don.ville  Samba YardMan
Joined: February 07, 2008 Posts: 2898 Location: West Palm Beach, FL
Erik G Samba Member
Joined: October 16, 2002 Posts: 13545 Location: Tejas!
Posted: Thu Jul 27, 2023 10:28 pm Post subject: Re: Holley RetroBright 7” Round LED Headlights |
morimoto is excellent stuff. I've used them in some $1200 lights. Not sure about these, thats a lof of extra on the back. There's a guy here that sells good vintage LED's that look more original and I'd imagine will fit better than those _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
MrPolak Samba Member
Joined: June 20, 2004 Posts: 1381 Location: AG ,atnaltA
Posted: Fri Jul 28, 2023 8:55 am Post subject: Re: Holley RetroBright 7” Round LED Headlights |
I went with LED bulbs because I wanted the option to replace faulty bulbs without replacing the housing, and I can use multi-color bulbs. I have Euro headlights.
H4 Hella housings with good LED bulbs are very satisfactory for a bus. I used this combo in my Vanagon.
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15191 Location: Casa de Oro, California
Posted: Sat Jul 29, 2023 6:15 am Post subject: Re: Holley RetroBright 7” Round LED Headlights |
The goodness of a headlight is mostly in the pattern, so check it before buying. A good LED bulb will retain the E-code pattern of a Hella housing.
I also have these and like the pattern and output a lot. Be your own judge when deciding how these will look in a vintage vehicle:
https://www.amazon.com/Xprite-Headlights-Approved-Headlamps-1997-2018/dp/B082SC83Q8/[url] |
Posted: Sun Jul 30, 2023 6:38 am Post subject: Re: Holley RetroBright 7” Round LED Headlights |
I think the vintage led 3500 model with Hella lens seems like the best option for me.
OE lens with the light color not too white like a modern car, but much brighter _________________
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20800 Location: Sandpoint, ID
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25877 Location: Olympia Wash Rinse & Repeat
Posted: Wed Aug 02, 2023 9:53 am Post subject: Re: Holley RetroBright 7” Round LED Headlights |
Those are not LED. _________________ In Stereo, Where Available! |
Posted: Wed Aug 02, 2023 2:03 pm Post subject: Re: Holley RetroBright 7” Round LED Headlights |
Eric&Barb wrote: |
Those are not LED. |
Yep, just figured maybe they could be an option. But, if a guy wants LED, these aren't it. _________________ You can't spell sausage without "USA"! |
Erik G Samba Member
Posted: Wed Aug 02, 2023 4:42 pm Post subject: Re: Holley RetroBright 7” Round LED Headlights |
cdennisg wrote: |
Eric&Barb wrote: |
Yep, just figured maybe they could be an option. But, if a guy wants LED, these aren't it. |
You can put an LED in those _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Wed Aug 02, 2023 5:02 pm Post subject: Re: Holley RetroBright 7” Round LED Headlights |
Erik G wrote: |
You can put an LED in those |
Any recommendations or better yet links?? _________________ In Stereo, Where Available! |
Erik G Samba Member
Posted: Wed Aug 02, 2023 9:09 pm Post subject: Re: Holley RetroBright 7” Round LED Headlights |
Eric&Barb wrote: |
Erik G wrote: |
Any recommendations or better yet links?? |
there are so many available - so, no I won't. They run from very cheap to very expensive. What's good for one lens won't be good for another. Look for a bulb that you can twist and change the pattern as needed, those you can usually make work well. Or buy from the guy that figured it out and sells here in the classifieds. No affiliation _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
panel Samba Member
Joined: December 02, 2001 Posts: 1189 Location: Victoria B.C. Canada
Posted: Sat Aug 05, 2023 8:36 am Post subject: Re: Holley RetroBright 7” Round LED Headlights |
MrPolak......any info on your yellow LED bulbs ? _________________ My '65-Subaru EJ20 Turbo conversion |
vintagecarleds Samba Member
Joined: April 28, 2015 Posts: 178 Location: Houston, TX
Posted: Tue Sep 05, 2023 11:53 am Post subject: Re: Holley RetroBright 7” Round LED Headlights |
Thanks, that's me!
Yes, the Holley lights are GOOD, and work well.
They are double the price of ours, and feature a plastic lens (ours are glass) _________________ www.vintagecarleds.com
[email protected]
713-853-9644 |
Posted: Wed Sep 06, 2023 3:39 am Post subject: Re: Holley RetroBright 7” Round LED Headlights |
Going to get down to build up some headlight buckets sometime in the future _________________
Buskraut  Samba Member
Joined: March 22, 2011 Posts: 57 Location: San Jose, CA 95125
Posted: Yesterday 10:46 am Post subject: Re: Holley RetroBright 7” Round LED Headlights |
Mini-review: Thanks to a nudge from Amazon Prime, I decided to pull the trigger on a set of the Xprite's recommended by MrPolak.
https://www.amazon.com/Xprite-Headlights-Approved-Headlamps-1997-2018/dp/B082SC83Q8/?th=1
So far, I'm impressed. In spite of the fact that they are marketed to the Jeep/Hummer crowd, they fit perfectly in the stock housings on my 65 bus. Zero tweaking required. They plug straight into the stock wiring connector, but you have to be a bit creative to stuff the connector at the back of the housing since it's on a dongle.
Beam pattern is even, with a sharp cutoff at the top so you don't blind folks. And compared to the bottom of the line Wagner bulbs I had, these things are BRIGHT! I also like that when off, they don't give the bus too much of a sci-fi alien look. Picture below are off, low beam, high beam. There is also a separate wire for DRLs, which only lights the halo (visible in the low beam pic), but I haven't connected that yet.
_________________ Erik S
'65 Type 251 / Deluxe
'03 Eurovan MVWK |
70bus  Samba Member
Posted: Yesterday 2:30 pm Post subject: Re: Holley RetroBright 7” Round LED Headlights |
Let us know if they obliterate your radio reception - my LED headlights completely drown out all radio sations with static.
Yes, some of us still listen to a radio. Especially since my bluetooth dongle has worse interference from LED lights! _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1474 Location: Richmond, VA
