Cleaning Aluminum Door Sills?
Max Welton
Max Welton is offline
PostPosted: Tue Apr 08, 2025 3:07 pm    Post subject: Cleaning Aluminum Door Sills? Reply with quote
What is a good way to clean up aluminum door sills?
Max
1967 Type-3 Fastback
Max Welton
PostPosted: Tue Apr 08, 2025 3:31 pm    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
Max
squaretobehip
squaretobehip is offline
PostPosted: Tue Apr 08, 2025 8:09 pm    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
Clean them really well and spray them with a flat nickel paint. We had to repair the carpet side on mine with some clear epoxy. Usually that part is rotted away from wet carpet. They will look really nice with a nice coat of flat nickel.
1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
LowThrum
LowThrum is offline
PostPosted: Wed Apr 09, 2025 8:31 am    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
agree, scrub them down with a good rust remover and stiff wire brush, use some mineral spirits to clean them, then spray with either nickel or silver color paint.
I did mine and was absolutely shocked at how close the color was to an original looking finish.
I'm at work right now, so of course I don't have the sills to show how they came out or the paint to show what I used.
Max Welton
PostPosted: Wed Apr 09, 2025 8:53 am    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
I have an old beetle sill and tried a wire brush. It left nasty marks. Glad I tried it on something I don't care about. I need a much softer brush. Wink
And I'll make a long tray so I can soak these in evaporust.
Max
sctbrd
sctbrd is offline
PostPosted: Wed Apr 09, 2025 10:22 am    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
Try pumice hand cleaner like Go-Jo and a small bristle brush (for small parts at work we use toothbrushes). Really good for cleaning aluminum with no scratches.
More for oil and dirt but should work on rust stains.
Ossipon
Ossipon is offline
PostPosted: Wed Apr 09, 2025 12:35 pm    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
What everyone said, And my lesson learned was even the dremel polishing will scratch the aluminum. I was amazed how soft it is in the end. I luckily had a spare to practice. I would definitely clearcoat with a rattlecan or better if you get the look you want.
Ossipon
--Two truths in life: Volkswagens Rust and everything will die at some point --
VWs in my life:
Air
Type 1 - 59, 62, 63, 71 Super 68 KGhia/ Type 2 - 59 Single Cab / Type 3 - 64 Notch
Water
GTI 83, Jetta 81, 85, 87, 91 TDI, 98 TDI, 09 / New Beetle 99 / SportWagen 05, 13 / Tiguan 18 / T3 92 /Taos 24... And don't about me and my experiences with my Dasher and Quantum
Bobnotch
Bobnotch is offline
PostPosted: Thu Apr 10, 2025 1:14 pm    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
Keep in mind those sill plates are anodized aluminum, which is why they scratch so easily. In your case Max, it looks like you have grinding dust imbedded in them that got left out in the rain (which caused the rust).
You'll probably have to sand them out, and spray paint them, or maybe even powder coat them, as I don't know if having them anodized again will fix them. The aluminum is soft, so keep that in mind, whatever you do to them.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
djfordmanjack
djfordmanjack is offline
PostPosted: Thu Apr 10, 2025 3:57 pm    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
In a case where welding or grinding has left rust speckles, I would try modern wheel cleaner. They are set up to remove ( brake disc) rust particles and dust from alloy wheels. it is the stuff you spray on and which turns purple, then rinse off.
54 Oval project
62 Dickholmer, Seeblau L360
Roadbeater
Roadbeater is offline
PostPosted: Thu Apr 10, 2025 5:36 pm    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
I beadblasted them then aluminum wheel polish.
69 Fastback
eyetzr Premium Member
eyetzr is offline
PostPosted: Fri Apr 11, 2025 1:55 pm    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
A brass bristle brush would remove the rust and not harm the annodiziing to much.
A light respray of silver spray bomb should touch up the anodized aluminum.
I think he meant "rare", as in "not well-done"
Max Welton
PostPosted: Fri Apr 11, 2025 4:21 pm    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
How did that turn out? Picture?
Max
Boroboy63
Boroboy63 is offline
PostPosted: Thu Apr 24, 2025 5:44 am    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
I cleaned mine with wire wool, epoxy primer, paint and then clear coat, not original, but the best I could do with what I had.
notchboy
notchboy is offline
PostPosted: Thu Apr 24, 2025 8:34 am    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
This product is by far the best work, fastest and most cost effective way to clean those sill covers.
https://www.homedepot.com/pep/Rust-Oleum-Professio...ds#overlay
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Max Welton
PostPosted: Thu Apr 24, 2025 10:18 am    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
Thanks. That's paint. What do you use to CLEAN them?
Max
notchboy
notchboy is offline
PostPosted: Thu Apr 24, 2025 11:19 am    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
Max
Gotcha, gotcha. I used this to clean the 356 wheels I used on my T34 project.
https://sierramadrecollection.com/products/silver-...hAQAvD_BwE
1964 1500 S
Roadbeater
PostPosted: Sat May 03, 2025 5:34 am    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
Here's mine that I beadblasted and used mothers on. Probably could use another polishing.
69 Fastback
notchboy
notchboy is offline
PostPosted: Sat May 03, 2025 10:35 am    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
So anyway Max. My sarcastic posts were to emphasize that you don't, at least I never have "cleaned" them. Only sets I've "cleaned" are super nice ones in great shape.
They are notorious for decaying. Getting pitted and crusty. They never came shinny and have a dull anodized finish to them. So painting is a great, cheap, looks good, solution IMHO.
I had my Type 34 ones polished. And it wasn't cheap. I want to say it was close to $500 to get these done. If they were dull finished Type 3 ones, Id of rattle canned them for sure.
1964 1500 S
my3bugs
my3bugs is offline
PostPosted: Sat May 03, 2025 10:47 am    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
aluminum doesnt rust , those stain are from something else nearby . ya i like Mothers mag polish for aluminum .
Max Welton
PostPosted: Tue May 06, 2025 11:09 am    Post subject: Re: Cleaning Aluminum Door Sills? Reply with quote
So ... media blast, apply primer, apply aluminum-look paint.
Before:
After:
Good enough
Max
