is there a trick to get the crank pulley back on?
denver_74
denver_74 is offline
PostPosted: Wed May 23, 2012 1:17 pm    Post subject: is there a trick to get the crank pulley back on? Reply with quote
i removed the old santana crankshaft pulley (engine in car - tins in place) and i started to put the new pulley on and its a tight fit!
so tight that i can only get it on approx. 1/4" (pushing, wiggling and shoving) before it sticks...no room for hammer..is there a trick?
heat?
D
1974 Standard Beetle Sunbug
donmurray
donmurray is offline
PostPosted: Wed May 23, 2012 1:23 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=512178&highlight=crank+pulley
Max Welton
Max Welton is offline
PostPosted: Wed May 23, 2012 1:25 pm    Post subject: Reply with quote
This is one of the many jobs that are easier with the engine out of the car.
I put my Berg pulley (also a nice tight fit) on with a 4x4 block of wood and a 3# mallet.
Max
1967 Type-3 Fastback
denver_74
PostPosted: Wed May 23, 2012 1:31 pm    Post subject: Reply with quote
thank you! my ol'lady is going to kill me! (i luv it)
jfats808
jfats808 is offline
PostPosted: Wed May 23, 2012 1:57 pm    Post subject: Reply with quote
You can try 400 grit wet sanding and smear some grease in the ID of the pulley before dropping the engine. Soon as you can get the nut in, tighten, then loosen, then tighten, then loosen....etc.
2276 IDA's 86C 11-1 DD
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
red caddy
red caddy is offline
PostPosted: Wed May 23, 2012 2:00 pm    Post subject: Reply with quote
Many years ago I had a major screaming match with my bride, over some piston's and rods in the dishwasher and some other "non food" stuff in the oven...
To keep the peace, (piece?) I ended up with a prefectly good washer and dryer, a dishwasher and a gas stove in MY shop. Been peaceful ever since...
Paul
If it turns $$$ into smoke and noise, I'm there.
My last build thread. http://www.thesamba.com/vw/forum/viewtopic.php?t=466571
slalombuggy
slalombuggy is offline
PostPosted: Wed May 23, 2012 2:36 pm    Post subject: Reply with quote
Nothing like getting caught with a sink full of rods and timing gears warming on the stove. Then there was the time I baked a bunch of parts I painted with enamal in the oven...boy that didn't go well Rolling Eyes
brad
mark tucker
mark tucker is offline
PostPosted: Wed May 23, 2012 2:43 pm    Post subject: Reply with quote
make sure the key hasent slid up the key way!!! it will effup the pully!!! check it before you proceed!!!
Greezy Joe
Greezy Joe is offline
PostPosted: Wed May 23, 2012 5:29 pm    Post subject: Reply with quote
brad
Been there done that and have the State Go Kart Race t-shirt. I put into the oven, go kart tires mounted to rims to get stagger like I needed, that went over real well with the wife. She blew a head gasket Shocked , I finished the race Laughing
Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound".
HeidiHo
HeidiHo is offline
PostPosted: Wed May 23, 2012 6:55 pm    Post subject: Reply with quote
When I swapped my stock pulley for a degreed I threw it in the oven for a few minutes at like 200*F, had some white grease on the counter. Pulled it out of the oven, greased it, and ran out to the car with pulley in hand. Went right on!
The joys of being single Smile
My 1970 Beetle Thread
Southern Integrity Aircoolers
DarthWeber
DarthWeber is offline
PostPosted: Wed May 23, 2012 7:03 pm    Post subject: Reply with quote
Are you related to Tom Wilson? Think
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
VIN
VIN is offline
my jaycee pully is tight fit as well. how do you guys get them back off? jaw puller? its gotta go on and come off at least 3 times i would think.
once during mock-up, once during dynamic balancing, and once during final assembly..
Co-owner, 2 Brothers Guns
[email protected]
Click to view image
mark tucker
PostPosted: Wed May 23, 2012 7:18 pm    Post subject: Reply with quote
and once more when you forget to put on the pully tin.
66brm
66brm is offline
PostPosted: Wed May 23, 2012 9:21 pm    Post subject: Reply with quote
Or one of those damn screws comes loose
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
mark tucker
PostPosted: Thu May 24, 2012 6:50 am    Post subject: Reply with quote
loose screw?? hmm Ive had a few of those........some say I still do.
HeidiHo
HeidiHo is offline
PostPosted: Thu May 24, 2012 7:44 am    Post subject: Reply with quote
No but his book sure was helpful!
mark tucker
PostPosted: Thu May 24, 2012 8:16 am    Post subject: Reply with quote
I thought that was wilson wilson? heidiho neibor tim !! do you know what time it is??
