Burlyhammer Samba Member
Joined: March 07, 2002 Posts: 1737 Location: Great north woods Maine
Posted: Sat Oct 29, 2022 3:37 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
| Huetti_1989 wrote: |
Nice to see a Update again!
Do you habe a idea how to prevent the patina rust? And how to prevent the underside from rust?
-Christian |
We used phosphoric acid to prep the bare metal, then silver master coated everything prior to any painting underneath. We used the phosphoric acid to prep everything else. We plan to use self etching primer over that before painting. I’m hoping that will do the trick. |
Posted: Fri Dec 02, 2022 1:22 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
I've been pecking away with the small parts blasting and painting as I go. I also started cleaning the exterior. I now have the inside ready for primer, and color where color should be. The next post should be a good one:
ddutch Samba Member
Posted: Sun Dec 04, 2022 10:34 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
| I like what you did with that door, it came out very nice with the original paint preserved and just the right amount of patina. Very curious to the outcome of the paintjob for the interior. |
braddick Samba Member
Joined: March 11, 2017 Posts: 195 Location: Australia, Victoria
Posted: Mon Dec 05, 2022 7:27 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
Great progress mate
Looking forward to the next update
Just painted the repair section on mine, took a bit to get the match right but think I’ve nailed it now
Cheers |
Posted: Wed Dec 14, 2022 2:14 am Post subject: Re: 1959 Mango walkthru metal rehab. |
| ddutch wrote: |
My goal is to keep as much original paint as possible. The door still needs some work but is getting there. The plan for the interior is to be clean. I think it’s going to be pretty nice.
Thanks ddutch! |
Posted: Wed Dec 14, 2022 2:15 am Post subject: Re: 1959 Mango walkthru metal rehab. |
| braddick wrote: |
Great progress mate
Cheers |
Your bus is looking great. You’ve done an awesome job!!!
Thanks braddick! |
Posted: Wed Dec 14, 2022 2:20 am Post subject: Re: 1959 Mango walkthru metal rehab. |
The inside is painted! I used self etching primer over the Mastercoat and then covered that with the Mango. My paint gun gave up the ghost after the primer so I had to go to Harbor Freight and bought the $25 special. I’m not a painter and it’s obvious if you look closely. There are a bunch of runs that need to be wet sanded out. But it’s green now!
von_hansel  Samba Member
Joined: June 12, 2006 Posts: 839 Location: Inland Empire
Posted: Wed Dec 14, 2022 8:31 am Post subject: Re: 1959 Mango walkthru metal rehab. |
The best thing to happen to this bus was finding you.
Your work is inspirational.
I look forward to seeing the first driving pic/ video  _________________
| Mugatu wrote: |
| von_hansel is still so hot right now |
KWZ Samba Member
Joined: July 11, 2004 Posts: 1371 Location: St. Louis, Missouri
Posted: Wed Dec 14, 2022 12:29 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
This thread is so porny _________________ '57 sunroof Standard
'63 15 window
'65 Westy SO44
'67 13 window |
Huetti_1989 Samba Member
Joined: February 13, 2011 Posts: 1360 Location: Austria
Posted: Thu Dec 15, 2022 1:19 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
| von_hansel wrote: |
I look forward to seeing the first driving pic/ video  |
My friend Matt, the owner of this bus bought it from a junkyard after it sat there for years being picked apart. I am so glad he rescued it and decided to put it back on the road.
Thanks von hansel! |
Posted: Thu Dec 15, 2022 1:20 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
| KWZ wrote: |
| This thread is so porny |
Posted: Thu Dec 15, 2022 1:23 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
looks good and unbelievable, unreal with that nice Paint!
-Christian |
The color looks awesome. I can't wait to roll it out into the sunlight. Seeing the inside painted is extremely motivational!
Thanks Christian!
P.S your truck is absolutely one of my all time favorites! |
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2151 Location: Plymouth, MA
Posted: Mon Jun 19, 2023 12:53 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
A lot has happened since this thread was last updated. I found out that my friend Matt that rescued this bus from the junkyard, as well as many other buses over the years from scrapyards, junkyards, fields, and sometimes driveways was not doing well. Unfortunately he passed away in January. He was a good friend and a bus guy through and through. He will be missed.
When we talked about the bus last summer around the time I was finishing the majority of the metal work he had asked me to finish the bus, and I agreed to it. We talked about how he wanted it to be, and that's the direction we were going in. After he passed I found out that he had left the bus to me, so I plan to finish the bus the way he wanted it (with the exception of the safaris). It has been slow going since the beginning of the year, but my son and I have been picking away at it, and are getting near the end of the project. I did not take as many pictures as I usually do, but it is moving forward. I know Matt is keeping an eye on us and I hope he approves. The pictures are out of order a little bit, but you will get the idea.
Whenever I updated the thread Matt would text me and say he saw his bus on Mango TV, so here is the Mango TV update:
When I took the Sportwagen cutout off of the bus and cleaned off the primer, I saw this dealer badge. It is from Key West, FL. The port of entry on the M Code plate is Miami so I am guessing this is where it was sold new.
Walk Thru KO Samba Member
Joined: August 14, 2003 Posts: 161 Location: North Carolina
Posted: Mon Jun 19, 2023 1:10 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
| Burlyhammer wrote: |
I'd say you need to go ahead and give this bus a name - Matt. Sorry for the loss of your friend
Stocknazi Samba Member
Posted: Mon Jun 19, 2023 3:24 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
Curious how difficult it was to re-bend the edge of the decklid after replacing the inner structure? _________________ WANTED:
Thomas Jefferson |
Bills85Westy Samba Member
Posted: Mon Jun 19, 2023 10:41 pm Post subject: Re: 1959 Mango walkthru metal rehab. |
Sorry to hear about your friend. Losing people close to us always sucks.
You are doing that bus justice and Matt will know it. _________________ 89 Tristar Syncro Doka - White
85 Westfalia Syncro (conversion)
SAH 1.8T Conversion - 2005 AWP
Engine Conversion Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=612144&highlight=
85 Doka L345 Grey - 1.9L |
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1366 Location: Yulee FL
Posted: Tue Jun 20, 2023 5:24 am Post subject: Re: 1959 Mango walkthru metal rehab. |
My condolences-
You are making your friend proud by the work you've put into this thing! Keep the hammer down! |
