for end play is on the low end but it is not the lowest. I found that the GM LS IV engine has a recommended crank end play of 0.0015"- 0.0078" On the tight end that is 15-ten-thousandths (15/10,000) of an inch!!! _________________ AshMan40
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 3349 Location: Memphis
Posted: Sun Aug 10, 2025 10:14 pm Post subject: Re: .06” end play |
You'll hear .06" as an audible THUNK CLUNK.
Think about how much stress that puts on the rods every time the clutch is actuated... _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11312 Location: Huntington Beach, CA
Posted: Sun Aug 10, 2025 10:52 pm Post subject: Re: .06” end play |
scrivyscriv wrote: |
Think about how much stress that puts on the rods every time the clutch is actuated... |
Plus how radical the timing would be. Everytime you accelerated or decelerated, the timing would change!
Man, the drivability complaint would be crazy odd sounding! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
