1965 SO42 Westy Nr 0021
velvetgreen
velvetgreen is offline
PostPosted: Sun Jul 06, 2025 5:50 pm    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
Hopefully it didn't come off as manspalaining.. Just a reminder . To assist in your excellent preservation efforts
edgood1
edgood1 is offline
PostPosted: Mon Jul 07, 2025 1:44 am    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
Not at all, I just meant that I spent way more time than I should have measuring all the dimensions, curves and location of that hole Very Happy
I really do appreciate the info you provide
1987 Syncro Westfalia powered by Subaru
'65 Westfalia
edgood1
edgood1 is offline
PostPosted: Mon Jul 07, 2025 5:43 am    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
I cleaned the engine compartment, painted the new battery tray, installed the gas tank with a new sender and prepped for engine reinstallation.
I was going to clean the engine up and paint the tin , but it's so original and clean I might roll with it as is. I'm rebuilding the original carb to make it complete. It did have an odd front tin piece on it that didn't fit the bus engine opening, maybe from a VW thing? I replaced it with one that fits properly.
Edit: the odd front tin looks like a '71 only bus tin, I didn't realize buses got upright engines with doghouse oil coolers. Today I learned. That means this engine was from a 71 bus as I have no doubt it's all original and came with the altitude correction valve on the carb.
'65 Westfalia
chiroracer
chiroracer is offline
PostPosted: Mon Jul 07, 2025 12:21 pm    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
Cool engine . 71 complete bus engines are a thing , the pinnacle of the upright 1600.Great to keep the package original albeit not to this bus.
SL
66 bajawestfalia
2/1600 buggy Kreger chassis 4 baja 1000(waiting to re emerge)
71 911 track car
65 kombi EZ camper (sold to OG owner in oregon)
69 class 11 racecar Sold to GH racing now the famous Dora SCOREchampion
70 class 11 prerunner
edgood1
edgood1 is offline
PostPosted: Tue Jul 08, 2025 6:25 am    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
I was trying to convince myself to use the engine as-is, with rusty heater boxes but my better judgement got the better of me. I was dreading the job because working with old exhaust parts flat out sucks. This morning I bit the bullet and dove in. I only broke off one stud (but I broke it three times trying to get it out). I drilled it out and tapped it
I opted to use a good used set of heater boxes to match the style of the engine. I have a few sets of newer aftermarket ones kicking around but I trust the originals better and they work nicely on this engine.
Here they are installed
The old ones in the garbage where they belong
The job sucked as expected but could have been a lot worse.
'65 Westfalia
von_hansel Premium Member
von_hansel is offline
PostPosted: Tue Jul 08, 2025 7:57 am    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
Those heater boxes are crusty! Having stock heat is really nice on cold days compared to no heat.
Looks like you will be driving down the road in no time. I can envision a camping trip in your near future Laughing
Mugatu wrote:
swharris
swharris is offline
PostPosted: Wed Jul 09, 2025 12:07 pm    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
edgood1 wrote:
. It seems just about every part is there, including all the rare westy bits.
So you have the big top tent/poles/rail bracket, cot canvas/poles/bag, Westfalia woodslat rack, ladder? If so, now that is a score! I do see you have the ultra rare accessory wiper knob in ivory Wink Congrats on the bus!
swharris
swharris is offline
PostPosted: Wed Jul 09, 2025 1:45 pm    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
edgood1 wrote:
von_hansel wrote:
what a score! Looks fairly dry too. The paint should buff out nicely.
Looking forward to seeing updates.
Please take pictures of the water tank if you pull the ice box out.
It's pretty dry. The cargo floor needs some attention the long rocker and short passenger rocker have a few small rust holes but should be easy fixes. This is definitely one of the better condition buses that I've found. This will probably be a preservation as opposed to a full restoration. We plan to use it as it was intended.
My son and I were just going through it and found the toolkit and original jack Shocked
A day or two soak in cleaning vinegar will clean those up nicely.
edgood1
edgood1 is offline
PostPosted: Thu Jul 10, 2025 6:05 am    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
No tent or ladder but I have the roof rack and the cot. I was/am very happy to have the uber rare early clamshell lights, early water pump along with all the other unique things about a super early so42.
Today the engine went in.
I rewired it, trying to return it as close to stock as possible. There were some shenanigans in there like a starter relay and a 6v to 12v converter which are now gone. It went in really smoothly. Just one literal snag with the right side heater box having an unnecessary extra lever that got in the way. I cut that off and it went right in.
'65 Westfalia
BarryL Premium Member
BarryL is offline
PostPosted: Thu Jul 10, 2025 6:13 pm    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
I always wondered what the slot in the screwdriver handle was for.
LAGrunthaner Premium Member
LAGrunthaner is offline
PostPosted: Fri Jul 11, 2025 3:18 am    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
Wow BarryL that is an interesting design I wonder if it is for another tool to get some torque.
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
BarryL is offline
PostPosted: Sat Jul 12, 2025 6:25 pm    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
I looked at mine today. On the opposite side is a perfect hole. Both sides are blocked from going all the way through with a strand of plastic. Strange...I'd love to know for sure. It looks like you could put a spare fuse or two on the long slot.
vwuberalles
vwuberalles is offline
PostPosted: Sun Jul 13, 2025 7:32 am    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
I assumed it was to allow it to flex a little bit so it can squeeze onto the screwdriver shaft to hold it in place.
edgood1
edgood1 is offline
PostPosted: Sat Jul 19, 2025 6:47 am    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
I had to cut out the rocker assembly. It wasn't solid enough to save.
As usual the rust was worse the further I dug into it. It's not terrible though and should be a straightforward repair.
'65 Westfalia
edgood1
edgood1 is offline
PostPosted: Mon Jul 21, 2025 2:46 pm    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
The brakes are toasted Shocked
'65 Westfalia
velvetgreen
PostPosted: Tue Jul 22, 2025 6:47 am    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
Where's the pads-or is that what the brown parmesan cheese dust is in the drums Smile?? Nice work looking fwd to seeing it back on the road
edgood1
edgood1 is offline
PostPosted: Tue Jul 22, 2025 8:14 am    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
Yeah the liners came out with the drums on both sides. They weren't stuck, just sitting lose between the drum and the shoe metal. There's no fluid in the lines either, but some of the soft lines replaced and look new and still have the ate tags on them.
I'm going to Go through the entire brake system and make sure everything is in order. Most of it will probably get replaced.
I had this and the 63 bus side by side doing rear brakes yesterday Very Happy
'65 Westfalia
edgood1
edgood1 is offline
PostPosted: Sat Jul 26, 2025 11:03 am    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
More rust repair behind the short rocker
There was a mouse nest in the top hat section in the jack point that rusted it from the inside out. I cut out the rust and added this piece to restore the integrity. Not intended to be pretty as this will get hidden by the floor
The front section is up next
'65 Westfalia
edgood1
edgood1 is offline
PostPosted: Sun Jul 27, 2025 8:17 am    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
After cutting off some rust metal to assess the repair needed I decided to bisect the top hat section of the front outrigger and fab up a patch panel. I'm trying to save as much good metal as possible and all the replacement metal is from the panel sections I cut off my 63 bus.
Fabricobbled this replacement piece...
Welded it in ( and cleaned up the mess my spot weld cutter made)....
And cleaned it all up. I drilled the hole the original had, not exactly sure what it's for but it's there.
I'll fix the surrounding sheet metal next and then start fitting the inner rocker.
'65 Westfalia
edgood1
edgood1 is offline
PostPosted: Wed Jul 30, 2025 7:21 am    Post subject: Re: 1965 SO42 Westy Nr 0021 Reply with quote
I got the inner rocker panel fitted and welded in.
Next is the outer rocker and short rocker panel. I fitted them both and just need the paint to dry to weld them in. This is the first time I've used "wolfsburg west" panels (not sure who actually makes them), but they are really good. I always expect to have to tweak new panels to get them to fit but these will fit right in, which is a pleasant surprise. They're very accurate to the originals as well.
'65 Westfalia
Page 3 of 4
