Big Mike Cbad Samba Member
Joined: December 19, 2019 Posts: 75 Location: Carlsbad
Posted: Mon Feb 22, 2021 5:24 pm Post subject: Ghia wire harness rubber question 1963 |
Question about this small rubber boot in the passenger lower front fender area behind the splash guard where the wire harness comes out of the tube in the heater channel and runs up the fender behind the splash guard and into the front trunk area. Didn't see this rubber noted in the Ghia diagrams and have not seen it in any parts list for my car. Any idea where to find it and if there is a part number for it that I can't find? It's for a 63 Ghia vert and I'm running a new wire harness for it. Found all the other grommets, but can't seem to find this small rubber boot. Appreciate any help you can provide. _________________ 1963 ghia convertible project |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 4116 Location: In Molinya Orbit
Posted: Tue Feb 23, 2021 8:51 am Post subject: Re: Ghia wire harness rubber question 1963 |
Thank you so much for the info. It's amazing the level of detail you know about these cars, very impressive. Really appreciate it. _________________ 1963 ghia convertible project |
Posted: Tue Feb 23, 2021 3:22 pm Post subject: Re: Ghia wire harness rubber question 1963 |
Will do, thank you. I did search all over the internet with no luck. You were correct it is hard to find. _________________ 1963 ghia convertible project |
St_Rand Samba Member
Joined: June 30, 2017 Posts: 41 Location: Lafayette Cali
Posted: Thu Sep 15, 2022 9:35 pm Post subject: Re: Ghia wire harness rubber question 1963 |
I am also looking for this part. I have my old one, but it is nearly falling apart. |
I am also looking for this part. I have my old one, but it is nearly falling apart. Any updates if anyone has found a source? |
obus  Samba Member
Joined: March 08, 2001 Posts: 11634 Location: just off Garden State Parkway Exit 81
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6143 Location: 37.5N 77.1W
Posted: Sun Sep 18, 2022 2:34 pm Post subject: Re: Ghia wire harness rubber question 1963 |
Quote: |
anything here similar |
Forgot the metal hole diameter but these go up to 1" (25mm) just make your own inside hole.
https://www.ebay.com/itm/223617273753?epid=1503903...BMwIuLqOpg _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Joined: February 22, 2001 Posts: 1582 Location: MIAMI
bnam Samba Member
Joined: July 02, 2006 Posts: 3462 Location: El Dorado Hills CA/ Bangalore, India
Posted: Wed Jul 30, 2025 11:52 pm Post subject: Re: Ghia wire harness rubber question 1963 |
Good idea. I was also considering a ball joint or tie rod end boot. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Posted: Thu Jul 31, 2025 11:01 am Post subject: Re: Ghia wire harness rubber question 1963 |
Both tie rod and balljoint boots are larger by a lot.
A late style shift boot still seems to have the closest look.
I did just try on a 1966 vw bus shift rod boot and it fits nice.
I also tried on a boot from the vw aircooled master cylinder and it fit snug as well.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211711183B
My concern with any choice s it lasting the lifespan of the restoration. I'm not yet ready to install the harness so I still have some time. _________________ 1960 double cab
1969 beetle convertible
www.volksblast.com |
bnam Samba Member
Posted: Thu Jul 31, 2025 4:38 pm Post subject: Re: Ghia wire harness rubber question 1963 |
What about heat shrink? There are ones available with adhesive too. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
tri356 Samba Member
Posted: Sun Aug 03, 2025 8:47 am Post subject: Re: Ghia wire harness rubber question 1963 |
Does anyone have a picture of one in good condition, preferably from a couple of angles? I'd like to send them along to someone who has production capabilities.
Thanks
Mike |
Posted: Wed Aug 06, 2025 8:28 am Post subject: Re: Ghia wire harness rubber question 1963 |
I have temporarily lost my original one. I think they were mouse grey in color
I did find something that looks very very similar when looking at my Porsche 911 from underneath. I have not ordered it yet, waiting to place an order for 356 parts. If anyone beats me to it, please let me know what you discover
Porsche Rubber Cable Boot Sleeve - 356BT6/356C/911/912 62-83 911-611-921-00 | Sierra Madre Collection | Porsche Parts and Accessories
https://share.google/AmWyzhlp7U7FeJn5j _________________ 1960 double cab
Loren  Samba Member
Posted: Wed Aug 06, 2025 9:20 am Post subject: Re: Ghia wire harness rubber question 1963 |
That Porsche boot looks really close. I'm curious about the size too. Maybe I will order one to see. I have a good original one (I don't know how pliable it is though) in one of my parts boxes. I will try to find it in the next week or two. They were just black rubber. |
Loren  Samba Member
Posted: Wed Aug 06, 2025 9:29 am Post subject: Re: Ghia wire harness rubber question 1963 |
Maybe if asked nicely they will take measurements. _________________ 1960 double cab
tri356 Samba Member
Posted: Wed Aug 06, 2025 9:53 pm Post subject: Re: Ghia wire harness rubber question 1963 |
Thanks for the responses. Yes, please, if you have one in good condition, it'd be great if measurements could be provided.
All I was going to do was to reach out to International Mercantile, which makes rubber parts for the 356 and 911. They mention they can provide manufacturing capabilities for projects. Cost of course is the next question, but, it'd be good to see first if it could be done.
Mike
PS. The rear decklid seal is the other rubber piece I was considering inquiring about. |
