extremebuggy Samba Member
Joined: March 13, 2009 Posts: 200 Location: Cleveland, TN
Posted: Sat May 24, 2025 4:35 pm Post subject: When to rebuild transmission? |
Got a swing axle transmission in a buggy that has been sitting for several years (about 20 years). Worked fine last time it was ran 20 years ago. Should the extended time sitting automatically warrant for a rebuild, or maybe just refresh fluid, fix any leaks and run it? What would you guys do in this case? |
oprn Samba Member
Joined: November 13, 2016 Posts: 14552 Location: Western Canada
Posted: Sat May 24, 2025 4:37 pm Post subject: Re: When to rebuild transmission? |
Don't fix what ain't broke is my policy. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Sat May 24, 2025 4:42 pm Post subject: Re: When to rebuild transmission? |
oprn wrote: |
Don't fix what ain't broke is my policy. |
That was kinda my thoughts too. Thanks for the input. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 32842 Location: Hot Arizona
jpaull Samba Member
Joined: February 22, 2005 Posts: 3625 Location: Paradise, Ca
Posted: Sat May 24, 2025 10:32 pm Post subject: Re: When to rebuild transmission? |
Is the engine out?
I have started up and tried to run many vw's after sitting for 20+ years. I personally love it. But, From my experience, If you try to run it, the input shaft seal will start to seep gear oil, and the engines main seal will start to leak. Soon, the clutch is saturated and you need to do a clutch cause its slipping.
So the big question, is the clutch good now? if it is, doing a rear main and input shaft seal will save you time and a clutch. _________________ 12.8@102.8 MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Posted: Sun May 25, 2025 11:26 am Post subject: Re: When to rebuild transmission? |
jpaull wrote: |
Is the engine out?
So the big question, is the clutch good now? if it is, doing a rear main and input shaft seal will save you time and a clutch. |
Engine had a top end overhaul, so new rear main seal installed and clutch and pressure in good condition. |
bedlamite Samba Member
Posted: Sun May 25, 2025 1:24 pm Post subject: Re: When to rebuild transmission? |
oprn wrote: |
If it ain't broke, fix it 'til it is! |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10969 Location: Black Forest, CO
jpaull Samba Member
Posted: Sun May 25, 2025 2:23 pm Post subject: Re: When to rebuild transmission? |
extremebuggy wrote: |
jpaull wrote: |
Is the engine out?
So if the transmission input shaft seal has not been changed, your new clutch might be getting soaked in gear oil after you start driving it again. _________________ 12.8@102.8 MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
esde Samba Member
Joined: October 20, 2007 Posts: 6289 Location: central rust belt
Posted: Sun May 25, 2025 4:00 pm Post subject: Re: When to rebuild transmission? |
I always found it's 50-50 on wether the seals leak of not, so I don't bother till they do..
First good drive, get the trans oil warmed up and then dump it while it's hot. watch for glitter and shrapnel, and then refill. You'll have an idea of what's ahead based on the condition of the oil and what's floating in it. _________________ modok wrote:
b-man Samba Member
Posted: Mon May 26, 2025 4:05 pm Post subject: Re: When to rebuild transmission? |
I had a swing axle bus transaxle sitting around for about 30 years, most of the time in dry storage. I took it out of my ‘66 single cab pickup in 1988 while doing a conversion to IRS and finally got around to using it again in 2018. Other than a little gear oil seepage and some bad axle boots it had been working fine.
I ended up installing it in my ‘56 panel using a Fast Fab adapter nosecone from Rancho, new axle boots and a new input shaft seal. Other than that I didn’t really do anything to it, just snugged down all the nuts and put in some high quality SWEPCO 201 80W-90 gear lube. Been working perfectly since I began driving it in June 2019.
If it ain’t broke don’t fix it.
_________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
Dusty1 Samba Member
Posted: Tue May 27, 2025 5:24 am Post subject: Re: When to rebuild transmission? |
When to rebuild your transaxle:
Rebuild your transaxle when someone pays you to rebuild your transaxle. The way that usually works is they pay you to rebuild their transaxle.
For heavy duty offroad use, build a "new" one off season. Toss your old one in your hauler as a back- up.
Otherwise, if it ain't broke, don't fix it. Hey! Is there an echo in here?
Your transmission will let you know when it's tired. It will start popping out of gear. Reverse or the lower gears get tired sooner.
I got over 500k miles on my stock '67 transmission. The stock transmission, generator and starter nave gave me problems. My '67 transmission is waiting for my next '67 project. It's thoroughly tested by now,
Schepp Samba Member
Posted: Tue May 27, 2025 7:37 am Post subject: Re: When to rebuild transmission? |
I'd put a new throw-out bearing, starter bushing, fresh seals, change the gear oil and run it. You'll know pretty quick if its good or not. |
nsracing Samba Member
Posted: Wed May 28, 2025 6:10 am Post subject: Re: When to rebuild transmission? |
About the only time I will say it ain't broke is when I went thru it myself.
All other parts to me when I bring them home are cores. That is about it.
I will just go thru it and know you are good to go. |
Schepp Samba Member
Posted: Wed May 28, 2025 7:17 am Post subject: Re: When to rebuild transmission? |
Ns,
I think 99% of people including myself feel that how a transaxle works and goes together is magic. They also don't have the tools to put one back together or have the knowhow to do so.
Its odd that so many of us will build the engine but not the trans. |
Posted: Thu May 29, 2025 2:09 am Post subject: Re: When to rebuild transmission? |
The VW trans is the unsung hero. People will dump loads of cash on a motor that lasts 2 days and not a dime on a trans.
The car ain't gonna go far w/o its working trans. And the last thing anyone wants is stuck far away from home. |
