Max Welton Samba Member
Joined: May 19, 2003 Posts: 11038 Location: Black Forest, CO
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 4026 Location: San Jose, CA
Posted: Tue Apr 08, 2025 8:09 pm Post subject: Re: Cleaning Aluminum Door Sills? |
Clean them really well and spray them with a flat nickel paint. We had to repair the carpet side on mine with some clear epoxy. Usually that part is rotted away from wet carpet. They will look really nice with a nice coat of flat nickel.
_________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
LowThrum Samba Member
Posted: Wed Apr 09, 2025 8:31 am Post subject: Re: Cleaning Aluminum Door Sills? |
agree, scrub them down with a good rust remover and stiff wire brush, use some mineral spirits to clean them, then spray with either nickel or silver color paint.
I did mine and was absolutely shocked at how close the color was to an original looking finish.
I'm at work right now, so of course I don't have the sills to show how they came out or the paint to show what I used. |
sctbrd Samba Member
Joined: May 06, 2013 Posts: 284 Location: Moravia, Czech Republic
Posted: Wed Apr 09, 2025 10:22 am Post subject: Re: Cleaning Aluminum Door Sills? |
Try pumice hand cleaner like Go-Jo and a small bristle brush (for small parts at work we use toothbrushes). Really good for cleaning aluminum with no scratches.
More for oil and dirt but should work on rust stains. |
Ossipon Samba Member
Posted: Wed Apr 09, 2025 12:35 pm Post subject: Re: Cleaning Aluminum Door Sills? |
What everyone said, And my lesson learned was even the dremel polishing will scratch the aluminum. I was amazed how soft it is in the end. I luckily had a spare to practice. I would definitely clearcoat with a rattlecan or better if you get the look you want. _________________ Ossipon
--Two truths in life: Volkswagens Rust and everything will die at some point --
VWs in my life:
Air
Type 1 - 59, 62, 63, 71 Super 68 KGhia/ Type 2 - 59 Single Cab / Type 3 - 64 Notch
Water
GTI 83, Jetta 81, 85, 87, 91 TDI, 98 TDI, 09 / New Beetle 99 / SportWagen 05, 13 / Tiguan 18 / T3 92 /Taos 24... And don't about me and my experiences with my Dasher and Quantum |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23362 Location: Kimball, Mi
Posted: Thu Apr 10, 2025 1:14 pm Post subject: Re: Cleaning Aluminum Door Sills? |
Ossipon wrote: |
What everyone said, And my lesson learned was even the dremel polishing will scratch the aluminum. I was amazed how soft it is in the end. I luckily had a spare to practice. I would definitely clearcoat with a rattlecan or better if you get the look you want. |
Keep in mind those sill plates are anodized aluminum, which is why they scratch so easily. In your case Max, it looks like you have grinding dust imbedded in them that got left out in the rain (which caused the rust).
You'll probably have to sand them out, and spray paint them, or maybe even powder coat them, as I don't know if having them anodized again will fix them. The aluminum is soft, so keep that in mind, whatever you do to them. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2365 Location: Graz, Austria, Europe
Roadbeater Samba Member
Joined: January 15, 2011 Posts: 61 Location: Central Ohio
Posted: Thu Apr 10, 2025 5:36 pm Post subject: Re: Cleaning Aluminum Door Sills? |
I beadblasted them then aluminum wheel polish. _________________ 69 Fastback |
eyetzr  Samba Member
Joined: October 09, 2013 Posts: 1469 Location: Toronto, Ontario. Canada
Posted: Fri Apr 11, 2025 1:55 pm Post subject: Re: Cleaning Aluminum Door Sills? |
A brass bristle brush would remove the rust and not harm the annodiziing to much.
A light respray of silver spray bomb should touch up the anodized aluminum. _________________ I think he meant "rare", as in "not well-done" |
Boroboy63 Samba Member
Posted: Thu Apr 24, 2025 5:44 am Post subject: Re: Cleaning Aluminum Door Sills? |
I cleaned mine with wire wool, epoxy primer, paint and then clear coat, not original, but the best I could do with what I had. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22659 Location: Escondido CA
Posted: Sat May 03, 2025 5:34 am Post subject: Re: Cleaning Aluminum Door Sills? |
Here's mine that I beadblasted and used mothers on. Probably could use another polishing.
Posted: Sat May 03, 2025 10:35 am Post subject: Re: Cleaning Aluminum Door Sills? |
So anyway Max. My sarcastic posts were to emphasize that you don't, at least I never have "cleaned" them. Only sets I've "cleaned" are super nice ones in great shape.
They are notorious for decaying. Getting pitted and crusty. They never came shinny and have a dull anodized finish to them. So painting is a great, cheap, looks good, solution IMHO.
I had my Type 34 ones polished. And it wasn't cheap. I want to say it was close to $500 to get these done. If they were dull finished Type 3 ones, Id of rattle canned them for sure.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
my3bugs Samba Member
Joined: June 18, 2003 Posts: 846 Location: Moreno Valley
Posted: Sat May 03, 2025 10:47 am Post subject: Re: Cleaning Aluminum Door Sills? |
aluminum doesnt rust , those stain are from something else nearby . ya i like Mothers mag polish for aluminum . |
