Getting ready to do some painting
RicMcK Premium Member
RicMcK is offline
PostPosted: Tue Jun 17, 2025 11:50 am    Post subject: Getting ready to do some painting Reply with quote
I haven't painted a car in 30 +years, but I'm going to give it a try. I've prepared the front, door jams, doors (inside & out) and roof. I'm going to paint it in sections with the part lines on the weld seams. The roof will be painted with the pop top in place. The tape line will be below the gutter on the top weld seam. On the vertical weld seam for the left center panel, and inside the sliding door at the rubber seal.
Westco had to custom mix the paint, because mixing by the color code, and color measuring machine, there was way too much silver flake and not enough blue.
If the weather is good tomorrow or Thursday morning I will shoot the base and clear coat on the van. It needs to overcast to keep the temperature ok. Doors are still in work.
We will see how good my skills are and how "clean" my tarp garage is.
I've painted cars in the driveway before (59 bug, 70 tin top bus, 1936 Ford, they all came out ok. Nothing some sanding and buffering didn't fix. However, I am concerned about the the small space and dry overspray.
Rick McK
Seattle
89 Westfalia-2.2L WBX "VINNY"
2006 TDI Jetta
1936 Ford Pick up
70 tin top, 700k mi when sold in 91
58 split window (first car)
58 split window bug - long gone.
dhaavers
dhaavers is offline
PostPosted: Tue Jun 17, 2025 1:24 pm    Post subject: Re: Getting ready to do some painting Reply with quote
Whatever you do, I’m sure it’ll look better than mine does…or ever will! Laughing
Love the prep pics, looks good from here! Keep us posted…
- Dave
"The WonderVan"
dobryan
dobryan is offline
PostPosted: Tue Jun 17, 2025 2:00 pm    Post subject: Re: Getting ready to do some painting Reply with quote
Looking good.
(Be sure to put some garbage bags over the tires and rims or you'll regret that.)
Dave O
The Western Syncro build
jimf909
jimf909 is offline
PostPosted: Tue Jun 17, 2025 2:35 pm    Post subject: Re: Getting ready to do some painting Reply with quote
Thanks for providing some inspiration. My van is in need of rust abatement and some paint but I'm not ready to spend $15K for the work, esp. given the abuse it gets. A driveway roller or spray job is probably what's in its future.
As for painting in the driveway, I did a few cars like that many years ago and discovered my anger for the wind. Oy. Your tarp setup looks luxurious compared to being outside.
- Jim
Butcher wrote:
Guilty as charged.
Red Ryder
Red Ryder is offline
PostPosted: Tue Jun 17, 2025 4:28 pm    Post subject: Re: Getting ready to do some painting Reply with quote
Enjoy your adventure and don’t forget to wear a proper respirator!
“Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic)
Abscate Premium Member
Abscate is offline
PostPosted: Tue Jun 17, 2025 4:53 pm    Post subject: Re: Getting ready to do some painting Reply with quote
You’re not leaving the windows in are you?
Very Happy
Phishman068
Phishman068 is offline
PostPosted: Tue Jun 17, 2025 4:59 pm    Post subject: Re: Getting ready to do some painting Reply with quote
Looks great!
You've got this!!!!
http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry."
alaskadan
alaskadan is offline
PostPosted: Tue Jun 17, 2025 6:17 pm    Post subject: Re: Getting ready to do some painting Reply with quote
Looks familiar. Is that autobody plastic masking film? If not, painting next to plastic that has overspray can cause huge flakes to fly off into your fresh wet paint. Not sure what it is but everytime I've sprayed a car outside it never fails that there's a bug hatch! Then ( my theory ) they get high on the fumes and fly into the paint. Lol. And how the hell can some little bugs backstroke a couple inches before they die! Good luck.
kaalualu
kaalualu is offline
PostPosted: Tue Jun 17, 2025 10:15 pm    Post subject: Re: Getting ready to do some painting Reply with quote
It makes sense spraying in sections. Tight area.
All the seams and body lines help. Have fun.
Looking forward to results.
'84 Transporter 16" CLK's/LED's/ AT's/Mansi injectors
'86 Wolfey Weekender Westfalia AT's/otherwise stock
Sold-'82 TinTop Diesel
RicMcK is offline
PostPosted: Sun Jun 22, 2025 7:19 am    Post subject: Re: Getting ready to do some painting Reply with quote
I'm making progress. Shot the color & clear coat on Tuesday. It worked! Not perfect, but as good as the orginal finish it has a little orange peel in places (nothing a light sand and polish won't fix).
I will post some photos. I'm now on to the doors. They are ready for primer. They only needed to tiny bit of glazing putty. However the bottom of the slider took all day to get the dents out and make it look proper. Had to the old spot heating with the oxy-act touch to shrink a spot that oil canned. More photos to come.
Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
zerotofifty
zerotofifty is offline
PostPosted: Sun Jun 22, 2025 9:05 am    Post subject: Re: Getting ready to do some painting Reply with quote
Paint it all in one shot for best results. that plastic can shed dried paint, and thus ruin the wet paint on the body. also when removing the plastic, it can shed paint onto the yet to be
painted panels, which will then need be removed, create paint dust.
I have pumped in clean air by using a box fan with a furnace filter on it, connected to a tunnel made of plastic film all taped together to give positive pressure into my spray both. Get the fan well away from the both, as the spray can create an explosive atmosphere given all the flammable solvents, you dont want an electric motor that is not explosion proof in or near the spray booth. so have the fan and filter remote, feeding clean positive pressure air into the booth you made.
Change your respirator cartridges often. protect your eyes, a full face respirator is best. Wear a lint free bunny suit.
have fun
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
zerotofifty
PostPosted: Sun Jun 22, 2025 9:07 am    Post subject: Re: Getting ready to do some painting Reply with quote
Tape, even painters tape can leash adhesive residues, so you need to remove said tape residues before painting the next section, hence do it in one shot.
have fun
Words to live by.
RicMcK is offline
PostPosted: Thu Jul 03, 2025 11:47 am    Post subject: Re: Getting ready to do some painting Reply with quote
I'm done for now.  I got the front end (to aft weld seam on the B pillar), door jams, roof (to the weld seam under the gutter), luggage rack, front and sliding doors, rocker panels and front bumper all painted. I left the windshield in as I recently had it replaced and the body frame was in perfect shape. I put a piece of 4mm cord under the seal so I could properly mask it.
It came out amazingly good. Better than I expected.  I had WestCo (local auto body paint Co.) custom mix the color to try to match as best we could. Mixing via the color code was not good, there was too much silver and not enough blue.  After several tries we got as close as we could. I used the sliding door cover panel as the test panel, to both match and do a blend to see how it looked. Once we decided it was good enough, they put it in SprayMax rattle cans.  I used rattle cans for everything (primer, base coat, and clear coat).
I removed the doors and dash, then prepped the jams, roof, and front end. I used green masking tape (rough surface) for masking the tent.  All rust was treated with either RustMort or Dupi-Color Rust Stop.
I painted everything in a 10x18Ft tarp garage with 6mil plastic as a floor, and 2 box fans. Yes it is too small, but it worked (for the most part).
Order of painting:
I started with the top and under the gutter. Then the roof I only painted up to the tent molding on 3 sides and just forward of the luggage rack rear screws, not under the luggage rack as the paint was fine there, and "you don't see it", then 3 " around the front of the luggage rack area. Then I did the door jams, and finished with the front end.  I put 2-3 coats of base on then 2-3 coats of SprayMax 2K high gloss clear.
The next painting session was the doors and luggage rack.  I did not have enough ventilation when doing the doors and the overspray drop-out causing them to orange peel. The orange peel was all my fault, as I did not look around and see how much overspray was floating around. I was able to polish them out (1500 grit, and 3 stage polishing compounds).  I then painted the sliding door.  Because the sliding door had some damage (dents) in the rocker area I cleaned it up and painted it at the same time. I used a combo of PDR and Oxy-Acet touch (fix an oil caning section), hammer and dolly to get things straightened out. I painted the lower front roller assembly blue and it looks much better. Before I painted the jam blue I cleaned up the lower track area and painted it with truck bed paint. I like this stuff as it is really tough and dries almost instantly.
The biggest PITA of the project were the front doors, and dashboard.  Dealing with the wiring, mirrors, window seals, ETC. One PITA was the left washer nozzle hose was too short and it dropped inside where it was very difficult to get to. Once I got to it, I extended the hose. The other PITA was I forgot the tape over the luggage rack bolts. This meant I had to drop the back of the headliner to remove them to clean them up.
I was able to mount both the front and sliding doors by myself using 5 & 6 Gal buckets, sawhorse, and shims.  It was easier than I thought it would be. I put the sliding door glass gasket (Peace Vans garage sale $5) in by myself by setting the bottom edge in place and holding the top with 2" blue masking tape. Again 4mm cord and soapy water it went in easily.  The new front and sliding door gaskets went in easily with 3M "super weather strip and gasket adhesive". It is basically rubber cement. It dries almost instantly so I was able to smear the gasket, put it in place and hold it. I did NOT need to coat both surfaces first. Surprisingly, the areas where I applied it to the door first, then the gasket did not stick as well as the single step method.
I was lucky in getting the doors aligned as there was still a paint mark for the screw placement. The new gaskets (Cip1) are really tight. The rear latch are set all the way out and the door is still hard to close.  NO WIND NOISE Smile.
When reinstalling the dash I put protective tape around the A pillar area so I would not scratch it, as I had done before.
I'm not sure when I will work my way to the rest of the van, but I feel like the hard part is over.  I will say it is totally possible to make a great paint job with rattle cans.  I did it more as an experiment. I figured it would be worth $500 in paint to try. If it failed at least it would be ready for a real painter and paint booth.
Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
Braukuche
Braukuche is offline
PostPosted: Thu Jul 03, 2025 2:21 pm    Post subject: Re: Getting ready to do some painting Reply with quote
Looks nice!
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
bobhill8 Premium Member
bobhill8 is offline
PostPosted: Thu Jul 03, 2025 7:08 pm    Post subject: Re: Getting ready to do some painting Reply with quote
WELL DONE - Jealous.
1986 Westy
1971 Squareback
dhaavers
dhaavers is offline
PostPosted: Thu Jul 03, 2025 9:58 pm    Post subject: Re: Getting ready to do some painting Reply with quote
Looks good from here…me next!
Wink
- Dave
"The WonderVan"
calsurf
calsurf is offline
PostPosted: Sat Jul 19, 2025 9:04 am    Post subject: Re: Getting ready to do some painting Reply with quote
Looks great, good job.
pnwkayaker
pnwkayaker is offline
PostPosted: Sat Jul 19, 2025 9:12 am    Post subject: Re: Getting ready to do some painting Reply with quote
Like everybody said, it looks very good!
Could you please put some pics on your paint equipment? I think you used spray cans and no air compressor, correct? Did you use any adapter to be able to handle and press it more easily/consistently? Also, I believe that you asked Westco to transfer the paint into the pray cans, is that something they normally do?
I have some rust spots in my van that I'm debating if I'll have them addressed by a shop or give it a try myself. In terms of paint equipment/setup, I'm very limited (just have a pancake air compressor), so your successful paint job is very inspiring and intriguing.
87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link)
jlrftype7
jlrftype7 is offline
PostPosted: Sat Jul 19, 2025 10:23 am    Post subject: Re: Getting ready to do some painting Reply with quote
You might want to look into a Rental Compressor if they're available. You want a larger tank than a Pancake Compressor has. For spray Guns, High Volume Low Pressure models, HVLP, are available everywhere. Harbor Freight has a devoted following for some of its spray guns.
I bought Astro Pneumatic spray guns for myself, one for Primer with a larger tip/needle, and a finer gun for Top Coats.
A dedicated pressure regulator, either right at the gun itself, or as a 2nd regulator to one upstream at your Filter Assembly, are nice to have as well for tweaking pressure at the gun.
Use a new hose, or one that's never had air tool oil run through it so you don't contaminate your paint work from accidentally introducing oil into your paint.
Get a GOOD respirator to protect your lungs, modern paint is nothing to laugh at, depending on what you get from your supplier.
If it's single stage and no clear as a 2nd coat, your work will be easier than if you have to Clear Coat existing work/paint.
‘84 Tin Top - Hilga....Auto
RicMcK is offline
PostPosted: Sat Jul 19, 2025 10:27 am    Post subject: Re: Getting ready to do some painting Reply with quote
Yes Wesco will load spray cans. They use special "SprayMax" brand cans. The cans have a good vertical spray pattern (like a real spray gun).
To back up a little bit. I've painted 4 cars in both a driveway and garage using old HVHP guns. So I have some experience with the process. However, that doesn't mean you can't do it. Remember if you get runs you either wish they were not there or sand them out. 99% of the work is surface prep. Paint only makes every mistake look HUGE. So take your time. Your eye and finger tips will help you a lot in finding defects. Yes, any home job will not be perfect. There will be some dust, missed pin holes, some minor orange peel. Some defects can be sanded and polished out. Others you will live with or redo.
Yes respirator and goggles (overspray on the eyes is BAD) are required, along with dust masks and gloves.
My biggest mistake was not watching the amount of clear coat over spray in the space. Some “fell out” on the doors and I had to sand and polish out the orange peel. I needed more ventilation and stop painting if there is too much overspray in the air. Yes, watch out for paint flaking off the plastic. Some plastic sheeting is designed for spray paint, and doesn't flake.
Remember,the original painting was done by hand (now it's all robots). There was orange peel and defects. Modern car paint and application is vastly different than in the 80's.
Watch a bunch of YouTube videos on how to paint.
For minor rust issues I wire brush (hand & drill). First clean the entire painted area and use real wax remover and or solvant to remove ALL WAX AND OILS. Then treat the area with "Rust Mort or Rust Fix (Rust Fix is the same chemistry as Rust MORT, but in a spray can (much easier to apply). Then comes the big decision point. Cut-out and weld in new sheet metal or patch and fill. For this job I did the patch and fill for now. I need to replace the left rocker panel and the lower B pillars with new METAL. But that will happen later. However, for now I did the patch and fill method. Remove as much rust as possible, treat with Rust Fix, then por 15. Prime clean metal with etching primer. Use some sheet rock patching mesh to bridge any holes. Make the mesh several inches bigger on all sides of the hole. Bond in place with reinforced bondo, and fill towards the outside with the reinforced bondo. Keep it as thin as possible. Feather with regular bondo and glaze. I only use 1 part filler for the tiny pin holes (takes too long to cure if it has any thickness to it) . Sand with long hard foam blocks (with adhesive backed sandpaper), bondo can finish off with 220 grit. Sand clear coat with 2000 if it's smooth if you are going to blend into it. Otherwise 600 or 800 until it's smooth. Prime with high build primer.
Prior to applying the base coat (color) clean with wax remover, mask clean again, tack rag, spray clear sealer. This will make a shiny surface so you can find any imperfection. Repair it as needed, and repeat cleaning steps. Spray base coats (color). Start with a thin coat and then increase the thickness - wetness for the next several coats 2-4 total. Let it flash and clear-coat with SprayMax 2K. 2-4 coats.
Remove masking as soon as the paint is safe to touch.
Let it cure for at least 2-4 days, then polish out (sanding if required) the minor defects. I sanded through the clear coat and one spot of base. I will feather the surrounding area with 800-2000, then air brush the base coat, followed by 2K clear coat and feathering clear coat. Once it's cured, polish out the blending area.
Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
