gmd1417 Samba Member
Joined: October 03, 2010 Posts: 8 Location: Dallas, Tx
Posted: Sun Nov 23, 2025 3:44 pm Post subject: 135r15 tire proper inflation? |
| Anyone running 135r15 tires on their lowered V-dub? What psi do you have in them? The sidewall states "36 psi Max Pressure". Thanks! |
Stinky123 Samba Member
Joined: January 31, 2022 Posts: 243 Location: Grand Junction, CO
Posted: Sun Nov 23, 2025 9:48 pm Post subject: Re: 135r15 tire proper inflation? |
| The "Maximum Tire Pressure" has nothing at all to do with what sort of tire pressure you should be running/using. |
Posted: Mon Nov 24, 2025 7:36 am Post subject: Re: 135r15 tire proper inflation? |
| I agree, but what should one run in a tire that states "max 36 psi" on the sidewall? |
EVfun  Samba Member
Posted: Mon Nov 24, 2025 8:03 am Post subject: Re: 135r15 tire proper inflation? |
With 155R15 tires the factory called out 18psi, so a good starting point would be 22psi for the slightly smaller tire. It's going to handle like crap not matter what tire pressure you run. _________________
| Wildthings wrote: |
| As a general rule, cheap parts are the most expensive parts you can buy. |
Posted: Tue Nov 25, 2025 7:50 pm Post subject: Re: 135r15 tire proper inflation? |
| I was waiting for somebody to respond w/the factory recommendation. I really don't know but, the factory recommendation is a good start. If I remember right, people have had problems, w/the front end bouncing, when running 32# |
Bill Schwimmer Samba Member
Posted: Wed Nov 26, 2025 8:11 am Post subject: Re: 135r15 tire proper inflation? |
| Is this a beetle?? I run 18lbs in a 145 on a lowered '59 beetle. Drives nice rides good. Any more the steering gets too light & it wanders around. |
Posted: Wed Nov 26, 2025 3:55 pm Post subject: Re: 135r15 tire proper inflation? |
Yes, it's a 1959 Cal-look bug
EverettB  Administrator
Joined: April 11, 2000 Posts: 71937 Location: Phoenix 602
Posted: Wed Nov 26, 2025 5:44 pm Post subject: Re: 135r15 tire proper inflation? |
| Thanks- What size tires came on stock beetles? |
daveblank Samba Member
Joined: November 07, 2024 Posts: 259 Location: Dallas, TX
Posted: Thu Nov 27, 2025 11:49 am Post subject: Re: 135r15 tire proper inflation? |
| Here is a trick I learned many years ago. Make a thick, straight line of chalk across the tire's tread, drive a short, straight distance(big empty parking lot works great), and observe the chalk wear pattern. If the chalk wears off evenly, the pressure is correct. If the center wears off first, the tire is overinflated; if the edges wear off first, it is underinflated. Adjust as necessary. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11143 Location: Black Forest, CO
Posted: Thu Nov 27, 2025 8:11 pm Post subject: Re: 135r15 tire proper inflation? |
Thing with small tires is the correspondingly smaller contact patch. And the smaller diameter component gives the brakes more leverage on that patch. And if you over-inflate them the patch gets even smaller.
So they look really cool ... as you slide through intersections with the fronts locked up.
[/rant]
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
