CV Axle Gasket?
vwwestyman
vwwestyman is offline
PostPosted: Tue Mar 03, 2015 10:42 pm    Post subject: CV Axle Gasket? Reply with quote
Am I smoking something?
I could have sworn there was supposed to be a paper/cardboard gasket between the CV joints and axle flanges at the bearing/transmission. But when I asked about it at the FLAPS he couldn't find anything, so I googled for it and couldn't find any mention of them on several different sites talking about repairing/replacing the CV joints.
Dave Cook
1973 Wild Westerner
My Thing
old DKP driver
old DKP driver is offline
PostPosted: Tue Mar 03, 2015 10:44 pm    Post subject: Reply with quote
ONLY on Porsche NOT Vw's Very Happy
V.W.owner since 1967
OB Bus
OB Bus is offline
PostPosted: Tue Mar 03, 2015 10:49 pm    Post subject: Reply with quote
I went through this when I changed my axle. The old (original?) axle had the gasket and the new axle came with the a new paper gasket. I used the gasket and it made installation a mess. Then I learned from the good people here that the paper gasket is not required or used on a Bus. The next axle I changed I did without the gasket and it went so much easier. No leaks either.
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for.
vwwestyman
PostPosted: Tue Mar 03, 2015 10:50 pm    Post subject: Reply with quote
Good enough for me.
I guess that later on VW decided they needed to be Porsche-level fancy and install the gaskets, cause I'm more than certain that some water-cooled cars I've had had them. Not that I worried too much about replacing them at the time...
Dave Cook
1973 Wild Westerner
My Thing
raygreenwood
raygreenwood is offline
PostPosted: Tue Mar 03, 2015 10:57 pm    Post subject: Reply with quote
They are not a big deal to install. I make my own for my 412. They prevent grease seepage and get rid of the greasy joint syndrome and the greasy crusty bolt heads that need cleankng out like mowt people complain about.
Necessary. ..no. useful?.....yes. Ray
airschooled
Air-Schooled
airschooled is offline
PostPosted: Tue Mar 03, 2015 11:49 pm    Post subject: Reply with quote
The early and higher quality buses had a flange on the stub axle that prevented most grease splatter. They also had a plastic(?) cap on the inside of the joint to contain the grease. Unfortunately the stub axle is not interchangeable.
Robbie
WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
kreemoweet
kreemoweet is offline
PostPosted: Wed Mar 04, 2015 2:33 am    Post subject: Reply with quote
I think the grease film on the CVJ's helps to keep the rust away. A big plus for those of us who can't garage or otherwise pamper our rigs.
'67 bug: seized by the authorities
raygreenwood
PostPosted: Wed Mar 04, 2015 10:06 am    Post subject: Reply with quote
in my experience....and this is also in I believe the, Haynes and Chiltons manuals for my car....greasy oily under pinnings promote rust.
Its the oil seeping out of the grease....not just liquid grease. That oil collects dust and dirt and gets crusty. That crusty oily grease/dirt conglomerate absorbs moisture and holds it against metal. Its also porous so its not airtight.
Its a common cause of body rust through points in humid areas.
There are no positives to leaking or seeping oils that I see. I dont have a garage either. Keeping the vehicle outside does not promote rust on dry parts if the parts are protected by paint or oxide treatment in the first place. Ray
kreemoweet
PostPosted: Wed Mar 04, 2015 11:42 am    Post subject: Reply with quote
raygreenwood wrote:
... greasy oily underpinnings promote rust.
Gotta say my experience is to the contrary. Agreed that an intact paint film is the best, but I always find the worst rust is where paint/undercoating
has bubbled/separated but not fallen off. There's an enormous surface area under a bus to be protected, keeping it all nicely painted is almost
a full-time job.
In the dank climate I live in, there are no "dry parts" on a machine that lives outside, except for a couple of months in summer. I have a storage
shed, completely "dry" but unheated and well-ventilated. Every ferrous surface in there gets significant rust in a few months unless kept well-oiled. That's why I
don't keep my car parts in there.
I've heard it said that in some parts of the world, used motor oil is used to spray the undersides of vehicles as a rust preventative, with excellent results.
aeromech
aeromech is offline
PostPosted: Sat Nov 08, 2025 11:39 pm    Post subject: Re: CV Axle Gasket? Reply with quote
Reviving this 10 year old thread.
Recently I replaced my cv boots on my 1971 bus and when I did I noticed quite a mess from grease being slung around from all four cv’s. There was quite a trail hanging off my starter.
Finding this brought back an old memory from years ago when I did an axle change on some kind of water cooled VW which used a thin cork gasket. I’d like to find these gaskets as I believe from my old memory that they would fit the bus as well.
Something like this maybe:
https://www.google.com/search?q=vw+cv+joint+gasket...ent=safari
Does anyone have experience with this?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
kreemoweet
PostPosted: Sun Nov 09, 2025 4:57 am    Post subject: Re: CV Axle Gasket? Reply with quote
It's hard to believe that much, if any, grease would ever leak past the joint-to-flange interface. Torn boots, yes. And yes to trans-oil-plus-road-grime "grease" from leaking oil seals and caps in the flange.
Years ago, I bought a Brazilian "bus" axle with CVJ's from a Bus Depot clearance sale, I recall that it came with those gaskets, which I tossed.
poundman
poundman is offline
PostPosted: Sun Nov 09, 2025 6:06 am    Post subject: Re: CV Axle Gasket? Reply with quote
I am also curious since I will be installing my CV axles soon.
Restoring a 1972 Bay Window Bus that has not be registered for the road since 1981.
Sugar Land, Texas
raygreenwood
PostPosted: Sun Nov 09, 2025 6:41 am    Post subject: Re: CV Axle Gasket? Reply with quote
As I noted 10 years ago.....its not "grease" that is leaking. It is the oil that separates from the grease. Grease is nothing but thickened oil.
The grease is too thick to seep. The oil is not. That link to the gaskets is nice because it shows you versions of CV gaskets from the usual suspects. Those blue non-cork ones from AutohouzeAZ are moderately better.
I will say that the cork gaskets are the bigger problem. Virtually every actual cork gasket I ever bought was....old....crispy....even back in my early vw days in high school and college. They work when they are pliable and installed properly.
Before I had fully learned to work on everything in my first 411 car I still had a mechanic guru I went to for certain things until about my second year in college. I learned a lot. I watched him install a set of these on a porsche 914. I had tried to install one of these gaskets on one side of my car and it was a mess so I left it out.
How he installed it leak free was to clean the hub very well. Spotless. He then used a thin fast drying gasket adhesive. This was 1982. It smelled like Yamabond or similar. He let it mostly dry until it just had some tack. He placed/arranged the gasket inside of the hub on the transmission. The sealant was just to keep it in place.
Then he installed the cv....only marginally greased. Bolted it down. Then he pumped in the rest of the grease with a skinny tube through the boot.
He noted....that once you do this....after you drive it,....wait a day or so and retorque the bolts. You may have to do this twice.
Why?....because some of the the cork gaskets are too thick. They take a while to compress. The bolts get loose as the gaskets continue to compress.
He also noted that a lot of the gaskets on smaller joints or joints without a gasket recess do not seal as well around the bolts and still can seep at the bolts.
The way I have done the for a long time is to put a single fine corner bead of solvent based sealant in the cuff of the flange on the transmission. I used to use a German gasket sealant I got from the dealer many years ago. Now I use something like motoseal or yamabond....same thing. Then put a very thin ring around each bolt hole either on the hub or on the joint. Let it dry completely so it shrinks down thin. You are making a custom gasket maybe 0.005" thick. Then bolt it together. Never leaks.
Ray
EDIT.....it was "Hondabond 4" I was taught to use and NOT Yamabond.
Actually these days, Permatex Motoseal works as good or better.
aeromech
aeromech is offline
PostPosted: Sun Nov 09, 2025 6:53 am    Post subject: Re: CV Axle Gasket? Reply with quote
Just what are you saying here? Am I misinterpreting? You gunna ask me for pictures next?
$20 got me four gaskets coming from autohausaz. I’ll come back here with a report on them in a couple weeks. Might even bring some pics to show some people
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
raygreenwood
PostPosted: Sun Nov 09, 2025 7:19 am    Post subject: Re: CV Axle Gasket? Reply with quote
Are those the blue ones? I have been wondering about those. I had used a similar set a long time ago on a type 3 and they were really nice. They were a somewhat squishy either silicone or urethane blend.
Oh....the other thing that happened....so the sealant method I just posted about worked great for a long time. Then right around the early 2000's....my joints started leaking at the boot flange and not at the transmission flange.
This is because the sheet metal stampings on CV boots got crappier....like everything else....and less flat and less precise in the corners where it meets up with the chamfer on the perimeter of the joint. So, I started treating the boot flange the same way.
I just use a small brush and paint the whole inside face and corner of boot flange. Let it dry and paint it again. You get about 0.005" to maybe 0.008" thick.
Also, you want to use a SOLVENT BASED product like Motoseal or....and this is where I mis-spoke (not enough cofee) in my last post. While you CAN use Yamabond....it was actually HONDA-BOND that I was taught to use. Specifically Hondabond 4.
You want a solvent based sealers because they are roughly 60% solvent. Once that flashes off, the adhesive film shrinks by roughly 60% in thickness making a thin uniform film.
Permatex Motoseal works as good or better and is easier to find locally.
Ray
richparker
richparker is offline
PostPosted: Sun Nov 09, 2025 7:39 am    Post subject: Re: CV Axle Gasket? Reply with quote
I’ve seen the before and in my case it was the drive flange seal leaking gear oil into the CV. Most recently on my Double Cab. Oil everywhere on the passenger side, someone used the wrong year flange seal and oil was leaking into the CV and was being tossed everywhere. Anyway, I ordered the correct seal and I’m hoping the trans was not run out of oil and is still good. It spins freely, although I spent a hour scraping oil caked dirt off it.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab
SGKent Premium Member
SGKent is offline
PostPosted: Sun Nov 09, 2025 8:06 am    Post subject: Re: CV Axle Gasket? Reply with quote
never had a bus leak significant grease there. I use Lobro boots. Some late CV's for vanagons had a thin seal that went around the outside of the joint but the only place i have seen them is with new CV kits like these
https://dansperformanceparts.com/cv-joint-kit-for-...-nauFPPIDS
Porsche 911, 928 use these. They go between the flange and CV. You'll need to figure something else out for the boot to CV. Be sure if you use them to retorque on a regular basis. Some people refer to paper seals and more than one thread I found people say after many failures they refuse to use them again.
https://www.autohausaz.com/pn/93033229700?utm_sour...iMQAvD_BwE
https://www.ecstuning.com/b-rein-parts/inner-cv-ga...rQQAvD_BwE
George Carlin:
Skills@EuroCarsPlus:
Willin
Willin is offline
PostPosted: Sun Nov 09, 2025 9:28 am    Post subject: Re: CV Axle Gasket? Reply with quote
I just replaced a torn boot yesterday.
Looking at things, it doesn't look like grease is leaking out. ( Trans. is leaking oil though, so it's kind of a mess.)
But, I was more concerned about water leaking IN. Especially at the boot flange.
Bentley manual, ( which I just picked up along with the boots) doesn't show any gasket/seal between CV and axle stub, or CV and boot flange.
I wondered what kind of sealant one would use there , which would be effective, and allow removal in the future. ( Your dealing with a grease-y mess.)
Decided to put it back together without cleaning all the grease from mating surfaces. So the grease is the seal.
I can't see putting a thick cork/paper gasket here between machined metal surfaces that you torque down. ( And then have to keep re-torquing.)
Maybe between boot flange and CV, but again...
My tip is to use an impact driver to spin the bolts in and out,(after loosing them first), speeds things up. Then tighten and use a torque wrench. (Wheel off the ground, so it turns, you can get at all the bolts.)
73 bus. Org. 1700 with dual Weber 40 idfs, bus header with Empi qp muffler, CB magnaspark 2 " ready to run kit".
aeromech
aeromech is offline
PostPosted: Sun Nov 09, 2025 9:38 am    Post subject: Re: CV Axle Gasket? Reply with quote
I plan to use permatex anaerobic sealant which never hardens.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
richparker
PostPosted: Sun Nov 09, 2025 9:48 am    Post subject: Re: CV Axle Gasket? Reply with quote
Contour a new boot on without addressing the leak from the transaxle?
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab
