Max Welton Samba Member
Joined: May 19, 2003 Posts: 11047 Location: Black Forest, CO
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35919 Location: Conejo Valley, CA
Posted: Mon May 19, 2025 1:32 pm Post subject: Re: Backup light |
This squishy foam rubber gasket material, cut to length, might be made to work (might be a bit too large). Just have the gap at the bottom.
https://vwispwest.com/inner-seal-311945235x/ _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23394 Location: Kimball, Mi
Posted: Tue May 20, 2025 12:09 pm Post subject: Re: Backup light |
Max Welton wrote: |
Scored these at the swaps yesterday. Cleaning up nice!
I've seen these on bugs, KGs and type-3s. What is the correct way to mount these on my 67 type-3? Brackets or direct to the bumper?
Also, I'd like to get new gaskets. Not finding them.
Max |
There should also be a rubber plug for the wire in the mounting stem. Normally these just bolt onto the top of the bumper. What I did was make a "U" shaped bracket and used a stainless steel carriage bolt to mount mine under the bumper for a cleaner look.
The gasket you have is the seal for the lense to housing. Maybe ISP carries them, or Wolfsburg West, or maybe another VW parts supplier, as those lights were used on several models and with different lenses (red for a fog light for example). I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5559 Location: Lefty, CA
